Domoticz version table V2020.1
Jump to navigation
Jump to search
Version table V2020.1
Build | Commit | Date | Type | Description |
11992 | afb1358d2 | 20200426 | Update | Updating History |
11991 | 96baa78b6 | 20200426 | Build | Making revisions start from 1 allowed |
11989 | 4d558c1cf | 20200426 | Update | Merge PR 4102 from HoekieN; removed reference to old name of new updateControler |
11987 | 214d411a | 20200426 | Translations | Updated Translations |
11986 | cf4a18a6d | 20200426 | OpenZWave | Update OpenZWave configuration files |
11985 | f14419249 | 20200426 | Security | Extra access check |
11984 | 311e2c634 | 20200425 | TTNMQTT | Merge PR 4100 from kiddigital; Fix PR 4085 where GPS data was not stored |
11982 | 114297520 | 20200425 | Buienradar | Fix for possible crash caused by old configuration parameter |
11981 | eef3826d7 | 20200424 | mySensors | Fix for issue 4088 and issue 4091; Prevent crash. Thanks to bmellink. |
11980 | e1109f9bb | 20200424 | Buienradar | Allow to enter either Station_ID or Lat/Lon on location field (hardware tab) |
11979 | d9a75c19d | 20200424 | Buienradar | Merge PR 4084 from akamming; Option to choose station ID in buienradar |
11970 | 2da8b25ad | 20200423 | GUI | Merge PR 3993 from rklomp; Correcting report headers for energy generation |
11967 | c08976251 | 20200423 | TTNMQTT | Merge PR 4085 from kiddigital; improved handling CayenneLPP channels and other areas. See cayennelpp |
11962 | bb9bf4d85 | 20200423 | Icon | Merge PR 4089 from waaren/; Allow changing icon for Home Confort types |
11960 | 077531af3 | 20200422 | PVoutput | Use logcounter since start and remember consumption status |
11959 | e07e74975 | 20200422 | Logging | Do not add to LightingLog if state has not changed |
11958 | 0014f2941 | 20200422 | Cleanup | Code cleanup |
11957 | 6a6accbb2 | 20200421 | Update | Correct name of new version update controller |
11956 | 7c5d8c12d | 20200421 | Notifications | Fix for notifications testfacility in setup tab |
11955 | a9623b444 | 20200421 | Database | Speeding up initial database creation |
11954 | 55f5eef3d | 20200421 | GUI | Fix for issue 4065 Unwanted RFY protection popup |
11953 | 0ba963236 | 20200421 | Update | Implement new version update controller |
11952 | 1986557fd | 20200420 | Notifications | Actual response/error checking for notifications to PushOver |
11951 | 42b506046 | 20200420 | Notifications | Allow subsystem parm to be empty or a space |
11950 | b4c5e6643 | 20200420 | Notifications | Only replace message with space when message field is empty. |
11949 | 5224e0b23 | 20200420 | Daikin | Correcting log output path |
11948 | fd0c63e45 | 20200420 | Notifications | Only send notifications to enabled systems |
11947 | f0e51f332 | 20200420 | OctoPrint | Prevent text-sensor flooding. (only update when state changed) |
11946 | 1227bcf33 | 20200416 | Icon | Merge PR 4082 from waaren; Allow changing icon for Lighting 6 types |
11944 | 52674382e | 20200415 | Wunderground | Merge PR 4079 from mantoz; Query changed to get wind-/gust unit m/s and JSON data to 'metric_si' |
11940 | 44a1e9c5b | 20200414 | Network | Reverted b71a76815 because message does not show the expected information |
11939 | ab6c15e67 | 20200414 | Main | Prevent possible crash caused by time not being set yet at domoticz startup (thanks to rkluwen!) |
11938 | b71a76815 | 20200414 | Network | Complete parsing http request fail message with request string |
11937 | 45e8edd76 | 20200414 | Xiaomi | Merge PR 4078 from Huupke; Fix for issue 4078 Dual button bug |
11935 | 3eb334008 | 20200413 | Daikin | Simplify debug to log / debug to OS file |
11934 | 6acbb6258 | 20200413 | Build | Windows Release build now use dynamic libraries |
11933 | 642989545 | 20200413 | OpenZWave | OpenZWave fix for battery issue |
11932 | df495f539 | 20200410 | GUI | Merge PR 4066 from kovainfo; Fix typo on dashboard page |
11930 | 423448b7e | 20200410 | Notifications | Add check for result of notification to Firebase Cloud Messaging |
11928 | 64caf9a91 | 20200409 | dzVents | Add support for Firebase Cloud Messaging |
11925 | 87bad52e2 | 20200409 | Notifications | Google Cloud - to Firebase Cloud Messaging and changed mechanism |
