Presence detection (Orbi Router)
From Domoticz Wiki
Orbi is a Wifi Router which allow network mesh between Orbi satellite.
If you are using the dhcp server from Orbi router, then all your wifi devices and known there.
The plugin allow you to create Domoticz switch based on Device mac address. When the device is connected to the router, the Domoticz switch will be set to On, otherwise Off
The Plugin is available here[1]
