Hardware
From Domoticz Wiki
Revision as of 05:35, 20 May 2024 by Creasol (talk | contribs) (Solarinverters)
This page lists almost all the devices and services that Domoticz can connect to. This list is curated by the community, so it may not be complete. Not all supported devices have pages on this wiki. In that case have a look in the Domoticz forum. Please help grow this list. Also, have a look at the Scripts page, which also offers other ways of integrating hardware and services into Domoticz.
To install hardware you first have to install the Hardware Gateway (Setup -> Hardware) and then modify the separate devices (Setup -> Devices)
The developers have created a Python plugin framework which allow other developers to easily create an interface between a piece of Hardware (or Virtual Hardware) and Domoticz.
Devices that are not supported by the build in Domoticz Hardware but by the Python plugin framework can be found on the following page: Plugins
Nice products to buy at one store
Gearbest
Compatible_products_on_gearbest
How to add a device to this list
Please add the name of the device or service, and if relevant, through which gateway-device you were able to connect to it. It would be great if you could create a wiki-page that explains the steps you took. You don't have to mention all the steps of getting the protocol/gateway to work on that page, that information should be gathered under the Integrations and Protocols part of this wiki. Please refer to those pages if you think its reasonably safe to assume that the device will continue working with new versions of those gateways. For example, it it works with bluetooth now, it will probably keep working in the future.
If you have a device that is not supported you could lend it to the developers of Domoticz. Please provide us with either:
  • Your device (please contact us before sending, we will ship it back), or
  • Donate a device to us, also please contact us before doing so
You can also open a topic on the forum to discuss about the product.
433 MHz devices
The two most popular ways of connecting to 433Mhz devices are through the RFXcom and the RFLink gateways. It is impossible for the developers to own all hardware that is supported by RFXCOM / Z-Wave / others, so this means that some devices are supported by RFXCOM / Z-Wave, but not yet supported in Domoticz. If you are able to get a device working, please also share through which gateway you managed this, by adding it in brackets after the device name. Examples are the RFLink, RFXtrx433 and/or the RFXtrx433E.
To get your device supported in Domoticz, we need:
  • In case of 433Mhz device with RFXCOM: RFXmngr screen dump (copy-paste text, not a screen dump)
A
Alecto WS1200 = Weatherstation
Alecto SA30 = Smoke Detector [ linkable smoke detector ]
ANSLUT = IKEA light
A-OK roller blind motor = Blind motor
ASA (RFXtrx433E) = Blind motor
ATI Remote Wonder = Remote
ATI Remote Wonder II = Remote
ATI Remote Wonder Plus = Remote
Atlantic = Sensor?
Atlantic's = PIR DT335R DMT and MC335R DMT
B
Banggood SKU174397 Temperature sensor. Seen as 'Alecto WS1700' when you enable 'Rubicson' protocol on RFXCOM. See also the forum topic.
Blyss (Lighting)
Brel 45MR40 (=blinds motor) works with RFXtrx433E, connection procedure described in this forum topic .
Brennenstuhl
ByeByeStandBy
Byron SX chime
C
cent-a-meter, Electrisave
Chacon (except EMW200)
Chacon (including EMW200)
CLSF LM-101LB Smoke detector
COCO
Creasol DomBus : reliable RS485 wired bus modules optimized for low power consumption, such as DomBus31 (<10mW in standby, <500mW with ALL 8 relays ON), DomBusTH (temp+hum sensors, 3 leds, 7 I/Os), DomBus12 (9 I/Os), DomBus23 (2 relays, 1 AC input, 2 opto inputs, 2 I/Os, 1 mosfet PWM with 12A 30Vmax), ...
