MPD & Domoticz
From Domoticz
Introduction
MPD (and it’s client MPC) is a nice add-on for a home-automation server. It provides a MusicPlayerDaemon which is controllable by Domoticz using some virtual switches.
This guide shows the implementation on a Raspberry Pi. MPD and MPC are Linux packages. So they should run also on other Linux systems.
In that case the mpd.conf (Configuration file) has to be adapted. Once MPD/MPC is implemented the audio signal out can be attached to a stereo amplifier for web-radio or mp3 files in combination with Domoticz switches triggered by a curl command from domoticz_main.
Example: a PIR switch is activated; a mp3 audio sound starts: “Warning, movement detected outside.”
Authors reference system
  • Raspberry Pi Type B 2nd Revision
  • Domoticz stable 1.1680 and 1.1803 beta // new: 3.8153
  • External USB audio sound card C-media 7.1
CPU usage is about 1-3% during normal operation with Domoticz only.
CPU usage is about 13-14% with MPD working on a web-radio-stream and Domoticz running.
External audio device
On the authors system it was not possible to use analog audio out (3.5mm).
With running Domoticz some seconds after starting an audio-stream via ALSA / analogue-out the SSH connection, MPD/MPC and Domoticz goes offline and stops working.
A reboot by unplug/plug of power was necessary. There is a collision when using the ALSA audio driver and the internal audio system.
Therefore it is strongly recommended before implementation of MPD/MPC.
* Save the domoticz.db
* Make a back-up image of the SD card
The ALSA web-page [1] http://www.alsa-project.org/main/index.php/Main_Page provides a lot of compatible devices.
Anyway the author uses a cheap (7,50€) device from Amazon. Sometimes it’s available for 2$. Could be that many USB audio devices are compatible, even if listed or not.
Plug-in the external audio device only when the Raspberry Pi is powered off! It will be recognized automatically after booting.
Preparation
Installation
Login via Putty. It is strongly recommended to update/upgrade! The latest version of MPD/MPC needs an actual system.
sudo su
cd
sudo service domoticz.sh stop
sudo apt-get update
sudo apt-get upgrade
sudo shutdown –h now
  • Remove power
  • Plug-in the external audio device
  • Power on your Raspberry
  • Wait until the Raspberry Pi has boot completely.
sudo su
cd
sudo apt-get install mpd mpc alsa-utils
sudo reboot
sudo su
cd
aplay –l
You should see the external audio device as “card1”.
The author is not sure, in German language: “Karte1”
aplay –L
The output depends on the USB audio card used.
Configuration
This is the most important part!
sudo nano /etc/mpd.conf
Set following parameters:
#bind_to_address
#log_file                       "/var/log/mpd/mpd.log"
Select group:
#group                          "nogroup"
group                           "audio"
Configuration für Raspberry Pi Output: * Hw:0,0 = analog audio out 3.5mm -> collision with Domoticz!
  • Hw:1,0 = external USB sound-card out 3.5mm
  • Mixer-type “software” -> set volume via “mpc volume 80” = volume=80%
audio_output {
       type            "alsa"
       name            "My ALSA Device"
       device          "hw:1,0"         # optional
#       format          "44100:16:2"    # optional
#       mixer_device    "default"       # optional
#       mixer_control   "PCM"           # optional
#       mixer_index     "0"             # optional
mixer_type      "software"   		  # optional
audio_buffer_size               "2048"
Save with CTRL-o
Exit with CTRL-x
Now check if the “snd-bmc2835” is installed? (optional)
sudo nano /etc/modules
  • # /etc/modules: kernel modules to load at boot time.
  • # This file contains the names of kernel modules that should be loaded
  • # at boot time, one per line. Lines beginning with "#" are ignored.
  • # Parameters can be specified after the module name.
snd-bcm2835
Set rights:
sudo chmod g+w /var/lib/mpd/music/ /var/lib/mpd/playlists/
sudo chgrp audio /var/lib/mpd/music/ /var/lib/mpd/playlists/
Change file hosts to prevent a failure messages regarding IPV6
cd /etc
sudo nano hosts
127.0.0.1	localhost
#::1		localhost ip6-localhost ip6-loopback
fe00::0		ip6-localnet
ff00::0		ip6-mcastprefix
ff02::1		ip6-allnodes
ff02::2		ip6-allrouters
127.0.1.1	raspberrypi
Change only:
::1		localhost ip6-localhost ip6-loopback to
“127.0.1.1 raspberrypi” could also be “127.0.1.1 Domoticzpi” (don’t change it)
Check if mpd is member ofthe group "audio"
ifconfig
id mpd
-> gid=29(audio)
cat /etc/group | grep audio
You can set the group with:
sudo usermod -aG audio mpd
Add music and playlists
1.Playing mp3 files:
Store them here: /var/lib/mpd/music
2. Playlists für Online Streams
Store them here: /var/lib/mpd/playlists
If you want to hear web-radio-streams generate a xyz.m3u or xyz.pls file:
sudo su
cd
cd /var/lib/mpd/playlists
sudo nano radio.m3u
Place your radio streams there. Have a look at the m3u format here: [2] http://en.wikipedia.org/wiki/M3U If it is a radio stream, the first parameter has to be a “-1” as shown in the example.
