Lost Username Password
From Domoticz Wiki
By default Domoticz is protected by a username (admin) and password (domoticz).
Please either change the password as soon as possible through page Setup - My Profile or create a different admin user and remove the default (admin) user.
If you lost your username and password you can start domoticz with a command line argument that will bypass security.
Steps to perform:
Linux
- Make sure domoticz is stopped
- change to the folder where domoticz is installed
- start domoticz with command
./domoticz -nowwwpwd
or
sudo ./domoticz -nowwwpwd
An example to perform this on a raspberry pi:
ssh to your machine (default username/password is pi/raspberry)
cd domoticz
stop the domoticz service
sudo service domoticz.sh stop
Wait at least 15 seconds and check if it is stopped before continuing:
sudo service domoticz.sh status
Start domoticz by hand (as root) with the command line argument:
Now go to the settings page of domoticz, and verify or change:
- Admin username/password (menu Setup -> Users)
- Trusted network settings (Setup -> Settings -> tab Security)
- My Profile (Setup -> My Profile)
Windows
Stop the Domoticz service (if running)
Start Domoticz as an app, define in the target field of the Domoticz properties window (right click on Icon) and add -nowwwpwd parameter.
For example C:\Users\Public\Domoticz\domoticz.exe -www 8080 -sslwww 443 -nowwwpwd
Remove the -nowwwpwd parameter again once you have reset your User/Password.