Cresta weather sensors (TX2/3/4/7/17,WS2300)
Cresta Temp/Hum Sensor TS34C
Cresta Temp/Hum Sensor TX320
D
DI.O
Digimax
Digimax RTS10 / RFS10 / TLX1206
DomiaLite
Düwi
Dooya blinds
E
ebode - XDOM
ELRO AB400
ELRO AB440
ELRO AB600
Efergy Engage forum tread engage efergy platform
Ematronic roller blind motor
Energenie ENER010 [1]
Energenie ENER002 [2] - manually add as COCO GDR2, put socket in learn mode, send a COCO GDR2 on/off command on the address you want it to learn to
ESP8266 With ESPEasy
Eurochron TSC34C (sold by Conrad)
Eurodomest/Intertek 972080 from Action [ Add as 'ARC' device, works with RFXCOM 'E' version. Included remote not working with Domoticz]
Etekcity Zap 5LX-S (plugs can be commuted one by one or all at once, remote not recognized by RFXCOM) EV1527 PIR (branded BQ677 / 80L Wireless Intelligent Wide-Angle PIR sensor (using RFLink gateway 1.1 r35)[3]
EverFlourish EMW203R-UK Remote Control Plug (Sold by B&Q as GAO Remote Control Switch GAO Remote Control Switch)(using RFLink gateway 1.1 r35)
F
Flamingo FA20RF [ linkable smoke detector ]
Focus MD-214R wireless alarm siren (RFXtrx433E)
H
Harrison curtain
Hasta motor
Hideki, TFA weather sensors
HomeEasy
HomeEasy (including HE105)
HomeEasy HE311 (Dusk/Dawn sensor)
HomeEasy EU
HomeEasy EU HE300
HomeEasy EU HE305 door sensor (RFXtrx433E)
HomeEasy EU HE800
Horstmann C-STAT 11/17 Thermostat and ASR-ZW Switch Forum post:[4]
HomeEasy EU HE842 Remote Control Wall Switch (using RFLink gateway 1.1 r35)
HomeEasy EU HE863 Outdoor Light Sensor (using RFLink gateway 1.1 r35)
I
IKEA Koppla
Impuls
Intertechno
K
KD101 (Avidsen, Chacon, NEXA, Flamingo, Blyss, Proove)
Kerui D025 Door sensor (only triggered on open)
Kerui P819 PIR motion sensor
KlikAanKlikUit
L
La Crosse weather sensors
Lexibook (SM883)
LightwaveRF, Siemens (lighting & power)
M
Maplin N32HN Sockets [5] - manually add as COCO GDR2 with address matching selector wheels on the socket
Media mount projection screen
Meiantech
Mertik Maxitrol (G6R-H4T1, G6R-H4TB)
Maverick bbq thermometer ET732
MAX Control sockets (C45-100150), use 'Impuls' protocol
Maplin branded RSL3660R (using RFLink Gateway 1.1 r35)
N
NEXA [6]
Nexa LGDR-3500 power outlet (RFXtrx433E)
Nexa LMST-606 door sensor (RFXtrx433E)
Nexus design IW008T
O
Oregon Scientific BWR101/BWR102, GR101
Oregon weather sensors (all 1.0,2.1,3.0)
OREGON SCIENTIFIC THGR328N
Oregon Scientific Motion sensor MSR939
OUDI AD-87 433MHz Wireless Door Contact - White | 'Lighting 4' protocol | RFXtrx433E | Forum
OWL CM113
OWL CM119
OWL CM160
OWL CM180
OWL Intuition CM180i
P
PC Remote
Phenix
Philips SBCSP370/375
Proove
Prologue Temperature & Humidity sensor (Biltema 84-0871)
PT2262 receivers
R
Raex roller blind motor
RFXMeter
RFXSensor
Rising Sun
Rohrmotor24.eu blinds RMF-series
RollerTrol blinds
RUBiCSON (48659,48695)
S
Sartano
Sencor SWS 3TS (recognized as CrestaTS34C)
Somfy
SUNLUXY PB-62 Wireless Doorsensor (recognized as Lighting4, PT2262)
T
Techno line TX95-TH
U
UPM/Esic Clas Ohlson (very short receive range)
V
Viking, FineOffset (02035,02038, 02811)
Visonic PowerCode
W
Waveman
WH3 Temperature Sensor | 'FineOffset/Viking' protocol | RFXtrx433E | Forum
X
X10 lighting, X10 security
X10 dimming is not supported by the RFXCom
X10 Ninja/Robocam
X10 remotes
X10 MS13 Motion Sensor (Battery change will cause loss of ID and settings)
X10 MS13E2 Motion, Sensor (With memory, battery change will not cause loss of settings)
868 MHz devices
A good way to interact with 868 Mhz devices is using for example the RTL-SDR v3 USB dongle.
Z-Wave devices
Controllers
Aeon Labs Aeotec Z-Stick S2 (non Z-Wave Plus)
Aeon Labs Aeotec Z-Stick Gen5 (Z-Wave Plus)
Vision Z-Wave Stick ZU1401
Z-Wave.Me RaZberry (Raspberry PI GPIO daughter card)
Z-Wave.Me RaZberry2 (Raspberry PI GPIO daughter card with better antenna)
Z-Wave.Me UZB Z-Wave Plus USB stick
If you are going to buy a new usb stick, buy a Z-Wave Plus model because they will support all Z-Wave Plus and non-Plus devices.
DO NOT unplug the USB sticks while Domoticz is running or it will crash.
If you want to include nodes with the Aeotec sticks, turn off the Pi before removing the stick.
Also you sometimes need to be persistent when including a node fails for the first time.
Sometimes you need to try many times to include a node before it will work.
