Philips Hue Lights
Philips Hue
Domoticz supports the Philips Hue bridge (both V1 and V2) and automatically detects which API version to use.
Adding the Hardware
Go to Setup → Hardware and select Philips Hue Bridge as the hardware type.
Enter:
- The IP Address of your Hue bridge (you can also find this in your network router)
First time setup (no username yet):
- Leave the Username field empty
- Press the link button on top of the Hue bridge
- Within 30 seconds, press the Register button in Domoticz
- If successful, a username is automatically filled in
- Press Add
Already registered before:
- If you know the username, enter it and press Add
- If you forgot the username, use the first-time procedure above to register again
Note: To allow Domoticz to create new devices, make sure Accept new Hardware Devices is enabled under Setup → Settings.
Domoticz will automatically probe the bridge after adding:
- Hue V2 bridges (CLIP v2 API) are detected on HTTPS port 443
- Hue V1 bridges are tried on HTTPS port 443, then HTTP port 80
- If no bridge is reachable, an error is logged and the hardware is not started
Configuration Options
| Option | Description |
| IP Address | The local IP address or hostname of your Hue bridge |
| Username | The application key used to authenticate with the Hue API |
| Poll Interval | For V1 bridges: how often Domoticz polls all device states (seconds, minimum 5, default 10). For V2 bridges: interval between full resyncs; real-time updates arrive instantly via SSE regardless of this setting. |
| Add Groups | Whether to expose Hue light groups as Domoticz devices |
| Add Scenes | Whether to expose Hue scenes as Domoticz selector switches |
Supported Hardware
Lights
All lights connected to the Hue bridge are added as Domoticz devices:
- On/Off lights — basic switch
- Dimmable lights — dimmer switch (brightness 0–100%)
- Color temperature lights — dimmer with color temperature control
- Full colour lights (RGB/RGBW) — RGB colour device
Lights can be controlled directly from the Domoticz dashboard or via scripts.
Groups
Light groups configured in the Hue app can be exposed as a single device in Domoticz (enable the Add Groups option). Controlling the group device turns all lights in the group on/off and adjusts brightness/colour.
Scenes
Hue scenes (named light configurations) can be exposed as selector switches in Domoticz (enable the Add Scenes option). Selecting a scene activates it on the bridge.
Sensors (V1 API)
The following sensor types are supported via the V1 API:
- Motion sensors (ZLLPresence) — motion/no-motion switch
- Temperature sensors (ZLLTemperature) — temperature device (°C)
- Light level sensors (ZLLLightLevel) — lux level device
- Switches / Remotes (ZLLSwitch, ZGPSwitch) — selector switch with button events
- Daylight sensor — on/off based on local sunrise/sunset
Sensors (V2 API)
When a V2 bridge is detected, the following additional sensor types are supported:
- Motion — motion sensors (per room or per individual device)
- Temperature — temperature sensors attached to motion sensor devices
- Light level — ambient light level in lux (per room or per device)
- Contact sensors — door/window open/close state
- Tamper alerts — tamper detection state
- Camera motion — motion detected by Hue camera devices
- Security area motion — motion events from security area zones
- Grouped motion — aggregated motion state across a room or zone
- Grouped light level — aggregated light level for a room or zone
- Buttons / Remotes — Hue dimmer switches and tap dial switches; each remote appears as a selector switch with short/long press levels per button
- Bell button — Hue doorbell button; triggers a Domoticz doorbell device on ring event
- Device power — battery level reported for all battery-powered Hue accessories (0–100%, or 255 if not applicable)
V2 API — Server-Sent Events (SSE)
When a Hue V2 bridge is detected, Domoticz uses the Hue CLIP v2 event stream (`/eventstream/clip/v2`) in addition to the polling loop.
The SSE stream is a persistent HTTP connection that delivers real-time push notifications from the bridge whenever a device state changes (motion, button press, contact open/close, etc.). This means:
- Instant updates — device state changes appear in Domoticz within milliseconds, without waiting for the next poll cycle
- Reduced bridge load — SSE replaces per-sensor polling for most sensor types
- Automatic reconnect — if the SSE connection drops, Domoticz reconnects automatically with exponential backoff (up to 60 seconds between retries)
A full resync (fetching all device states via the REST API) still runs at every poll interval to catch any missed updates.
Troubleshooting
| Problem | Solution |
| Hardware starts but no devices appear | Check the Username/application key. Ensure the Hue bridge is reachable at the configured IP address. |
| No Philips Hue bridge found error in log | Verify the IP address. Check that the bridge is online and reachable from the Domoticz host. Firewall rules may block HTTPS (port 443) or HTTP (port 80). |
| Lights appear but sensors do not | For V1 bridges, sensors must already be paired. For V2 bridges, check that the application key was created on the V2 bridge (not via a V1-only API path). |
| Battery level shows 255 | The device does not report a battery level (mains-powered) or no battery report has been received yet. |
| Duplicate devices after bridge upgrade | If you upgraded from a V1 to a V2 bridge and re-added the hardware, sensors may appear as duplicates due to different internal IDs. You can delete the old devices via Setup → Devices. |
Notes
- The Hue bridge has a limit of approximately 3 concurrent API connections. The SSE stream counts as one connection. Avoid connecting too many external applications simultaneously.
- Hue V1 bridges manufactured before 2016 may not support HTTPS. Domoticz will fall back to HTTP port 80 automatically.
- The Hue V2 CLIP API supports additional sensor and device types not available via V1. Using a V2 bridge is recommended for the best experience.
Links
- Philips Hue developer portal: https://developers.meethue.com/
- Hue CLIP v2 API documentation: https://developers.meethue.com/develop/hue-api-v2/
- Domoticz forum: https://forum.domoticz.com/
