Timer Plan
From Domoticz Wiki
Revision as of 13:49, 26 April 2021 by Walter vl (talk | contribs)
With timer plans you can setup a specific set of timed devices for example: Setup a lighting schedule when on Holidays.
Default there is a Normal and a Holiday Timer. In Settings the active Timer plan schedule should be set to Normal.
In short the actions are:
  1. Create a timer plan (Setup - More Options - Plans - Timer Plan). Refresh the Page (F5) if empty. If you are already have timers created and you want to reuse/modify these timers in the new Timer Plan you can use the Duplicate button after selecting the source Timer Plan.
2. Activate the new Timer Plan in Setup - Settings - tab Other
3. Add/Edit timers per device/light. They will be added to the new created and active Timer Plan.
When you want to activate another Timer Plan activate it in Setup - Settings - tab Other.
Tip: List all timers of devices in the active timerplan:
http://<domoticz IP:domoticz PORT>/json.htm?type=schedules&filter=device
All the timers of a specific device
http://<domoticz IP:domoticz PORT>/json.htm?idx=<device ID>&type=timers
or
http://<domoticz IP:domoticz PORT>/json.htm?idx=<device ID>&type=setpointtimers