11924 | 1fb2c1e80 | 20200408 | Notifications | Add default sound for iOS in Firebase |
11923 | 59f8319f2 | 20200408 | dzVents | Fix for internal editor templates and examples and protect notify |
11922 | 655b0cc4e | 20200407 | Build | Ignore submodules in git status request |
11921 | 01332c708 | 20200407 | MQTT | Add option to enable/disable loop prevention |
11920 | c58575a4f | 20200407 | EventSystem | Fix for battery level updates |
11919 | dcfa0eb84 | 20200407 | Build | Merge PR 4058 from xbeaudouin Add check for MQTT and SQLite in cmake |
11899 | 74e49c588 | 20200406 | dzVents | Fix moduleName in error message |
11898 | a9857e420 | 20200406 | dzVents | Add missing constant EVENT_TYPE_HTTPRESPONSE |
11897 | 05262f143 | 20200406 | OpenZWave | Update OpenZWave configuration files |
11896 | 390d7b9ff | 20200405 | Build | Update find of Lua package, Fix external JSONCPP library linking |
11895 | 553c17615 | 20200404 | Build | Fix Appveyor compile issue (4053) |
11894 | 54d12c6f7 | 20200404 | Build | Update Appveyor project file |
11893 | ac4737c5c | 20200404 | OpenWebNet | MergePR 4051 from Spugna85; update SQLHelper |
11890 | a9da5aee8 | 20200404 | Build | Use external library again to speed up build process on Windows |
11887 | 496db7148 | 20200404 | EventSystem | Initialize trigger pointer in structure |
11886 | 1bce2493c | 20200404 | EventSystem | Add battery-level to UpdateSingleState |
11885 | ea19237f3 | 20200404 | Build | Fix C++20 compile warnings |
11884 | a81945095 | 20200404 | OpenZWave | Ignore listening state |
11883 | 3baaa6712 | 20200403 | dzVents | Improve check for numeric value in .afterXX() and .at() |
11875 | 8c5c9826f | 20200403 | Build | Fix compile warning |
11874 | cb07eba9b | 20200403 | OpenZWave | Update OpenZWave library (Windows) |
11873 | [a8f209398 | 20200403 | Database | Merge PR 4042 from gizmocuz; combine pusher tables into one and fix device delete |
11867 | cec081f2c | 20200403 | GUI | Update translations |
11866 | 25e096963 | 20200403 | OpenZWave | Update OpenZWave configuration files |
11865 | 59eaf69c8 | 20200403 | Build | Appveyor building VCPKG packages again (does not seem to work from the cache) |
11864 | 1aad3ed17 | 20200403 | Build | Remove wrong compiler flag, added dynamic flag for LUA |
11863 | d2f9d0fe4 | 20200403 | Build | Disable VCPKG packages generation as it's stored in the cache |
11862 | 7e606aeb1 | 20200402 | GUI | Merge PR 4033 from stas-demydiuk; implement auto-refresh of logs on device and scene update |
11860 | bae36450b | 20200402 | GUI | Merge PR 4034 from cocooma; Fix time zone in Temperature tab |
11858 | db00d658e | 20200402 | Hardware | Merge PR 4038 from huupke; Simplify xiaomi methods |
11857 | 275effddf | 20200402 | Build | Merge PR 4044 from gizmocuz; Removing external library dependencies from the source tree |
11856 | 835fd0168 | 20200402 | dzVents | Fix moduleLabel. Moved from _G to domoticz object |
11853 | cc1a38a4e | 20200331 | Python | Merge PR 4032 from hamshiva; Fix segfault on Python plugin stop |
11851 | dbd7cddcd | 20200331 | Hardware | Merge PR 4030 from Huupke; Cleanup Xiaomi Gateway code and prepare for 2 new devices |
11844 | 5575b9462 | 20200331 | Hardware | Merge PR 4031 from Spugna85; Fix for OpenWebNet blind update status |
11842 | fcc7b6443 | 20200331 | Build | Merge branch 'development' of github.com:domoticz/domoticz into development (align branches) |
11840 | 2b499545a | 20200331 | dzVents | Update dzVents to 3.0.2 Add openURL PUT and DELETE support |
11839 | 139d994e5 | 20200327 | Hardware | Merge PR 4016 Fix multiple Daikin bug corrections |
11838 | 372611b76 | 20200326 | Hardware | Merge PR 4015 from dwmw2; Fix for Evohome fault log date handling |
11836 | 7e0c5045a | 20200325 | GUI | Temporary fix for issue 4012 Darksy does no longer allow displaying its weather forecast in a frame |
11835 | d93f467a7 | 20200323 | Build | Merge PR 4006 from domoticz; Fix for Lua includes |
11833 | 684cfac0a | 20200323 | GUI | Add Beta build in about page and in version JSON |
11832 | 77b93f111 | 20200322 | Build | Fix Compile warnings |