Secondary Controllers/Remotes
Aeotec Minimote
A
Aeon Labs = Aeotec
Aeon Labs Z-Wave stick
Aeotec Panic Button
Aeotec Z-Stick Series 2
Aeotec Z-Stick Series GEN5
Aeotec ZW088 Key Fob Gen5
Aeotec ZW100-C MultiSensor 6
Aeotec ZW096-C16 Smart Switch 6
Aeotec LED Bulb
Aeon Labs Recessed Door Sensor
Aeon Labs Multi Sensor
Aeon Labs Energie meter Hem3-100A
Aeon Labs Extender
Aeon Labs Recessed Door Sensor GEN5
Aeotec Micro Smart Energy Switch G2 (DSC18103)
B
BeNext Energy Switch [ incl. use measurement, and Solar measurement ]
C
Comm5 MA-5nnn-2 relay and digital sensors
D
Danfoss Radiator Valve Thermostat (LC-13)
E
Everspring SE812 Siren
Everspring SF812 Smoke Alarm
Everspring SP814 Motion Detector
Everspring AD142 Plug-in Dimmer Module
Everspring AN157 Plug-in Appliance Module
Everspring AN158 Plug-in Meter Appliance Module
Everspring TSE03-0 Doorbell
Everspring ST812 Flood Detector
Everspring ST814 Temperature and Humidity detector
Eminent EM6550 Wallplug (recognized as: 'Everspring AN145 Lamp Screw In Module')
Eminent EM6551 Wallplug dimmer (recognized as: 'Everspring AD142 Plug-in Dimmer Module')
Eminent EM6552 Wallplug (recognized as: 'Everspring AN158 Plug-in Appliance Module')
Eminent EM6555 Lamp Screw in module (recognized as: 'Everspring AN157 Plug-in Appliance Module')
Eminent EM6581 Motion Detector (recognized as: 'Everspring SP814 Motion Detector')
Eminent EM6601 Energy Reader (recognized as: 'NorthQ NQ-92021 Power Reader')
Eminent EM6575 Alarm module (recognized as: 'Everspring SE812 Siren')
EUROtronic EUR_STELLAZ Wall Radiator Thermostat Valve Control (temp. set, low-battery warning, temp. read (with polling on))
F
Fakro ZWS230 Window Opener (partially? open, stop, close works)
FIBARO System FGBS001 Universal Binary Sensor
FIBARO System FGBS321 Universal Binary Sensor (Shown as FGBS001)
FIBARO System FGD211 Universal Dimmer 500W
FIBARO System FGD212 Universal Dimmer 250W
FIBARO System FGK101 Door Opening Sensor (including optional temperature sensor)
FIBARO System FGMS001 Motion Sensor (movement, temperature, lightlevel, tamper) (EU ZW+ version 3.2 movement, temperature DOES NOT WORK)
FIBARO System FGRGBWM-441 (RGBW Controller)
FIBARO System FGRM222 Roller Shutter Controller 2
FIBARO System FGSS101 Smoke Sensor
FIBARO System FGSD-002 Smoke Sensor EU V3.3
FIBARO System FGS221 Double Relay Switch 2x1.5kW
FIBARO System FGS222 Double Relay Switch 2x1.5kW
FIBARO System FGS223 Double Relay Switch 2 2x1.5kW
FIBARO System FGWPE Wall Plug
FIBARO System FGFS101 Flood Sensor (including temperature,tamper)
FIBARO System FGSD002 Smoke sensor (including temperature,tamper)
FIBARO System FGS212 Switch 3kW
G
Greenwave PowerNodes 1 and 6 socket version with power measurement, also known as Nuon Smart Plug 1 and 6
H
EZ-Motion/Homeseer HSM100 (temp works, motion works, Lux does not work) Heiman, CO Sensor HS1CA-Z
Heiman, Indoor Siren HS2WD-Z: see [7]
Heiman, Smart Smoke Sensor HS1SA-Z
I
J
Jasco Z-Wave Wireless Lighting Control On/Off Switch, 45609
Jasco Z-Wave Plug-In Outdoor Module - JA12720
Jasco Z-Wave On-Off Wall Switch - JA12722
Jasco Z-Wave ZW4005 In-wall Wireless Smart switch
L
Linear Z-Wave 500-Watt Wall-Mount Dimmer Switch - WD500Z-1
Linear Z-Wave 15 Amp Single Wall Outlet - Wo15Z-1
Leviton Vizia RF+ VRS15-1L
M
N
Neo CoolCam NAS-DS01Z Door/Window Detector
NEO CoolCam NAS-PD01Z Z-wave PIR Motion Sensor
Nuon Smart Plug 1 and 6 with power measurement (are actually Greenwave PowerNodes 1 and 6)
P
Philio Technology Corporation PAN04-1 Double Relay Switch 2x1.5kW with Power Measurement
Philio Technology Corporation Slim Multi-Sensor PSM02
Popp 123580 Plug-in Dimmer
Popp 123658 Plug-in Switch plus Power Meter
Popp Z-Weather Station
Popp 123627 Plug-in switch
Popp / Duwi ZW ZSA 3500 Plugin Switch
Popp / Duwi ZW ZS 3500 Plugin Switch
Q
Qubino ZMNHBA2 Flush 2 Relays (Also supports power measurement. Temp sensor optional.) - Not fully working, strange behavior when cliking switch on Domoticz
Qubino ZMNHDA2 Flush Dimmer (Also supports power measurement, two additional general purpose switches. Temp sensor optional.)
