Native secure access with Lets Encrypt
From Domoticz Wiki
Domoticz includes a SSL certificate generated for the *.domoticz.com domain. So for your own domain, it may result some warning error by your browser.
This article shows how to add a LetsEncrypt certificate to Domoticz so you can access your server over a secure HTTPS channel and without warning error. This certificate has a lifetime of 3 months and must be renewed every 3 months.
The provided steps are executed using a Raspberry Pi, but they should work on every Linux OS.
Prerequisites (see here : http://www.domoticz.com/wiki/Native_HTTPS_/_SSL_support)
  • You own a domain name
  • The (sub)domain name for Domoticz has a DNS entry that points to your external IP address
  • Port 80 (HTTP) and 443 (HTTPS) , in your internet box, are forwarded to your Domoticz server. Forwarding Port 80 is only needed for the creation and renewal time. I advice that you disable it after.
  • domoticz must listen to the port HTTP and HTTPS. Check this in the startup script : /etc/init.d/domoticz.sh
For more info on Domoticz security setup see wiki page Security
Install Lets Encrypt
Deprecated! Use the Install Lets Encrypt through snapd instruction, next section.
Note that the current Lets Encrypt procedures refer to certbot-auto (October 2019)
cd /etc
sudo git clone https://github.com/letsencrypt/letsencrypt
cd letsencrypt
sudo ./letsencrypt-auto
On Pi this last command will take a long time ...
if it fails due to a hash error, the culprit is this file (in july 2019) which points at a repo which is not sound see:
sudo nano /etc/pip.conf
Move it and reboot... and run the last command again:
sudo mv /etc/pip.conf /etc/pip.conf.backup
sudo reboot
will fix it.
snapd method added on 18 December 2021
Writing this currently you'll get an error through the instructions above because 'letsencrypt-auto' no longer seems to exist. Certbot apparently is the way to go!
First check if the snapd installation method would work for you on the official letsencrypt website: https://certbot.eff.org/
If you have no snapd installed, you can check their website to see if it's possible to install: https://snapcraft.io/docs/installing-snapd
If you could install snapd or snapd was already installed, follow either the most recent instructions on the certbot website or the following instructions below:
sudo snap install core; sudo snap refresh core;
sudo snap install --classic certbot;
Certbot should now be installed and callable from the CLI. Following one of the instructions below to actually start creating a certificate.
Create the certificate
sudo /etc/letsencrypt/letsencrypt-auto certonly --webroot --email <your email> -d <your complete sub.domain name> -w <user home>/domoticz/www/
(check that your domoticz is accessible on the port HTTP 80 via NAT forwarding in your router)
Letsencrypt create a temporarly file in the www directory of domoticz. This file will be checked by the letsencrypt server to ensure that you are the owner of the domain. Then it remove the temporarly file.
Edit Sep 10 2017 : If you do not want to expose port HTTP 80 to the outside world you can also use --preferred-challenges=dns and create a DNS TXT record (as described) to validate the ownership
You can specify multiple domain names using another -d parameter and domain name for each additional domain name.
If everything is OK this message shows:
IMPORTANT NOTES:
 - Congratulations! Your certificate and chain have been saved at
   /etc/letsencrypt/live/<your domain>/fullchain.pem. Your
   cert will expire on <date>. To obtain a new version of the
   certificate in the future, simply run Let's Encrypt again.
 - If you like Let's Encrypt, please consider supporting our work by:
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
The certificate is created in /etc/letsencrypt/live/
Create the certificate using Duck DNS and DNS validation (snapd method)
If you're using Duck DNS and got troubles generating a certificate using the webroot authenticator, you could also try the Duck DNS authenticator with DNS validation. Webpage of the certbot Duck DNS plugin: https://github.com/infinityofspace/certbot_dns_duckdns
Assuming you're using the snapd installed certbot, the following instructions apply (writing this it's still in beta).
sudo snap install -U --beta certbot-dns-duckdns;
sudo snap set certbot trust-plugin-with-root=ok;
sudo snap connect certbot:plugin certbot-dns-duckdns
sudo certbot certonly -v --authenticator dns-duckdns --preferred-challenges dns --dns-duckdns-token *duckdns token noted on website of duckdns* --email *my email* -d *my duckdns domain*
You can find the duckdns-token if you log in on the Duck DNS website: https://www.duckdns.org/
Add the certificate to Domoticz
Then you add the created certificate to Domoticz with (rename certificate so it will not be overwritten by a Domoticz update):
sudo cat /etc/letsencrypt/live/<your domain>/privkey.pem > ~/domoticz/letsencrypt_server_cert.pem
sudo cat /etc/letsencrypt/live/<your domain>/fullchain.pem >> ~/domoticz/letsencrypt_server_cert.pem
Modify in /etc/init.d/domoticz.sh (change <USER> by the used user eg pi
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
into
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443 -sslcert /home/<USER>/domoticz/letsencrypt_server_cert.pem"
Restart Domoticz:
sudo service domoticz restart
As every update of domoticz overwrites your certificate, the last command backups your new certificate so that you may may restore it if needed.
When there's a domoticz error after rebooting the service like : Error: [web:443] missing SSL DH parameters from file
Add the DHparam :
sudo cat /etc/ssl/certs/dhparam.pem >> ~/domoticz/server_cert.pem
and if you get also an error like : /etc/ssl/certs/dhparam.pem: No such file or directory
cd /etc/ssl/certs
sudo openssl dhparam -out dhparam.pem 2048
sudo /etc/init.d/domoticz.sh restart
Here, the openssl command will take a very long time (like 45 minutes on a Pi3). Alternatively you could copy the section from the original server_cert.pem file:
sudo tail -n 8 server_cert.pem.org >> ~/domoticz/server_cert.pem
This will append the lines from -----BEGIN DH PARAMETERS----- to -----END DH PARAMETERS----- to the end of the pem file.
Renew the certificate automatically
Your Lets Encrypt certificate is valid for 3 months. To automtically renew it, you could make a cron job to try and renew it say every week. To do so:
crontab -e
and add a line like
0 23 * * 5 sudo certbot-auto renew --webroot -w ~/domoticz/www/ --deploy-hook ~/domoticz/scripts/deploy-cert.sh >/dev/null
Note that I use certbot-auto here instead of letsencrypt-auto because I know the above works. To install the renewed certificate --deploy-hook is used with a script to create the new server_cert.pem with correct contents as described above.
