Docker
Introduction
You can also install Domoticz as a Docker container. Using a Docker container gives you ease in the configuration and requirements of your system. No dependencies on libraries, Python versions etc.
Also some frequently used hardware gateways like Zigbee2MQTT and Zwave-JS-UI (and their interface Mosquitto MQTT) can run in separate Docker containers.
Using Docker with Domoticz will require some general knowledge how to use and maintain Docker environments. See for example https://docs.docker.com/get-started/docker-concepts/running-containers/publishing-ports/
It is important to understand that docker containers work with volumes. Volumes are the folders/files that needs to be persistent. (Like the configuration)
Everything else is 'virtual'. Also understand that a docker is not a virtual machine, It does not emulate, meaning, the performance is as fast as running this natively!
Make sure you have already installed both Docker Engine and Docker Compose.
We highly recommend using 'docker-compose' as maintaining the configuration will be much easier
Install docker on a linux system
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install -y make git
curl -fsSL test.docker.com -o get-docker.sh && sh get-docker.sh
sudo usermod -aG docker ${USER}
sudo systemctl enable docker
sudo reboot
Platforms
The official docker image of Domoticz supports the following platforms
- 32 and 64 Arm
- 64 bit Linux
This should cover most platforms.
Default installation
The Docker image can be found here:
https://hub.docker.com/r/domoticz/domoticz
IMPORTANT: This website also gives the detailed instructions how to install and update the docker image based on docker compose.
Below mentioned topics are only to explain specific topics.
docker image tags
It is possible to use stable (preferred!) and beta images: https://hub.docker.com/r/domoticz/domoticz/tags
with docker pull or in the image section of the docker-compose.yml:
domoticz/domoticz:beta (will pull latest beta version)
domoticz/domoticz:stable (will pull latest stable version)
domoticz/domoticz:2022.1 (will pull latest stable version 2022.1)
domoticz/domoticz:2022-beta.12345 (will pull beta with build number 12345)
tag latest or no tag will pull the latest uploaded image, so could be a beta or stable image.
Update the Domoticz Docker Container
See also https://hub.docker.com/r/domoticz/domoticz
Docker-Compose: Use the following command in a terminal session in the directory where the docker-compose.yml is located:
docker compose pull && docker compose up --force-recreate --build -d && docker image prune -f
Domoticz Docker settings and tips
See also the basic install instructions on https://hub.docker.com/r/domoticz/domoticz
Serial Port
If you need to access a USB dongle connected to your system, we need to identify this serial device.
We do this by issuing the following command
ls /dev/serial/by-id
You should see one or multiple serial devices, find out which one is your RF stick, for example it's: usb-0658_0200-if00-port0
You need to add this device to the docker container in the docker-compose.yml like
devices:
- "/dev/serial/by-id/usb-0658_0200-if00-port0:/dev/ttyUSB0"
or in the docker startup line with
--device="/dev/serial/by-id/usb-0658_0200-if00-port0:/dev/ttyUSB0"
Ports
If you use ssl and or Device Sharing make sure those ports (eg default 443 and 6144) are enabled in your docker config
Docker Compose:
ports: - "8080:8080" - "8443:443" - "6144:6144"
or with docker run:
docker run -d -p 8080:8080 -p 8443:443 -p 6144:6144
Note: First port value is outside port, second value is inside container port (as configured in Domoticz). So for example the Domoticz configured ssl port 443 is accessible outside the container through port 8443.
custom startup script for the container
The container supports running a custom bash script (customstart.sh in userdata) before the Domoticz process starts. This way, you can customize anything in the container that you need:
- install incremental apt packages (don't forget to apt update before you apt install)
- install incremental python functions (pip3 install)
- and so on
The container calls a script named customstart.sh in userdata, if that script exists. Please note that the script gets called on EVERY start of the container, not just at creation time. If you want the script to run only once, you need to build that in your script (e.g. test for a file you create in the script).
Example script
#!/bin/bash if [ -f /opt/domoticz/FIRSTRUN ]; then true else echo 'updating packages' apt-get -qq update echo 'installing mosquitto clients' apt-get -y install mosquitto-clients echo 'installing iputils-ping' apt-get -y install iputils-ping echo 'creating FIRSTRUN file so script can check on next run' touch /opt/domoticz/FIRSTRUN echo 'copying event script templates to external mapped storage cp -r /opt/domoticz/scripts/templates /opt/domoticz/userdata/scripts cd /opt/domoticz || return fi
Python Plugins
When launching the docker container for the first time, a plugin folder is created in the mounted /opt/domoticz/userdata folder You need to place your python plugins in this folder.
The stable container runs Python 3.11.2. (current beta too)
When plugins need extra python modules you need to install those in the Docker container! Python is also setup with a venv so no need to do something special on installing the required python modules.
Use the following command to get into the docker container:
docker exec -it domoticz bash
Then go to the plugin folder and install the modules
cd /opt/domoticz/userdata/plugins/<yourpluginfolder>
sudo pip3 install -r requirements.txt
You can use the custom startup script (customstart.sh asmentioned above) to be sure the required python modules are reinstalled when you update the docker image.
Docker and dzVents
Make sure you have created the following script subfolders manually in your mounted /opt/domoticz/userdata folder if you get errors complaining about these folders:
- scripts/dzVents/generated_scripts (so from within container /opt/domoticz/userdata/scripts/dzVents/generated_scripts)
- scripts/dzVents/scripts
Latest beta 2023.1 should have these folders create at startup.
Dzvents templates:
When creating a new dzvents script the templates are empty. To repair that add the following line in the customstart.sh file or run the command after a new image deploy in the docker container:
Custom templates
If you use custom templates make sure you added a volume so the custom templates are added and not overwritten at a Domoticz update. For example add ./config/www/templates:
volumes:
- ./config:/opt/domoticz/userdata
- ./config/www/templates:/opt/domoticz/www/templates
Custom Themes
To use custom themes mount the custom style subfolder. For example for the machinon template mount ./config/www/styles/machinon:/opt/domoticz/www/styles/machinon
volumes:
- ./config/www/styles/machinon:/opt/domoticz/www/styles/machinon
IP settings in Hardware gateways
If you have to enter an URL in one of the hardware gateways setting (menu Setup - Hardware) with values like localhost or 127.0.0.1 change these into the real IP of your Domoticz server (eg 192.168.1.32).
The redirect IP's like localhost and 127.0.0.1 are directing to the IP's in the container and so not connecting to the IP of the host. The Domoticz Hardware gateways would then not find the expected services running on the server.
Dockge
If you have more docker containers next to Domotcz you can use the application Dockge, a fancy, easy-to-use and reactive self-hosted docker compose.yaml stack-oriented manager. See for more information https://github.com/louislam/dockge
Debugging
Switch on Domoticz logging to OS
Switch on logging to an OS file with Docker environment parameter LOG_PATH=/opt/domoticz/userdata/domoticz.log
With the Docker environment parameter EXTRA_CMD_ARG (see the page https://hub.docker.com/r/domoticz/domoticz) you can set additional command line parameters (see also page Command Line Parameters) for extra debugging. For example:
EXTRA_CMD_ARG= -loglevel normal,status,error,debug -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id
Shell access while the container is running
To get into the docker container to check config files or install extra software use command
Monitor the logs of the container
docker logs -f domoticz
Questions:
If you have questions about this new official Docker container, please go to the following forum topic: https://www.domoticz.com/forum/viewtopic.php?f=4&t=35454
In case you want to install a Domoticz Docker container on a Synology, please read Domoticz on a Synology NAS.