Qubino ZMNHDD1 Z-Wave Plus Flush Dimmer (Also supports power measurement, two additional general purpose switches. Temp sensor optional.)
Qubino ZMNHJD1 Dimmer "Fil Pilote" (for heater management) (requires to create xml config file - refer to post "QUBINO ZMNHJD1 not compatible with Domoticz ?" in forum)
The Z-Wave Plus devices might not work with the Aeon Labs S2 stick with Domoticz version <3.4834.
(Dimmer confirmed however to work with Aeon Labs V5 stick and Z-Wave.me stick).
To get the additional switches of Z-Wave Plus devices working you need to add the node in several groups. See the forum.
All Qubino dimmers can dim very low power LED lights without any bypass as they do not require a minimum load.
R
S
T
TKB TZ68 (on/off socket)
U
V
Vision Motionsensor
Vision ZL7432 In-Wall Switch, Dual Relay
Vision ZS6301 CO Detector
Vision ZD2102 Door/Window Sensor
Vision ZP3102 PIR Motion Sensor (there is a red sensor's headline in Switches and Dashboard)
Vision ZG8101BR Garage Door Sensor
Vision ZM1601 alarm siren
Z
Z-Wave.Me UZB Z-Wave Plus certified USB Stick
Z-Wave.Me RaZberry a tiny daughter card that sits on top of the Raspberry PI GPIO
Zipato RGBW LED bulb
Zooz zse08 contact-sensor
Zooz Z-Wave Smart-Plug ZEN06
Zooz ZSE40 Plus 4-in-1 Sensor
Zigbee
Various large brands are now selling Zigbee devices like light bulbs, switches and sensors. For example: IKEA Tradfri, Philips Hue, Xiaomi / Aqara, Trust, Heiman, Osram, etc.
Domoticz does not have native support for Zigbee USB-dongles (Zigbee Coordinator) but there are plugins for Domoticz that can connect to various Zigbee Bridges/Gateways/Hubs/Controllers that in turn can connect to and control Zigbee devices.
Zigbee <- Read more about Zigbee here.
Bluetooth
Xiaomi Mi-Band presence detection
Xiaomi Mi Flora plant sensor
eHouse BMS
eHouse is BMS and home automation solution integrating many controller types considering size, installation and communication.
eHouse is specially designed for DIY, development and integrations.
Communication interfaces:
- LAN (Ethernet)
- WiFi (2,4GHz b/g/n)
- RS-485
- CAN
- RF 863 MHz
- SPI (PRO)
- I2C (PRO)
- Infrared Remote Control RX/TX
Installation types:
- Central Switchboard (LAN, PRO, BMS, RS-485)
- Room Switchboard (LAN, RS-485)
- External Housing / OEM (WiFi, CAN, RF)
- Standalone (Thermostat)
- Socket cans (CAN, RF, WiFi)
- DIY
Integrations:
- RFID - card readers (PRO + eHouse RFID Gateway)
- CLOUD - MYSQL integration
- Thermostat - (PRO + eHouse Thermostat Gateway)
- Onkyo (Ethernet)
Contollers currently integrated with Domoticz:
eHouse LAN - EthernetRoomManager Controller Ethernet Room Controller: 12 binary inputs, 32 binary outputs, 3 PWM dimmers, 10 ADC inputs, Infrared TX/RX
eHouse LAN - CommManager Controller Ethernet Security System / Blinds Controller: 48 binary inputs, 36 doubled binary outputs, 15 ADC inputs
eHouse LAN - LevelManager Controller Ethernet Centralized Floor Controller: 48 binary inputs, 77 binary outputs, 15 ADC inputs
eHouse WiFi - eHouse WiFi 2.4GHz b/g/n All-In-One Controller Up to 4 relays, up to 4 binary inputs, 1 Temperature input, 3 PWM Dimmers, Infrared RX/TX
eHouse BMS/PRO - Switch-board Ethernet/WiFi Centralized and integrated system: 127 binary inputs, 128 relays 230V/16A, 5 alarm outputs, eHouse Integrations
    | via eHouse PRO Server/Gateway
    | - eHouse RS-485 - RoomManager Controller Room Controller: 12 binary inputs, 24 binary outputs, 8 ADC inputs, Infrared TX/RX
    | - eHouse RS-485 - HeatManager Controller Boiler Room / Ventilation / Central Heating - 16 ADC inputs, 21 Dedicated binary outputs
    | - eHouse RF Thermostat - Temperature sensors with preset(RF 868MHz) - require eHouse PRO server and USB > RS-485 > eHouse Thermostat Gateway
    | - 127 DIY SPI Input modules for Rasberry PI - DIY 127 Input Modules - under eHouse PRO Software with security system implementation
    | - 128 DIY I2C Output modules with Relay Drivers for Rasberry PI - DIY 128 Output Modules - under eHouse PRO Software
EnOcean
Controllers
BSC EnOcean USB 300 USB-Gateway 868MHz / TCM310 Chipset
EnOcean Pi
Products
EnOcean Equipment Profiles (EEP’s) are the fundament of interoperability between EnOcean devices of all different manufacturers. Ideally, the devices using the same EEP are interoperable... but exceptions exist! The list of supported EEP can be found in this page. The equipments implementing supported EEP's sould in turn be supported ! Please refer to your equipment user manual to determine the EEP('s) it implements. A database of EnOcean products is available here.
