Domoticz version table V2020.1
From Domoticz Wiki
Revision as of 09:07, 20 October 2020 by Rwaaren (talk | contribs) (Rwaaren moved page DzVents version table V2020.1 to Domoticz version table V2020.1 without leaving a redirect)
Version table V2020.1
Build Commit Date Type Description
11992 afb1358d2 20200426 Update Updating History
11991 96baa78b6 20200426 Build Making revisions start from 1 allowed
11989 4d558c1cf 20200426 Update Merge PR 4102 from HoekieN; removed reference to old name of new updateControler
11987 214d411a 20200426 Translations Updated Translations
11986 cf4a18a6d 20200426 OpenZWave Update OpenZWave configuration files
11985 f14419249 20200426 Security Extra access check
11984 311e2c634 20200425 TTNMQTT Merge PR 4100 from kiddigital; Fix PR 4085 where GPS data was not stored
11982 114297520 20200425 Buienradar Fix for possible crash caused by old configuration parameter
11981 eef3826d7 20200424 mySensors Fix for issue 4088 and issue 4091; Prevent crash. Thanks to bmellink.
11980 e1109f9bb 20200424 Buienradar Allow to enter either Station_ID or Lat/Lon on location field (hardware tab)
11979 d9a75c19d 20200424 Buienradar Merge PR 4084 from akamming; Option to choose station ID in buienradar
11970 2da8b25ad 20200423 GUI Merge PR 3993 from rklomp; Correcting report headers for energy generation
11967 c08976251 20200423 TTNMQTT Merge PR 4085 from kiddigital; improved handling CayenneLPP channels and other areas. See cayennelpp
11962 bb9bf4d85 20200423 Icon Merge PR 4089 from waaren/; Allow changing icon for Home Confort types
11960 077531af3 20200422 PVoutput Use logcounter since start and remember consumption status
11959 e07e74975 20200422 Logging Do not add to LightingLog if state has not changed
11958 0014f2941 20200422 Cleanup Code cleanup
11957 6a6accbb2 20200421 Update Correct name of new version update controller
11956 7c5d8c12d 20200421 Notifications Fix for notifications testfacility in setup tab
11955 a9623b444 20200421 Database Speeding up initial database creation
11954 55f5eef3d 20200421 GUI Fix for issue 4065 Unwanted RFY protection popup
11953 0ba963236 20200421 Update Implement new version update controller
11952 1986557fd 20200420 Notifications Actual response/error checking for notifications to PushOver
11951 42b506046 20200420 Notifications Allow subsystem parm to be empty or a space
11950 b4c5e6643 20200420 Notifications Only replace message with space when message field is empty.
11949 5224e0b23 20200420 Daikin Correcting log output path
11948 fd0c63e45 20200420 Notifications Only send notifications to enabled systems
11947 f0e51f332 20200420 OctoPrint Prevent text-sensor flooding. (only update when state changed)
11946 1227bcf33 20200416 Icon Merge PR 4082 from waaren; Allow changing icon for Lighting 6 types
11944 52674382e 20200415 Wunderground Merge PR 4079 from mantoz; Query changed to get wind-/gust unit m/s and JSON data to 'metric_si'
11940 44a1e9c5b 20200414 Network Reverted b71a76815 because message does not show the expected information
11939 ab6c15e67 20200414 Main Prevent possible crash caused by time not being set yet at domoticz startup (thanks to rkluwen!)
