MPD & Domoticz
Introduction
MPD (and it’s client MPC) is a nice add-on for a home-automation server. It provides a MusicPlayerDaemon which is controllable by Domoticz using some virtual switches.
This guide shows the implementation on a Raspberry Pi. MPD and MPC are Linux packages. So they should run also on other Linux systems.
In that case the mpd.conf (Configuration file) has to be adapted.
Once MPD/MPC is implemented the audio signal out can be attached to a stereo amplifier for web-radio or mp3 files in combination with Domoticz switches triggered by a curl command from domoticz_main.
Example: a PIR switch is activated; a mp3 audio sound starts: “Warning, movement detected outside.”
Authors reference system
- Raspberry Pi Type B 2nd Revision
- Domoticz stable 1.1680 and 1.1803 beta // new: 3.8153
- External USB audio sound card C-media 7.1
CPU usage is about 1-3% during normal operation with Domoticz only.
CPU usage is about 13-14% with MPD working on a web-radio-stream and Domoticz running.
External audio device
On the authors system it was not possible to use analog audio out (3.5mm).
With running Domoticz some seconds after starting an audio-stream via ALSA / analogue-out the SSH connection, MPD/MPC and Domoticz goes offline and stops working.
A reboot by unplug/plug of power was necessary. There is a collision when using the ALSA audio driver and the internal audio system.
Therefore it is strongly recommended before implementation of MPD/MPC.
* Save the domoticz.db
* Make a back-up image of the SD card
The ALSA web-page [1] http://www.alsa-project.org/main/index.php/Main_Page provides a lot of compatible devices.
Anyway the author uses a cheap (7,50€) device from Amazon. Sometimes it’s available for 2$. Could be that many USB audio devices are compatible, even if listed or not.
Plug-in the external audio device only when the Raspberry Pi is powered off! It will be recognized automatically after booting.
Preparation
Installation
Login via Putty. It is strongly recommended to update/upgrade! The latest version of MPD/MPC needs an actual system.
sudo su cd sudo service domoticz.sh stop sudo apt-get update sudo apt-get upgrade sudo shutdown –h now
- Remove power
- Plug-in the external audio device
- Power on your Raspberry
- Wait until the Raspberry Pi has boot completely.
sudo su cd sudo service domoticz.sh stop sudo apt-get install mpd mpc alsa-utils sudo reboot
sudo su cd aplay –l
You should see the external audio device as “card1”.
The author is not sure, in German language: “Karte1”
aplay –L
The output depends on the USB audio card used.
Configuration
This is the most important part!
sudo nano /etc/mpd.conf
Set following parameters:
#bind_to_address
#log_file "/var/log/mpd/mpd.log"
Select group:
#group "nogroup" group "audio"
Configuration für Raspberry Pi Output: * Hw:0,0 = analog audio out 3.5mm -> collision with Domoticz!
- Hw:1,0 = external USB sound-card out 3.5mm
- Mixer-type “software” -> set volume via “mpc volume 80” = volume=80%
audio_output {
type "alsa"
name "My ALSA Device"
device "hw:1,0" # optional
# format "44100:16:2" # optional
# mixer_device "default" # optional
# mixer_control "PCM" # optional
# mixer_index "0" # optional
mixer_type "software" # optional
audio_buffer_size "2048"
Save with CTRL-o
Exit with CTRL-x
Now check if the “snd-bmc2835” is installed? (optional)
sudo nano /etc/modules
- # /etc/modules: kernel modules to load at boot time.
- # This file contains the names of kernel modules that should be loaded
- # at boot time, one per line. Lines beginning with "#" are ignored.
- # Parameters can be specified after the module name.
snd-bcm2835
Set rights:
sudo chmod g+w /var/lib/mpd/music/ /var/lib/mpd/playlists/ sudo chgrp audio /var/lib/mpd/music/ /var/lib/mpd/playlists/
Change file hosts to prevent a failure messages regarding IPV6
cd /etc sudo nano hosts
127.0.0.1 localhost #::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters 127.0.1.1 raspberrypi
Change only:
::1 localhost ip6-localhost ip6-loopback to #::1 localhost ip6-localhost ip6-loopback
“127.0.1.1 raspberrypi” could also be “127.0.1.1 Domoticzpi” (don’t change it)
Check if mpd is member ofthe group "audio"
ifconfig id mpd
cat /etc/group | grep audio
You can set the group with:
sudo usermod -aG audio mpd
Add music and playlists
1.Playing mp3 files:
Store them here: /var/lib/mpd/music
2. Playlists für Online Streams
Store them here: /var/lib/mpd/playlists
If you want to hear web-radio-streams generate a xyz.m3u or xyz.pls file:
sudo su cd cd /var/lib/mpd/playlists sudo nano radio.m3u
Place your radio streams there. Have a look at the m3u format here: [2] http://en.wikipedia.org/wiki/M3U If it is a radio stream, the first parameter has to be a “-1” as shown in the example.