Here are some examples of supported products, sorted by EEP :
A5-02-13
  • Trio2Sys Outdoor Temperature Sensor, T2S10020076
A5-04-01
  • NodOn Indoor Temperature and Humidity Sensor, STPH-2-1-05
D2-01-0E
  • Nodon Micro smart plug, MSP-2-1-01, MSP-2-1-11
D2-01-12
  • NoDon In-wall modules, dual switches, SIN-2-2-01
F6-02-01/02
  • Eltako Wireless Sensor (Wireless push-buttons FT55-rw) PTM 215, PTM 210 module
  • Trio2Sys Wall Switches TS1002001, T2S10540012 and other variants
Ethernet devices
Relay-Net 8 channel LAN Relay and binary Input module
eHouse LAN - EthernetRoomManager Controller Ethernet Room Controller: 12 binary inputs, 32 binary outputs, 3 PWM dimmers, 10 ADC inputs, Infrared TX/RX (direct integration)
eHouse LAN - CommManager Controller Ethernet Security System / Blinds Controller: 48 binary inputs, 36 doubled binary outputs, 15 ADC inputs (direct integration)
eHouse LAN - LevelManager Controller Ethernet Centralized Floor Controller: 48 binary inputs, 77 binary outputs, 15 ADC inputs (direct integration)
eHouse WiFi - eHouse WiFi 2.4GHz b/g/n Up to 4 relays, 4 binary inputs, Temperature input, 3 PWM Dimmers, Infrared RX/TX (direct integration)
eHouse BMS/PRO - Switch-board Ethernet/WiFi Centralized and integrated system: 127 binary inputs, 128 relays 230V/16A, 5 alarm outputs, eHouse Integrations (direct integration)
    | Indirect integration via eHouse PRO Server/Gateway
MyHome Web server A/V - F454
MyHome Scenario Programmer - MH202
MyHome Screen 35 - LN4890
MyHome Screen 10 - MH4892
MyHome Server1 - MHS1
IP-networkcameras
This page will give you an overview of IP-cameras that users have reported working with Domoticz.
Please mention the brand + type of your camera and also the URL to the image.
If you want to try if your camera works, a lot of settings for different brands of cameras can also be found here: http://www.ispyconnect.com/sources.aspx
Please only add the devices which are really known to work!
General security warning
When connecting the IP-camera to your network, be sure to put a username and a strong password on your IP-camera if you have it opened up to internet, otherwise you might end up at http://insecam.org/
Block internet access to the camera in your router if you don't want to have it connected to the internet.
A fast way to achieve this is to leave the 'Default gateway' field in the camera empty. By doing this it will only have access to your local LAN and no internet access.
