Command line parameters
From Domoticz Wiki
Introduction
Domoticz can be started with various parameters to configure the environment. These parameters can be set in configuration files or during manual startup (eg ./domoticz -www 8080 -sslwww 443)
Parameters
The following command line parameters are available:
-version display version number
-www port (for example -www 8080)
-wwwbind address (for example -wwwbind 0.0.0.0 or -wwwbind 192.168.0.20)
-wwwroot file_path (for example D:\www or /opt/domoticz/www)
-dbase file_path (for example D:\domoticz.db or /opt/domoticz/domoticz.db)
-userdata file_path (for example D:\domoticzdata or /opt/domoticz)
-approot file_path (for example D:\domoticz or /opt/domoticz)
-webroot additional web root, useful with proxy servers (for example domoticz)
-startupdelay seconds (default=0)
-nowwwpwd (in case you forgot the webserver username/ password)
-wwwcompress mode (on=always compress [default], off=always decompress, static=no processing but try precompressed first)
-nobrowser (do not start webbrowser) (Windows Only)
-nocache (ask browser not to cache pages)
-noupdates (do not use the internal update functionality)
-nomdns (disables mDNS service to <domoticz instance name>.local)
-dbase_disable_wal_mode (2021.1 beta, Database journal mode switch from WAL (write ahead) to DELETE)(Windows only)
-log file_path (for example D:\domoticz.log or /tmp/domoticz.txt)
-loglevel level_string (combination of: all,normal,status,error,debug)
-loglevel level_num (addition of: 1=normal, 2=status, 4=error, 8=debug)(-loglevel debug has to be set to display debug messages)
-debuglevel level_string (combination of: all,normal,hardware,received,webserver,eventsystem,python,thread_id,sql)(-loglevel debug has to be set to enable debug)
-debuglevel level_num (addition of: 1=normal, 2=hardware, 4=received, 8=webserver, 16=eventsystem, 32=python, 64=threadids, 128=sql)(-loglevel debug has to be set to enable debug)
-notimestamps (do not prepend timestamps to logs; useful with syslog, etc.)
-php_cgi_path (for example /usr/bin/php-cgi)
-daemon (run as background daemon)(Unix Only)
-pidfile pid file location (for example /var/run/domoticz.pid)(Unix Only)
-syslog [user|daemon|local0 .. local7] (use syslog as log output, defaults to facility 'user')(Unix Only)
-f config_file (for example /etc/domoticz.conf)(Unix Only) Easy for debugging, a sample config file can be found in link
-weblog file_path (for example /var/log/domoticz_access.log) Creates Apache Combined Logformat logs containg all webrequests. (Beta)
  • NOTE for Raspberry PI users: Generating these logfiles means constant writing to the filesystem. When running Domoticz on a Raspberry Pi off a SD-card, this logging feature can really cause a lot of wear on such a card and shorten the lifespan of these cards. If you want to get these logs even when running on a Pi, either attach a separate (USB) harddrive to write to. Or have the logging forwarded to another machine using syslog. This can be done by specifying 'syslog:' as the 'weblog file'. But this only works when you enabled syslog for the other logging as well! See the -syslog commandline option.
If Domoticz is compiled with SSL support:
-sslwww port (for example -sslwww 443, or -sslwww 0 to disable https)
-sslcert file_path (for example /opt/domoticz/server_cert.pem)
-sslkey file_path (if different from certificate file)
-sslpass passphrase (to access to server private key in certificate)
-sslmethod method (supported methods: tlsv1, tlsv1_server, sslv23, sslv23_server, tlsv11, tlsv11_server, tlsv12, tlsv12_server)
-ssloptions options (for SSL options, default is 'default_workarounds,no_sslv2,no_sslv3,no_tlsv1,no_tlsv1_1,single_dh_use')
-ssldhparam file_path (for SSL DH parameters)
If no –sslcert parameter is provided, Domoticz will use server_cert.pem from its installation folder
Unix Deamon configuration
The above mentioned command can be added to the domoticz.service file when using systemd (more recent systems), edit the line ExecStart=/home/domoticz/domoticz/domoticz -www 8080 -sslwww 443
See for instructions page Installation Linux
For older systems still using init.d the above mentioned command line parameters can be added as DEAMON_ARGS in /etc/init.d/domoticz.sh.
Python plugin environment
In the context of embedded Python in C++ code, PYTHONPATH is an environment variable that specifies the directories where Python looks for modules and packages. It plays a crucial role in ensuring your embedded Python code can locate and import the required Python modules.
Key Uses of PYTHONPATH:
  1. Module Discovery: When your embedded Python code executes an import statement, Python searches for the module in directories listed in PYTHONPATH, in addition to the standard library paths.
  1. Custom Module Locations: If your project includes custom Python modules or packages that are not installed in the standard Python library directories, you can add their paths to PYTHONPATH to make them accessible.
  1. Isolation of Dependencies: You can use PYTHONPATH to point to a specific directory containing dependencies, ensuring your embedded Python environment is isolated and predictable.
  1. Debugging and Testing: During development, you might use PYTHONPATH to include paths for testing modules or different versions of libraries.
Docker environment values
You can use these command line parameters also as Environment values when using EXTRA_CMD_ARG. See also Docker page https://hub.docker.com/r/domoticz/domoticz
Windows Domoticz startup parameters:
For new installations or update of current installations the decision to use an external logfile and the full qualified filename of that logfile is done during the installation dialogue.
For adding other command line parameters (including log file without the need for reinstalling) take the following steps:
  1. When running as a service change regkey HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Domoticz\Parameters . Add value AppParameters with the command line parameters eg: -log "<Path-to-logfile\domoticz.log>"
  2. When running as an app define it in the target field of the Domoticz properties window (right click on Icon). Something like C:\Users\Public\Domoticz\domoticz.exe -www 8080 -sslwww 443 -log "C:\Users\Public\Domoticz\domoticz.log" -loglevel normal,status,error