Also “pls” is a possible format: [3] http://en.wikipedia.org/wiki/PLS_%28file_format%29
Example for m3u playlist (radio.m3u)
#EXTM3U #EXTINF:-1,WDR2 BL http://gffstream.ic.llnwd.net/stream/gffstream_mp3_w99a #EXTINF:-1,SWR3 http://swr.ic.llnwd.net/stream/swr_mp3_m_swr3b #EXTINF:-1,RSG http://62.27.47.60:8000/ps-radiorsg/livestream.mp3 #EXTINF:-1,Antenne Bayern Classic Rock live http://mp3channels.webradio.antenne.de/classic-rock-live #EXTINF:-1,Antenne Bayern Chillout http://mp3channels.webradio.antenne.de/chillout
Configuring the ALSA mixer
alsamixer
With the ALSA mixer you will set the basic output volume.
Select with F6 the external sound-device.
Choose the cursor position with arrow left and arrow right.
Change the output power with arrow up and arror down.
See more here: [4] http://en.wikipedia.org/wiki/Alsamixer
Testing MPD/MPC
Place a playlist like this "radio.m3u" (user = mpd) in:
/var/lib/mpd/playlist/
Plug-in a headphone or connect to your stereo.
Check all available commands with:
mpc help man mpc
Check if your playlist user is “mpd”.
sudo /etc/init.d/mpd stop mpc update sudo /etc/init.d/mpd start mpc clear mpc load radio.m3u mpc play 1
Now should hear a radio stream. If your device is the same as the authors you will see a flashing green LED. You can change to another by:
mpc play 2
Have a look at all the mpc commands especially like:
mpc clear mpc add <a web-radio-streaming address> mpc stop mpc volume 70 mpc outputs mpc lsplaylists
Configuring a playlist
Be aware! A radio-stream should not end with “.m3u” or “.pls”. This will not work within a playlist like “radio.m3u” because it is still a playlist! Use a playlist editor like Windows media player to check what streams are in a playlist.
Another and better way: if you have a play-list-web-radio-stream like the following...
http://www.antenne.de/webradio/channels/classic-rock-live.m3u
...you can extract the mp3 adress like this:
sudo su cd /var/lib/mpd/music wget http://www.antenne.de/webradio/channels/classic-rock-live.m3u sudo chown mpd classic-rock-live.m3u
Check the file content:
Now you will see the playlist "classic-rock-live.m3u". Double-click on this m3u file and you will see the stream-adress:
This adress can be placed in a "m3u" playlist like this (radio.m3u):
#EXTM3U #EXTINF:-1,Antenne Bayern Classic Rock live http://mp3channels.webradio.antenne.de/classic-rock-live #EXTINF:-1,Antenne Bayern Chillout http://mp3channels.webradio.antenne.de/chillout
If you want to change from one playlist (e.g. radio.m3u) to another:
mpc stop mpc clear mpc load classic-rock-live.m3u mpc play 1
Controlling via Domoticz
Control scripts
First setup a RAM-drive like explained here: [5] http://www.domoticz.com/wiki/Setting_up_a_RAM_drive_on_Raspberry_Pi
This is necessary to store the last output volume.
The following scripts are neccessary for:
- Volume Up
- Volume Down
- Mute / UnMute
- Radio station select
Each will be started by a Domoticz button.
Place the scripts here:
/home/pi/domoticz/scripts/radio
VolumeUP.sh
#!/bin/bash
#Volume UP
if [ -f /var/tmp/mpd_volume ]; then # check for file
old_volume=`cat /var/tmp/mpd_volume` # read old volume value
echo 50 > /var/tmp/mpd_volume # store new volume
old_volume=50
fi
if (( $old_volume < 100)) ; then # if volume < 100%
new_volume=$((old_volume+10)) # add 10%
echo $new_volume > /var/tmp/mpd_volume # store new volume
new_volume=100 # set highest value
fi
mpc -q volume $new_volume
VolumeDN.sh
#!/bin/bash
#Volume Down
old_volume=50
fi
if (( $old_volume > 0)) ; then # if volume > 0%
new_volume=$((old_volume-10)) # lower 10%
new_volume=0 # set lowest value
fi
mpc -q volume $new_volume # set mpc volume
Mute / UnMute (=toogle.sh)
#!/bin/bash
# toggle
mpc -q toggle
RockLive.sh
#!/bin/bash
old_volume=50
fi
new_volume=$old_volume
#Antenne Bayern Rock Classic Live
mpc -q play 4
Switches
Define a "Push on" button with 1sec delay for:
Volume Up Volume Down Mute/UnMute One for each radio-stream
The author used:
AC type (Lightning2) adress 1 01 01 01 1 to 8
Clearing RAM cache
Since some cache is needed for buffering it could be that to much usage will cause a problem with domoticz or other applications running on the same system when remaining RAM is to low. Therefore it is recommended to clear the cache after stopping MPD and/or using a cronjob from time to time. The author starts a "cache-delete" script named "free-mem.sh" when shutting off MPD and the power amplifier. Therefore add following script in your "/home/pi/domoticz/scripts" folder:
#!/bin/bash
free -m
sync
sudo echo 3 > /proc/sys/vm/drop_caches
free -m
Also it is a good idea to start the script from the cronjob:
30 6,23 * * * /home/pi/domoticz/scripts/free-mem.sh
The cache will be deleted according to this example at 6:30 and 23:30 every day.
Useful links
ALSA: [6] http://www.alsa-project.org/main/index.php/Main_Page
m3u: [7] http://en.wikipedia.org/wiki/M3U
pls: [8] http://en.wikipedia.org/wiki/PLS
MPD: [9] http://www.musicpd.org/
MPC: [10] http://linux.die.net/man/1/mpc
