1Wire
From Domoticz
Revision as of 11:01, 30 November 2022 by Walter vl (talk | contribs)
1-Wire is a device communications bus system designed by Dallas Semiconductor Corp. that provides low-speed (16.3 kbit/s) data, signaling, and power over a single conductor.
Domoticz supports 1-Wire devices directly connected to the gpio of the Raspberry Pi or Windows system with serial adapter that runs Domoticz.
Setup
Windows
First Stop Domoticz
Download and install the OneWireDomoticzServiceInstaller.msi from here
With a serial adapter, update the OneWireDomoticzServiceConfig.xml in the OneWireDomoticzService installation directory (usually C:\Program Files (x86)\Domoticz\OneWireDomoticzService), with this content (update adapter name and COM port with your values), and restart the service :
<OneWireDomoticzServiceConfig>
  <adapter name="{DS9097U_DS948X}" port="COM1"/>
</OneWireDomoticzServiceConfig>
Supported adapter names are : {DS9097E}, {DS9097U_DS948X}, {DS9490}, NetAdapter
USB DS9490 adapter should be auto discovered, it doesn't need the OneWireDomoticzServiceConfig.xml file.
Restart Domoticz
Linux
There are two methods to use 1-Wire devices
w1-gpio/w1-therm
Follow this guide to connect and install 1-Wire support
How to Setup 1-Wire
When the above is working, do not forget to include the two modules in /etc/modules, otherwise after the next reboot it is not working anymore.
sudo vi /etc/modules
Add the following two modules (on separate lines):
w1-gpio
w1-therm
Restart domoticz, and 1-wire support should now be detected, and you are able to add a new hardware device (1-Wire)
Note: When using GPIO, set OWFS Path to nothing. After adding 1-wire (system) the sensors will eventually show up in the log.
OWFS
Follow this guide to connect and install OWFS - 1-Wire support
How to Setup OWFS
Make sure everything works as it should by checking the contents of the 1wire folder or by reading a sensor: (Change path according to your sensor id)
cat /mnt/1wire/10.F6877C010800/temperature
Note: to be detected by Domoticz, the 1-wire filesystem must be mounted as /mnt/1wire
Disable 1-wire
Add this line to crontab (sudo crontab -e):
@reboot sudo rmmod w1_gpio
Add 1-Wire Hardware Gateway
After 1-wire system is working on your system you can add id to Domoticz:
Go to menu Setup -> Hardware
Select type: 1-Wire (system)
Enter a Name eg: 1-Wire
OWFS Path: Enter path starting with /mnt/1wire Leave empty when using w1-gpio/w1-therm method!!
Modify Sensor and switch Poll Periods to your need.
Click on Add to add the Hardware. Domoticz will create the connected 1-Wire devices.
They will show up in the devices list (menu Setup -> Devices) and need to be activated in domoticz (click on green arrow) to be shown in the devices tabs (switches, temperature etc).