11938 b71a76815 20200414 Network Complete parsing http request fail message with request string
11937 45e8edd76 20200414 Xiaomi Merge PR 4078 from Huupke; Fix for issue 4078 Dual button bug
11935 3eb334008 20200413 Daikin Simplify debug to log / debug to OS file
11934 6acbb6258 20200413 Build Windows Release build now use dynamic libraries
11933 642989545 20200413 OpenZWave OpenZWave fix for battery issue
11932 df495f539 20200410 GUI Merge PR 4066 from kovainfo; Fix typo on dashboard page
11930 423448b7e 20200410 Notifications Add check for result of notification to Firebase Cloud Messaging
11928 64caf9a91 20200409 dzVents Add support for Firebase Cloud Messaging
11925 87bad52e2 20200409 Notifications Google Cloud - to Firebase Cloud Messaging and changed mechanism
11924 1fb2c1e80 20200408 Notifications Add default sound for iOS in Firebase
11923 59f8319f2 20200408 dzVents Fix for internal editor templates and examples and protect notify
11922 655b0cc4e 20200407 Build Ignore submodules in git status request
11921 01332c708 20200407 MQTT Add option to enable/disable loop prevention
11920 c58575a4f 20200407 EventSystem Fix for battery level updates
11919 dcfa0eb84 20200407 Build Merge PR 4058 from xbeaudouin Add check for MQTT and SQLite in cmake
11899 74e49c588 20200406 dzVents Fix moduleName in error message
11898 a9857e420 20200406 dzVents Add missing constant EVENT_TYPE_HTTPRESPONSE
11897 05262f143 20200406 OpenZWave Update OpenZWave configuration files
11896 390d7b9ff 20200405 Build Update find of Lua package, Fix external JSONCPP library linking
11895 553c17615 20200404 Build Fix Appveyor compile issue (4053)
11894 54d12c6f7 20200404 Build Update Appveyor project file
11893 ac4737c5c 20200404 OpenWebNet MergePR 4051 from Spugna85; update SQLHelper
11890 a9da5aee8 20200404 Build Use external library again to speed up build process on Windows
11887 496db7148 20200404 EventSystem Initialize trigger pointer in structure
11886 1bce2493c 20200404 EventSystem Add battery-level to UpdateSingleState
11885 ea19237f3 20200404 Build Fix C++20 compile warnings
11884 a81945095 20200404 OpenZWave Ignore listening state
11883 3baaa6712 20200403 dzVents Improve check for numeric value in .afterXX() and .at()
11875 8c5c9826f 20200403 Build Fix compile warning
11874 cb07eba9b 20200403 OpenZWave Update OpenZWave library (Windows)
11873 [a8f209398 20200403 Database Merge PR 4042 from gizmocuz; combine pusher tables into one and fix device delete
11867 cec081f2c 20200403 GUI Update translations
11866 25e096963 20200403 OpenZWave Update OpenZWave configuration files
11865 59eaf69c8 20200403 Build Appveyor building VCPKG packages again (does not seem to work from the cache)
11864 1aad3ed17 20200403 Build Remove wrong compiler flag, added dynamic flag for LUA
11863 d2f9d0fe4 20200403 Build Disable VCPKG packages generation as it's stored in the cache
11862 7e606aeb1 20200402 GUI Merge PR 4033 from stas-demydiuk; implement auto-refresh of logs on device and scene update
11860 bae36450b 20200402 GUI Merge PR 4034 from cocooma; Fix time zone in Temperature tab
11858 db00d658e 20200402 Hardware Merge PR 4038 from huupke; Simplify xiaomi methods
11857 275effddf 20200402 Build Merge PR 4044 from gizmocuz; Removing external library dependencies from the source tree
11856 835fd0168 20200402 dzVents Fix moduleLabel. Moved from _G to domoticz object
11853 cc1a38a4e 20200331 Python Merge PR 4032 from hamshiva; Fix segfault on Python plugin stop
11851 dbd7cddcd 20200331 Hardware Merge PR 4030 from Huupke; Cleanup Xiaomi Gateway code and prepare for 2 new devices
11844 5575b9462 20200331 Hardware Merge PR 4031 from Spugna85; Fix for OpenWebNet blind update status
11842 fcc7b6443 20200331 Build Merge branch 'development' of github.com:domoticz/domoticz into development (align branches)
11840 2b499545a 20200331 dzVents Update dzVents to 3.0.2 Add openURL PUT and DELETE support
11839 139d994e5 20200327 Hardware Merge PR 4016 Fix multiple Daikin bug corrections
11838 372611b76 20200326 Hardware Merge PR 4015 from dwmw2; Fix for Evohome fault log date handling
11836 7e0c5045a 20200325 GUI Temporary fix for issue 4012 Darksy does no longer allow displaying its weather forecast in a frame
11835 d93f467a7 20200323 Build Merge PR 4006 from domoticz; Fix for Lua includes
11833 684cfac0a 20200323 GUI Add Beta build in about page and in version JSON
11832 77b93f111 20200322 Build Fix Compile warnings
