Intergas Incomfort Heater control
From Domoticz Wiki
Revision as of 22:02, 19 June 2025 by Walter vl (talk | contribs)
To connect the Intergas Incomfort LAN2RF Gateway, Domoticz includes standard support for the Incomfort.
From version 2022.2 the thermostat setting also works with the V2 gateway.
Prerequisites
Make sure the Gateway, app and thermostat work as they should, then you can get started with Domoticz.
Configure Domoticz
Navigate to Settings -> Hardware
Choose "Intergas InComfort LAN2RF Gateway as Type" and fill in the appropiate fields:
  • Name For example, type "Intergas InComfort"
  • Data Timeout: "Disabled".
  • IP address: IP address of the LAN2RF Gateway under Remote address.
  • port: default 80
  • username: admin
  • password: The password that is shown on the back of your gateway. (which you can change via the web interface if you point your browser at the IP address of the gateway)
Once Domoticz has successfully established contact with the gateway, it will automatically create all devices.
Under Settings -> Devices, there are now 10 new devices. Click on the green arrows to add the devices to your overview.
You can then adjust the names to what makes sense to you (as has already been done below)
After this, you can simply operate the thermostat (the setpoint device)
The setpoint device is sometimes set to 0 by the real thermostat or the app, which makes it unusable in domoticz.
So set it to NOT ACTIVE (see the green arrow behind the device)
