Supported Controllers
Jump to navigation
Jump to search
#Integration/Connection of various eHouse IP Controllers:
- eHouse Ethernet: directly on LAN/WiFi Network. Do not require eHouse PRO server in LAN Network for continuous work of Domoticz - after complete auto-discovery of all controllers
- eHouse WiFi: directly on WiFi/LAN Network. Do not require eHouse PRO server in LAN Network for continuous work of Domoticz - after complete auto-discovery of all controllers
- eHouse PRO: directly on WiFi/LAN Network.
#Integration of various eHouse NON IP Controllers (VIA eHouse PRO Server & Communication gateways):
- eHouse RS-485: must work under Main Host Supervision: CommManager, LevelManager, eHouse.Exe or eHousePRO. Require eHouse PRO server (or other host) for continuous work for integration with Domoticz
- eHouse Aura: Thermostats must work under Main Host Supervision: eHousePRO connected thru USB->AURA-485 gateway. Require eHouse PRO server for continuous work for integration with Domoticz
- eHouse CAN/RF: currently not implemented (future) must work under Main Host Supervision: eHousePRO. Require eHouse PRO server (or other host) for continuous work for integration with Domoticz
- eHouse RFID: currently not implemented (future) must work under Main Host Supervision: eHousePRO. Require eHouse PRO server (or other host) for continuous work for integration with Domoticz
- eHouse BMS: other systems integrated with eHouse (future)
#eHouse Ethernet controllers are large ( more than 50 intelligent points) microcontroller based units wchich can work standalone/autonomic after remote configuration via Windows application "eHouseWiFi.exe":
- up to 32 on/off outputs can work individually or paired for blinds/drives support with relay drives (for external relays)
- up to 20 on/off programmable inputs (switches, sensors, etc)
- up to 15 ADC (0..3v3) measurement inputs for regulation (eg termostat)
- up to 3 12-24VDC/PWM dimmers for direct LED light dimming
- IR Receiver input for direct control of current controller (Room)
- IR Transmiter output for direct control of external A/V systems (~23 IR standards implemented)
- 128 items of calendar-scheduler for unatended and service operations
- 24 light scenes/programs (on/off outputs + dimmers)
- 12 ADC Measurement/Regulation Programs
- 256 IR codes for reception (learning functionality)
- 256 IR codes for transmission (learning functionality)
- Domoticz Support:
- Single Outputs: on/off
- Double Outputs (blinds): open/close/set value
- Dimmer (on/off/set value)
- Thermostat Regulation Point (+/-/Set value)
- Measurement input associated with Thermostat Preset
- 10 Light Scenes/Programs (on/off outs + dimmers)
- 10 ADC Measurement Programs
- Inputs status Show
- Room Plan Auto Creation
2) CM/LM (CommManager/LevelManager) - centralized controller with security system functionality: CM
- up to 77 on/off outputs can work individually (LM) or paired for blinds/drives support (CM) with relay drives (for external relays)
- up to 48 on/off programmable inputs (switches, sensors, etc) with security system functionality
- 16 light scenes/programs (on/off outputs + dimmers)
- 24 security zones
- 24 roller programs (CM) / 16 scenes (LM)
- Domoticz Support:
- 10 Blinds Scenes/Programs (on/off outs + dimmers)
3) EPM (Ethernet Pool Manager) - Swimming Pool Controller (dedicated firmware for optimal control of Swimming POOL): EPM
- up to 5 on/off programmable inputs (switches, sensors, etc)
- Domoticz Support (In the future):
#eHouse WiFi 2.4GHz b/g/n controllers are medium size ( more than 10 intelligent points) microcontroller based units wchich can work standalone/autonomic after remote configuration via Windows application "eHouseWiFi.exe": WiFi
- up to 4 on/off outputs can work individually or paired for blinds/drives support with relays 230V/5A
- up to 4 on/off programmable inputs (switches, sensors, etc)
- up to 1 temperature measurement inputs for regulation (eg termostat)
- IR Receiver input for direct control of current controller or whole system
- optional 230V/5V build in power supply
- Domoticz Support:
#eHouse PRO/BMS: BMS
eHouse PRO are centralized Home Automation system based on Linux Microcomputer (Raspberry PI 1/2/3, Banana Pi/Pro, etc). With I/O Buffers and integrations (eHouse BMS, Thermostat, MySQL, Cloud, etc).
eHouse PRO server software without I/O buffers can also run on PC computers.
- up to 256 digital inputs via SPI
- up to 256 digital outputs via I2C
- up to 5 alarm outputs (Horn, Warning Light, Early Warning, Monitoring, Silent)
- security system functionality
- SMS/GSM Alarm notification and control
- WWW control
- TCP/IP Client/Server
- Modbus Client/Server
- Integrates (eHouse LAN, WiFi, RS-485, CAN/RF, Aura, RFID, Cloud, Satel Integra) into centralized/decentralized unlimited BMS system
- Domoticz Support:
- 10 Light Scenes/Programs (on/off outs)
- 10 Blinds Scenes/Programs (open/close - double outputs )
- 10 Security Zones (on/off inputs masks)
#eHouse RS-485 controllers are large ( more than 49 intelligent points) microcontroller based units which can work standalone/autonomic after remote configuration via Windows application "eHouse.exe":
1) RM (RoomManager) - Room Controller: RS-485
- up to 24 on/off outputs with relay drives (for external relays)
- up to 12 on/off programmable inputs (switches, sensors, etc)
- up to 8 ADC (0..5) measurement inputs for regulation (eg termostat)
- 248 items of calendar-scheduler for unatended and service operations
- 24 light scenes/programs (on/off outputs + dimmers) + ADC Measurement/Regulation Programs
- 248 IR codes for reception (learning functionality)
- 248 IR codes for transmission (learning functionality)
- Domoticz Support:
- Measurement input show as temperature
2) HM (HeatManager) - Boiler Room, Central Heating, Ventilation Controller (dedicated firmware for optimal control of Heating): HM
- up to 21 on/off outputs can work individually with relay drives (for external relays)
- up to 16 ADC (0..5) measurement inputs for regulation (eg termostat)
3) CM/LM (CommManager/LevelManager) - centralized controller with security system functionality: CM
- 24 security zones
- rs-485 interface for eHouse 1 supervising and integration
#Aura Wireless thermostat + temperature sensor
- thermometer with LED Display
- Thermostat Preset Local/Server
- Domoticz Support:
- Theromoeter associated with Thermostat Preset
- Special Inputs status Show
- Room Plan Auto Creation for all Aura controllers
- 10 ADC Measurement Programs for all Aura controllers
