ZiBlue RFPlayer
From Domoticz Wiki
Introduction
RFPlayer 1000 by Ziblue, the USB interface which allows to connect all the wireless devices in your house! In the form of a USB key, this little tool works with the protocols usually used with home automation devices: SOMFY RTS (roller shutters, automatic gates), DELTADORE X2D (alarms, heating, home automation), VISONIC (alarms), CHACON/DIO (home automation), SCIENTIFIC OREGON (peripherals for weather stations) and others.
4 main features:
- "Gateway": allows USB connection for all wireless devices in the house using the protocols quoted above.
- "Parrot": stores 433Mhz and 868Mhz radiofrequency frames, and then recognition and transmission.
- "Repeater": amplifies again the signal in order to avoid reach problems, very common with home automation transmissions.
- "Transcoder": converts input frames from a protocol to an output protocol.
Note: In 2021, GCE Electronics took over the manufacture of the "ZiKey" RFPlayer RFP1000 previously manufactured by the ZiBlue company.
Instructions
Setup Hardware
First Plugin you RFPlayer to your Domoticz machine
  • Go to Setup -> Hardware
  • Select Type: RFPlayer Gateway USB
  • Select correct com port (on rpi ex. /dev/ttyUSB30)
  • Give it a name. Ex RFPlayer
  • Push Add
Now if you have "Accept new hardware" enabled under menu Setup - Settings, it should start to populate the device list with new devices. Add them by the green arrow.
In French: https://www.planete-domotique.com/blog/2017/05/05/utilisation-rfplayer-domoticz/
Setup Devices
Sensors
Sensors like OREGON temperature/humidity sensors should be created when the first message is received from it. Just go to the Setup -> Devices page set the device to used ("Add Device" button with a right green arrow icon).
Supported Protocols
Protocol Device Created
X10 / Domia Lite protocols Switch
X10 (24/32 bits ID), CHACON , KD101, BLYSS, JAMMING Switch
VISONIC /Focus/Atlantic/Meian Tech None yet, only logged
RFY (RTS remotes) Switch
Scientific Oregon (thermo/hygro sensors) Temp/Hum Sensor or Temp Sensor
Scientific Oregon (Atmospheric pressure sensors) Temp/Hum/Baro Sensor
Scientific Oregon (Wind sensors) Wind Sensor
Scientific Oregon (UV sensors) Solar Radiation Sensor
OWL (Energy/power sensors) Watt Meter Sensor, kWh Meter Sensor, optionaly Watt Meter Sensor * 3 if three-phase
OREGON (Rain sensors) Rain Rate Sensor, Rain Sensor
Thermostats X2D None yet, only logged
Alarm/remote control devices X2D None yet, only logged
Cartelectronic TIC/Pulses devices (Teleinfo/TeleCounters) Watt Meter Sensor, kWh Meter Sensor * 2
FS20 None yet, only logged
EDISIO None yet, only logged
Switches
To add a switch (for example, to control somfy blinds):
  • Configure your devices with RFPlayer Configurator (you can download it at https://myrfplayer.com/)
  • Go to Switches tab
  • Manual Light/Switch button
  • Fill the name field
  • Choose the switch type
  • Set the Type: this is the protocol of your device
  • Set the pseudo X10 address (A1-P16) (the one you used to configure it with RFPlayer Configurator)
  • For RTS protocol, set the qualifier (true if not a blind).
  • Press "Add Device"
Supported Protocols
Protocol Parameters Device Example
Visonic 433MHz House Code
Visonic 868MHz House Code
Chacon House Code
Domia House Code
X2D 433MHz House Code
X2D 868MHz House Code
X2D SHUTTER House Code
X2D ELEC House Code
X2D GAS House Code
RTS House Code, Qualifier Somfy RTS Stores
Blyss House Code
Parrot House Code Devices learnt in parrot mode of RFPlayer
KD101 House Code
FS20 868 House Code
EDISIO House Code