IP-Cameras sorted by brand
A
Android Phone (Tested with Sony Xperia V) using this app: IP Camera (Change default port!) - Image URL: shot.jpg
AVtech AVN362 - Image URL: /cgi-bin/guest/Video.cgi?media=JPEG&channel=1
Axis M1054 - Image URL: jpg/image.jpg?size=3
Axis 206 - Image URL: jpg/image.jpg?size=3
B
C
D
D-Link DCS-800L
D-Link DCS-825L - Image URL: /image/jpeg.cgi
D-Link DL-930
D-Link DCS-932L - Image URL: image/jpeg.cgi
D-Link DCS-935L - Image URL: image/jpeg.cgi
D-Link DCS-942L - Image URL: image/jpeg.cgi
D-Link DCS-2332L - Image URL: image/jpeg.cgi
D-Link DCS-5009L - Image URL: /image.jpg
D-Link DCS-5020L - Image URL: image/jpeg.cgi
D-Link DCS-5222LB - Image URL: image/jpeg.cgi
D-Link DCS-7513
Dahua HDW3200S - Image URL: http://<IP address>:9989/onvif/media_service/snapshot?channel=0&subtype=0
Dahua IPC-HDBW4421R - Port "empty" - Image URL: cgi-bin/snapshot.cgi?channel=0
Dahua IPC-HDW4233C-A - port 80 - Image URL: cgi-bin/snapshot.cgi?Channel=0
Dahua SD29204S-GN - port 80 - Image URL: cgi-bin/snapshot.cgi?chn=0
DBPower MEYE-155303-FBACE - Image URL: http://<ip address>:81/snapshot.cgi?user=username&pwd=password
E
Ebode IPV38 - Port 80 - image URL: snapshot.cgi
Ebode IPV58P2P - Port 88 - Image URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=<user>&pwd=<pwd>&
Elro C800IP (also known as Trendnet TV-IP100) - Port 80 - Image URL: /image.jpg
Eminent EM6225 - Port 81 - Image URL: auto.jpg
F
Floureon 4CH CCTV DVR - Port 80 - Image URL: /cgi-bin/snapshot.cgi?channel=1&user=USERNAME&password=PASSWORD
Foscam C1 - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USERNAME&pwd=PASSWORD
Foscam FI9803P V2 - Port 80 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Foscam FI9804W - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Foscam FI8905W - Port 80 - Image URL: /snapshot.cgi?user=#USERNAME&pwd=#PASSWORD
Foscam FI8907W - Port 80 - Image URL: /snapshot.cgi?user=#USERNAME&pwd=#PASSWORD
Foscam FI8909W - Port 80 - Image URL: /snapshot.cgi?user=#USERNAME&pwd=#PASSWORD
Foscam FI8910W - Port 80 - Image URL: snapshot.cgi
Foscam FI8918W - Port 80 - Image URL: snapshot.cgi
Foscam FI9831P - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Foscam FI9831W - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Foscam FI9826P - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USERNAME=&pwd=PASSWORD
Foscam FI9826W - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Foscam FI9853EP - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Foscam FI9900P - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Foscam G4EP - Port 88 - Image URL: /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USERNAME&pwd=PASSWORD
G
H
Hikvision DS-2CD2532F-IWS (Mini-Dome) - Port 80 - Image URL: Streaming/Channels/1/picture
Hikvision DS-2CD2032-I 3MP bullet cam
Hikvision DS-2CD2132F-IS - Port 80 - Image URL: /Streaming/Channels/1/picture
Hikvision DS-7608NI-E2/8P NVR - Port 80 - Image URL: ISAPI/Streaming/channels/101/picture?
Hikvision DS-2CD2346G1-I/SL - Port 80 - Image URL: ISAPI/Streaming/channels/101/picture?
I
INSTAR IN-5905HD - Image URL: /tmpfs/snap.jpg?usr=YOUR_USER_NAME&pwd=YOUR_PASSWORD
Iphone 4 changed into IP cam using this app: http://skjm.com, Image URL: image.jpg
J
K
L
Level one FCS-5051 - Image URL: /cgi-bin/jpg/image.cgi?
Linksys WVC54GCA - Image URL: img/snapshot.cgi
Lowes Iris Digital Outdoor Security Camera - Image URL: img/snapshot.cgi?size=4 (size=3 enables zoom, username/password not required)
M
Maygion H264 IP Camera - Image URL: http://<ipaddress>:81/snapshot.cgi?user=usernamei&pwd=password
N
Neo Coolcam (Pan-tilt camera from http://www.kingstarinternational.nl/) - Port 1888 - Image URL: snapshot.cgi?user=NNN&pwd=NNNN" (where NNN = Username and NNNN= Password)
Nexus 116VW - Image URL: /snap.jpg?JpegCam=[CHANNEL]
O
Overmax Camspot 3.1:
Stream URL: videostream.cgi?loginuse=#USERNAME&loginpas=#PASSWORD
Image URL: snapshot.cgi?user=#USERNAME&pwd=#PASSWORD
OVISLINK WL-5400 Image URL: image.jpg
P
PANASONIC BL-C131 (only video streaming works : the snapshot does not work) - Port 80 - Image URL: SnapShotJPEG?Resolution=640x480&Quality=Standard
Q
R
Reolink - Port 80 - /cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=ADMINNAME&password=PASSWORD
S
Supra IPC-10AC (aldi) - Image URL: URL/snapshot.cgi?user=#USERNAME&pwd=#PASSWORD
Sunell (CGI API) - Image URL: cgi-bin/image.cgi?userName=#USERNAME&password=#PASSWORD&cameraID=1&quality=1
Sricam AP003 Use Admin User & Password in IP. - Image URL: snapshot.cgi (and/or: index.htm/videostream.asf?user=nnnnn&pwd=nnnnnnn&resolution=640*480 (or 320*240))
Sitecom Wifi Home Cam Mini WLC-1000 - Image URL: /img/snapshot.jpg Video URL: rtsp://x.x.x.x:554/live1
T
Tenvis jpt3815w - Image URL: snapshot.cgi?user=????&pwd=????
