Notifications
From Domoticz
Revision as of 19:24, 20 January 2026 by Walter vl (talk | contribs) (Configuring Google Cloud messaging)
Introduction
Notifications can be send for example when a switch is pushed, electricity usage is too high,temperature to high and for many more options.
See page [Devices - Edit Notifications] for instruction to set Notifications on the devices.
The following notification services are supported:
  • Prowl (iPhone/iPad)
  • IFTTT
  • NMA (Android)
  • PushBullet
  • Pushsafer (iOS/Android/Windows10/Chrome/Firefox) + Image
  • Pushover (Android/iOs)
  • Pushalot (Windows/Windows Phone)
  • Clickatell SMS
  • Custom HTTP/Action
  • Kodi Media Player
  • Logitech Media Server
  • Google Cloud Messaging
  • Telegram
The services settings the notification Intervals can be set for sensors and switches. Notification systems can be configured in the Menu Setup -> Settings
Configuring IFTTT
When you are logged in at IFTTT, visit https://ifttt.com/maker_webhooks
Next press the Connect button, and after being connected, click Documentation, and copy the API/Key and paste this in Domoticz under Settings->Notifications->IFTTT
Also enable IFTTT here and Apply Settings
For more info see wiki page IFTTT integration with Domoticz
To receive notifications from Domoticz server with the Android Domoticz app you need to setup a project. For this got to wiki page Firebase setup
NOTE: Google Cloud Messaging with all stable Domoticz versions stopped working from december 2025. This is fixed in Domoticz 2025.2 beta (20-jan-2026) or newer and latest Android Domoticz App 0.2.386 (11 jan 2026) or newer. So you need to update both before able to configure and use Google cloud messaging again in Domoticz.
Configuring Telegram
See the following wiki page: Telegram notification
Configuring Telegram Bot with Custom HTTP/Action
See the following wiki page: Telegram Bot#Setting Domoticz to Use Telegram Bot Nofications
Configuring PushBullet
  • Get your API key with PushBullet ; you can find the link from Domoticz > Settings > Notifications.
  • Set your API into Domoticz at the same location and SAVE your changes
  • Select your device (lights, sensor, custom) and click Notifications ; you therefore have to select Pushpullet and the trigger you want to receive the notification.
  • Install the pushbullet app on your smartphone
Configuring Clickatell SMS
See the following wiki page: SMS Notifications
Configuring Custom HTTP/Action
Please note that when using a script, the script name/path cannot contain the words import, socket or os
For an example, see the following wiki page: Telegram Bot#Setting Domoticz to Use Telegram Bot Nofications
Configuring Kodi Media Player
See the following wiki page: Kodi#On_Screen_Notifications
Configuring Pushover
To connect Pushover to Domoticz, you need two things:
  • A user key, which can be found on the Pushover website as soon as you have logged in
  • An API-key. This can be made by filling in this wizard: https://pushover.net/apps/build
Fill in both the keys into the correct fields inside Domoticz ( Menu Settings), and the Pushover notifications should be working.
Configuring Pushsafer
To connect Pushsafer to Domoticz, you need a private or alias key from https://www.pushsafer.com:
  • A private or alias key, which can be found on the Pushsafer website as soon as you have logged in
  • private key > send the notification to all devices with standard notification parameter
  • alias key > send the notification to the devices stored in the alias with predefined parameter
Fill in the key into the correct field inside the Domoticz notification settings ( Menu Settings), and the Pushsafer notifications should be working.
Optionally you can send an image with the push-notification. Simply add an absolute image url, e.g. from an ip camera or a door bell.
Example Image-URL: http://user:[email protected]:8080/snapshot.cgi
Advanced Pushsafer configuration
To customize your notification to your fit, you can enter Pushsafer parameters in the "Custom Message" field.
The following parameters are available and must always be entered separately in this order by a PIPE character.
The domoticz priority parameter is passed with the pr parameter of Pushsafer.
PrivateOrAliasKey|DeviceID|Icon|Sound|Vibration|Title|Message|ImageURL|URL|URLTitle|Time2Live|Retry|Expire|Answer
Examples
YourPrivateOrAliasKey|269|82|6|3|Domoticz|Switch on|http://user:[email protected]:8080/snapshot.cgi|http://www.pushsafer.com|Open Pushsafer|1000|60|600|1
YourPrivateOrAliasKey||83|7|1|Domoticz|Switch off|http://user:[email protected]:8080/snapshot.cgi||||||
Pushsafer Domoticz: https://www.pushsafer.com/en/domoticz
Pushsafer HowTo: https://www.pushsafer.com/en/howto
Pushsafer API: https://www.pushsafer.com/en/pushapi
Notifications to PC with Snarl
Snarl is a great notification system for events like low diskspace, IM events, played music, time, anything you can think of!
Notifications to Snarl on your desktop or laptop only work on your local network, that is, the network in where Domoticz runs More info in the following Wiki page: Notifications to PC with Snarl
