MQTT Push
Jump to navigation
Jump to search
To setup a regular data push from specific Domoticz devices to a MQTT Broker/Server you go to Setup - More options - Data Push - MQTT
If you want full integration including Read MQTT messages use the MQTT Gateway or the MQTT mapper python plugin
Prerequisite: An accessible MQTT Broker/Server to connect to.
You can add the individual devices you want to send the data to MQTT in the Edit Link section
- Device name: Select the device from wich the data has to be send to Influxdb
- Value to Send: Some devices have multiple values eg Temperature, Humidity barometer pressure. Select here the value to send.
- Target type: What triggers the send to influxdb action:
- On value change: Only when the updated value is different from the previous.
- Direct: After each update in Domoticz, changed or not
- Link Active: Yes/No
In the General Settings section you can enter the details of the MQTT Broker/server you can connect to.
- Remote adress: (IP) adress of the MQTT server
- Port
- Username for the MQTT server
- Password for the MQTT server
- Topic Out Prefix (eg DomoHome)
- CA file name, default empty (only needed when a certificate is needed)
- TLS Version, default tlsv1.2 (only change when needed)
