Philips Hue Lights
From Domoticz Wiki
Philips Hue
Domoticz supports the Philips Hue bridge (both V1 and V2) and automatically detects which API version to use.
Adding the Hardware
Go to Setup → Hardware and select Philips Hue Bridge as the hardware type.
Enter:
  • The IP Address of your Hue bridge (you can also find this in your network router)
First time setup (no username yet):
  1. Leave the Username field empty
  2. Press the link button on top of the Hue bridge
  3. Within 30 seconds, press the Register button in Domoticz
  4. If successful, a username is automatically filled in
  5. Press Add
Already registered before:
  • If you know the username, enter it and press Add
  • If you forgot the username, use the first-time procedure above to register again
Note: To allow Domoticz to create new devices, make sure Accept new Hardware Devices is enabled under Setup → Settings.
Domoticz will automatically probe the bridge after adding:
  • Hue V2 bridges (CLIP v2 API) are detected on HTTPS port 443
  • Hue V1 bridges are tried on HTTPS port 443, then HTTP port 80
  • If no bridge is reachable, an error is logged and the hardware is not started
Configuration Options
Option Description
IP Address The local IP address or hostname of your Hue bridge
Username The application key used to authenticate with the Hue API
Poll Interval For V1 bridges: how often Domoticz polls all device states (seconds, minimum 5, default 10). For V2 bridges: interval between full resyncs; real-time updates arrive instantly via SSE regardless of this setting.
Add Groups Whether to expose Hue light groups as Domoticz devices
Add Scenes Whether to expose Hue scenes as Domoticz selector switches
Supported Hardware
Lights
All lights connected to the Hue bridge are added as Domoticz devices:
  • On/Off lights — basic switch
  • Dimmable lights — dimmer switch (brightness 0–100%)
  • Color temperature lights — dimmer with color temperature control
  • Full colour lights (RGB/RGBW) — RGB colour device
Lights can be controlled directly from the Domoticz dashboard or via scripts.
Groups
Light groups configured in the Hue app can be exposed as a single device in Domoticz (enable the Add Groups option). Controlling the group device turns all lights in the group on/off and adjusts brightness/colour.
Scenes
Hue scenes (named light configurations) can be exposed as selector switches in Domoticz (enable the Add Scenes option). Selecting a scene activates it on the bridge.
Sensors (V1 API)
The following sensor types are supported via the V1 API:
  • Motion sensors (ZLLPresence) — motion/no-motion switch
  • Temperature sensors (ZLLTemperature) — temperature device (°C)
  • Light level sensors (ZLLLightLevel) — lux level device
  • Switches / Remotes (ZLLSwitch, ZGPSwitch) — selector switch with button events
  • Daylight sensor — on/off based on local sunrise/sunset
Sensors (V2 API)
When a V2 bridge is detected, the following additional sensor types are supported:
  • Motion — motion sensors (per room or per individual device)
  • Temperature — temperature sensors attached to motion sensor devices
  • Light level — ambient light level in lux (per room or per device)
  • Contact sensors — door/window open/close state
  • Tamper alerts — tamper detection state
  • Camera motion — motion detected by Hue camera devices
  • Security area motion — motion events from security area zones
  • Grouped motion — aggregated motion state across a room or zone
  • Grouped light level — aggregated light level for a room or zone
  • Buttons / Remotes — Hue dimmer switches and tap dial switches; each remote appears as a selector switch with short/long press levels per button
  • Bell button — Hue doorbell button; triggers a Domoticz doorbell device on ring event
  • Device power — battery level reported for all battery-powered Hue accessories (0–100%, or 255 if not applicable)
V2 API — Server-Sent Events (SSE)
When a Hue V2 bridge is detected, Domoticz uses the Hue CLIP v2 event stream (`/eventstream/clip/v2`) in addition to the polling loop.
The SSE stream is a persistent HTTP connection that delivers real-time push notifications from the bridge whenever a device state changes (motion, button press, contact open/close, etc.). This means:
  • Instant updates — device state changes appear in Domoticz within milliseconds, without waiting for the next poll cycle
  • Reduced bridge load — SSE replaces per-sensor polling for most sensor types
  • Automatic reconnect — if the SSE connection drops, Domoticz reconnects automatically with exponential backoff (up to 60 seconds between retries)
A full resync (fetching all device states via the REST API) still runs at every poll interval to catch any missed updates.
Troubleshooting
Problem Solution
Hardware starts but no devices appear Check the Username/application key. Ensure the Hue bridge is reachable at the configured IP address.
No Philips Hue bridge found error in log Verify the IP address. Check that the bridge is online and reachable from the Domoticz host. Firewall rules may block HTTPS (port 443) or HTTP (port 80).
Lights appear but sensors do not For V1 bridges, sensors must already be paired. For V2 bridges, check that the application key was created on the V2 bridge (not via a V1-only API path).
Battery level shows 255 The device does not report a battery level (mains-powered) or no battery report has been received yet.
Duplicate devices after bridge upgrade If you upgraded from a V1 to a V2 bridge and re-added the hardware, sensors may appear as duplicates due to different internal IDs. You can delete the old devices via Setup → Devices.
Notes
  • The Hue bridge has a limit of approximately 3 concurrent API connections. The SSE stream counts as one connection. Avoid connecting too many external applications simultaneously.
  • Hue V1 bridges manufactured before 2016 may not support HTTPS. Domoticz will fall back to HTTP port 80 automatically.
  • The Hue V2 CLIP API supports additional sensor and device types not available via V1. Using a V2 bridge is recommended for the best experience.
