Talk:Initial Raspberry Pi Setup
From Domoticz
Revision as of 15:42, 14 May 2018 by Beat (talk | contribs)
4 points :
1. There is suggestion for "optional enable SSH". As far as I can determine, SHH IS enabled, so it should be optional disable SSH, OR remove the line. If it should stay, it should have an added description of which menu option that will give you the possibility.
2. Is there any reason why we wouldn't suggest the user to change password?
3. From the install document included for the SD image :
"Optional: Configure a static IP Address (see http://www.domoticz.com/wiki/Domoticz_RaspberryPi_SD_Image) (Everything else on this page HAS BEEN DONE, do not do this again!!)"
This is suboptimal. We should remove the stuff from the wiki we do not wish the user should do, both instruction document should be similar in actions.
4. "1. Use a Class 10 SD card 2. Make sure you are using a Class 10 SD card ! And a good one!"
This should probably be stressed in this document too.
If there is no complains or corrections, I will make the changes.
Under "Installation" is mentioned "Download the latest Raspbian Jessie Lite SD card image. https://www.raspberrypi.org/downloads/raspbian/". However, the provided link doesn't link to Raspbian Jessie Lite any more, but to Raspbian Stretch. Being a first-time user of Domoticz, it's unclear to me now if I should be looking for an older Rasbian Jessie image (since Stretch is not supported / working flawlessly yet) or if I should download Stretch. Searching the forum I haven't found a clear answer. So I will try Stretch for now and update the WIKI later - depending on if it does work or not.