Tenvis IProbot 3 (PTZ controls + audio not available in Domoticz) - Image URL: ip:port/snapshot?username=[username]&[password]&strm=0
TOP201 - Image URL: http://x.x.x.x/webcapture.jpg?command=snap&channel=0
U
Ubiquiti AirCamDome - Port 80 - Image URL: snapshot.cgi?user=#USERNAME&pwd=#PASSWORD (make sure you have turned off "Use HTTPS" on "Device" tab, else it will redirect to https and that doesn't seem to work with Domoticz)
V
VIVOTEK FD8134V - Port 80 - Image URL: cgi-bin/viewer/video.jpg
VIVOTEK PT7137 - Port 80 - Image URL: cgi-bin/video.jpg
VStarcam C7824WIP - Port 81 - Image URL: snapshot.cgi?user=#USERNAME&pwd=#PASSWORD
VStarcam C7837WIP - Port 81 - Image URL: snapshot.cgi?user=#USERNAME&pwd=#PASSWORD
W
WANSCAM HW0021 - Port 80 - Image URL: web/auto.jpg?-usr=****&-pwd=****&
WANSCAM JW008 - port 99 - image URL: snapshot.cgi
WANSCAM HW0026 - Port 80 - Image URL: web/auto.jpg?-usr=****&-pwd=****&
WANSCAM HW0026 - port 81 - Image URL: snapshot.cgi?user=[USERNAME]&pwd=[PASSWORD]
WANSCAM HW0036 - port 81 - Image URL: snapshot.cgi?user=[USERNAME]&pwd=[PASSWORD]
WANSVIEW 1080P W2 - port 80 - mage URL: mjpeg/snap.cgi?chn=0
X
Xyclop XC-BU-34F-IR - port 80 - Image URL: Streaming/Channels/1/picture
Y
Y Cam Knight SD - Image URL: snapshot.jpg
Z
Grabbing snapshots from RTSP-stream with script based on 'ffmpeg'
Cams that spit out a RTSP-stream (Real Time Streaming Protocol) won't work in Domoticz.
With this script you can grab snapshots from a RTSP-stream. It uses 'ffmpeg' to open the RTSP-stream and grab a snapshot from it.
You still can't use it directly in Domoticz, but if you want to grab a snapshot when the doorbell is pressed for example, this script will do so (outside of Domoticz).
Workaround for getting RTSP-based cam to work in Domoticz (through Synology NAS)
However, if you have a Synology NAS and have the cam working in the Surveillance Station package, you can use this script. It grabs a the stream from the Surveillance Station package and spits it out as a JPEG-image.
You can then use this in Domoticz, because the PHP-script mimicks itself as a JPEG file. The conversion of the stream is done by the NAS. Pretty clever huh!? ;)
LoRa
At time of writing, Domoticz does not support LoRa devices directly but through the TTNMQTT hardware module. Using The Things Network and its network of LoRa gateways, IoT devices can send their data using LoRa radio technology and the TTNMQTT module will read the data using the MQTT facilities from TTN.
WiFi Light
Applamp
Slimmeled
Mi-Light
Sonoff WiFi switch after reflash with ESPEasy
YeeLight
eHouse WiFi 2.4GHz b/g/n All-In-One Controller Up to 4 relays, 4 Binary Inputs, 1 Temperature Input, 3 PWM Dimmers, Infrared RX/TX
Logitech Remote
Harmony Smart Control
Harmony (Ultimate) Hub
Harmony Ultimate
(Be sure the Hub is included)
Remarks:
Domoticz can see and start activities on the Hub. It cannot control devices directly.
For every activity a switch device is added in Domoticz.
Logitech Harmony Hub wiki entry
Logitech Harmony forum topic
Philips Hue
The Philips Hue bridge and ecosytem are natively supported in Domoticz.
Supported Hue lights:
Hue E27 bulb
Hue GU10 bulb
Hue Lux E27 bulb
Hue White bulb
Hue White and Color Ambiance A19/E27 bulb
Hue White and Color Ambiance GU10 bulb
Hue Go
Hue Beyond
Hue Phoenix
Hue Lightstrip Plus (RGBW)
Philips Friends of Hue Bloom
Philips Friends of Hue Iris
Philips Friends of Hue Lightstrip (RGB)
All other official Philips Hue and Friends of Hue products.
LivingWhites dimmer
LivingWhites E27 bulb
LivingColors gen 2
LivingColors Bloom
LivingColors Aura
LivingColors Iris
All other LivingColors will work too except generation 1.
