Intergas Incomfort Heater control
From Domoticz Wiki
Revision as of 21:55, 19 June 2025 by Walter vl (talk | contribs) (Created page with "To connect the Intergas Incomfort LAN2RF Gateway, Domoticz includes standard support for the Incomfort. From version 2022.2 the thermostat setting also works with the V2 gateway. Make sure the Gateway, app and thermostat work as they should, then you can get started with Domoticz. Navigate to Settings -> Hardware Choose Intergas InComfort LAN2RF Gateway at the bottom under Type For example, type "Intergas InComfort" under name Set data Timeout to "not active". E...")
Enter the IP address of the LAN2RF Gateway under Remote address.
Then enter port, username and password
Once Domoticz has successfully established contact with the gateway, it will automatically create all devices.
Under Settings -> Devices, there are now 10 new devices. Click on the green arrows to add the devices to your overview.
You can then adjust the names to what makes sense to you (as has already been done below)
After this, you can simply operate the thermostat (the setpoint device)
The setpoint device is sometimes set to 0 by the real thermostat or the app, which makes it unusable in domoticz.
So set it to NOT ACTIVE (see the green arrow behind the device)