Also “pls” is a possible format: [3] http://en.wikipedia.org/wiki/PLS_%28file_format%29
Example for m3u playlist (radio.m3u)
#EXTM3U
#EXTINF:-1,WDR2 BL
http://gffstream.ic.llnwd.net/stream/gffstream_mp3_w99a
#EXTINF:-1,SWR3
http://swr.ic.llnwd.net/stream/swr_mp3_m_swr3b
#EXTINF:-1,RSG
http://62.27.47.60:8000/ps-radiorsg/livestream.mp3
#EXTINF:-1,Antenne Bayern Classic Rock live
http://mp3channels.webradio.antenne.de/classic-rock-live
#EXTINF:-1,Antenne Bayern Chillout
http://mp3channels.webradio.antenne.de/chillout
Configuring the ALSA mixer
alsamixer
With the ALSA mixer you will set the basic output volume.
Select with F6 the external sound-device.
Choose the cursor position with arrow left and arrow right.
Change the output power with arrow up and arror down.
See more here: [4] http://en.wikipedia.org/wiki/Alsamixer
Testing MPD/MPC
Place a playlist like this "radio.m3u" (user = mpd) in:
/var/lib/mpd/playlist/
#EXTM3U
#EXTINF:-1,WDR2 BL
#EXTINF:-1,SWR3
#EXTINF:-1,RSG
Plug-in a headphone or connect to your stereo.
Check all available commands with:
mpc help
man mpc
Check if your playlist user is “mpd”.
sudo /etc/init.d/mpd stop
mpc update
sudo /etc/init.d/mpd start
mpc clear
mpc load radio.m3u
mpc play 1
Now should hear a radio stream. If your device is the same as the authors you will see a flashing green LED. You can change to another by:
mpc play 2
Have a look at all the mpc commands especially like:
mpc clear
mpc add <a web-radio-streaming address>
mpc stop
mpc volume 70
mpc outputs
mpc lsplaylists
Configuring a playlist
Be aware! A radio-stream should not end with “.m3u” or “.pls”. This will not work within a playlist like “radio.m3u” because it is still a playlist! Use a playlist editor like Windows media player to check what streams are in a playlist.
Another and better way: if you have a play-list-web-radio-stream like the following...
http://www.antenne.de/webradio/channels/classic-rock-live.m3u
...you can extract the mp3 adress like this:
sudo su
cd /var/lib/mpd/music
wget http://www.antenne.de/webradio/channels/classic-rock-live.m3u
sudo chown mpd classic-rock-live.m3u
Check the file content:
Now you will see the playlist "classic-rock-live.m3u". Double-click on this m3u file and you will see the stream-adress:
This adress can be placed in a "m3u" playlist like this (radio.m3u):
#EXTM3U
If you want to change from one playlist (e.g. radio.m3u) to another:
mpc stop
mpc clear
mpc load classic-rock-live.m3u
mpc play 1
Controlling via Domoticz
Control scripts
First setup a RAM-drive like explained here: [5] http://www.domoticz.com/wiki/Setting_up_a_RAM_drive_on_Raspberry_Pi
This is necessary to store the last output volume.
The following scripts are neccessary for:
  • Volume Up
  • Volume Down
  • Mute / UnMute
  • Radio station select
Each will be started by a Domoticz button.
Place the scripts here:
/home/pi/domoticz/scripts/radio
VolumeUP.sh
 #!/bin/bash
 #Volume UP
 if [ -f /var/tmp/mpd_volume ]; then		# check for file
  old_volume=`cat /var/tmp/mpd_volume`		# read old volume value
  echo 50 > /var/tmp/mpd_volume			# store new volume
  old_volume=50
 fi
 if (( $old_volume < 100)) ; then		# if volume < 100%
 	new_volume=$((old_volume+10))		# add 10%
 	echo $new_volume > /var/tmp/mpd_volume	# store new volume
 	new_volume=100				# set highest value
 fi
 mpc -q volume $new_volume
VolumeDN.sh
 #!/bin/bash
 #Volume Down
  old_volume=50
 fi
 if (( $old_volume > 0)) ; then			# if volume > 0%
 	new_volume=$((old_volume-10))		# lower 10%
 	new_volume=0					# set lowest value
 fi
 mpc -q volume $new_volume				# set mpc volume
Mute / UnMute (=toogle.sh)
 #!/bin/bash
 # toggle
 mpc -q toggle
RockLive.sh
 #!/bin/bash
  old_volume=50
 fi
 new_volume=$old_volume
 #Antenne Bayern Rock Classic Live
 mpc -q play 4
Switches
Define a "Push on" button with 1sec delay for:
Volume Up
Volume Down
Mute/UnMute
One for each radio-stream
The author used:
AC type (Lightning2)
adress 1 01 01 01 1 to 8
Clearing RAM cache
Since some cache is needed for buffering it could be that to much usage will cause a problem with domoticz or other applications running on the same system when remaining RAM is to low. Therefore it is recommended to clear the cache after stopping MPD and/or using a cronjob from time to time. The author starts a "cache-delete" script named "free-mem.sh" when shutting off MPD and the power amplifier. Therefore add following script in your "/home/pi/domoticz/scripts" folder:
 #!/bin/bash
 free -m
 sync
 sudo echo 3 > /proc/sys/vm/drop_caches
 free -m
Also it is a good idea to start the script from the cronjob:
30 6,23 * * * /home/pi/domoticz/scripts/free-mem.sh
The cache will be deleted according to this example at 6:30 and 23:30 every day.
Useful links
ALSA: [6] http://www.alsa-project.org/main/index.php/Main_Page
m3u: [7] http://en.wikipedia.org/wiki/M3U
pls: [8] http://en.wikipedia.org/wiki/PLS
MPD: [9] http://www.musicpd.org/
MPC: [10] http://linux.die.net/man/1/mpc