Philips Hue wiki entry
Philips Hue forum topic
Solarinverters
USB Devices
Aeon Labs Z-Stick S2
Dutch DSMR smart meter with P1 port
OpenTherm Gateway USB
RFXCOM RFXtrx433(E)
RFLink Gateway
Teleinfo USB
Vision Z-Wave Plus USB Stick
Z-Wave.me UZB Z-Wave plus usb stick
USBtin Can Gateway
RS485 / Modbus
Creasol DomBus modules (designed for Domoticz, with a proprietary protocol that permits modules to works together independently from the controller, as KNX do):
- Creasol DomBusTH - Temperature + Relative Humidity sensors, 4 inputs, 2 open collector outputs, 3 LEDs, 1 analog input, 1 touch sensor
- Creasol DomBus12 - 9 I/O (configurable as digital inputs, analog inputs, counters, digital outputs, buzzer, blind, pushbuttons, double pushbutton): 2 I/O are configured by default as open-drain outputs, suitable to control external relays
- Creasol DomBus23 - 2 relays, 1 mosfet output (30V 12A) for dimming LED strips, 2 analog outputs 0-10V, 2 I/O (configurable as digital inputs, analog inputs, counters, digital outputs, buzzer, pushbuttons, double pushbutton), 2 low-voltage opto inputs (5-40V), 1 opto input (230V)
- Creasol DomBus31 - 6 N.O. relays (250V 5A) + 2 N.O.+N.C. relays (250V 10A): very low power consumption, less than 500mW with ALL relays ON!
- Creasol DomBus32 - 3 relay outputs, 3 AC optoisolated inputs, 5 I/Os
- Creasol DomBus33 - 3 relay outputs, 3 AC optoisolated inputs, 5 I/Os, designed to work with existing light system using step-by-step relays and pushbuttons
- Creasol DomBus36 - 12 relays output, organized in 3 blocks of 4 relays; each block as 1 common (line, neutral, gnd, V+) to simplify wirings
- Creasol DomBus37 - 12 inputs, 3 AC optoisolated inputs, 3 relay outputs: designed for alarm systems to manage many magnetic contact sensors and PIRs, Siren, power outage detection, ...
- Creasol DomBusEVSE - Smart EVSE module to build a home-made wallbox working in stand-alone and also with home automation system.
More information in the wiki page Creasol Dombus.
PZEM-004T PZEM-014 PZEM-016 single phase power and energy meters: up to 51 meters can be connected to the same bus and managed by the same plugin.
PIFace
PiFace
Internet Services
Domoticz has integration with several Internet Services so you do no need any hardware, but mostly just an account (or somekind of 'key') and Domoticz can read (and write) information to/from these services as if they were local Sensors in Domoticz.
Some available services:
  • PVOutput
  • Winddelen
Thermostats (Internet based)
There are a number of Internet connected thermostats that can be used with Domoticz:
  • Thermosmart thermostat
  • ICY thermostat (Essent)
  • ATAG One thermostat
  • Honeywell thermostat
  • Nest thermostat
  • Tado thermostat
  • Toon thermostat
Weather Services
Several Weather Services have been integrated so you can have your own local weather information without actually having physical local weather station equipment.
Hardware sorted by category
In the following sections the hardware is grouped by category
Climatization, heat pumps, boilers, heaters
In this section a non-exaustive list of climatization devices that can be managed by Domoticz
Energy and power meters
Single phase
  • DDS238-1, DDS238-2: uni-directional DIN-rail 1P energy meters with display and pulsed output. Only power/energy can be measured, through the pulsed output connected to Dombus modules, ESP8266/ESP32 modules, ...
  • DDS238-1 ZN/S, DDS238-2 ZN/S: bi-directional 1P DIN-rail energy meters with display output that can measure power, energy, current, voltage, frequency and power factor, with 1 pulse output and Modbus/RS485 output. Can be used with DDS238 plugin (Modbus RTU), DDS238 plugin (Modbus TCP), with DomBusEVSE and DomBus34 module, ...
  • Eastron SDM220, SDM230 bi-directional DIN-rail 1P energy meters : please add description
  • PZEM-004T, PZEM-014, PZEM-016: uni-directional 1P cheap energy meters to measure active power and energy, current, voltage, frequency and power factor, that can be connected by TTL serial port (004T) or Modbus RS485 (014 and 016). Up to 51 devices can be managed by domoticz-pzem-016 plugin.
Three phase
Flow meters
Sensors and meters to measure fluid like water, hot water, gas, ...
Cheap flow meter with hall sensor
Vehicles
In this section some information about how to connect vehicles to Domoticz.
Domoticz has an EVehicles framework which currently has implementations for:
Some other cars/brands are supported by a different modules.
Tesla
All information about controlling and monitoring the Tesla BEV is available in the EVehicles page.
Mercedes
The Mercedes integration is available via the EVehicles framework.
Hyundai and Kia Connect
The Vehicles Hyundai Kia page shows how to install a plugin to access KIA and Hyundai car information (battery status, locks, ...) and control car temperature, door/trunk lock.
On wikipedia is available all info about the SAE J1772 standard used from electric vehicle supply equipment to inform electric vehicle about the max source current.
Wallbox and EVSE modules
