Domoticz version table V2021.1
From Domoticz Wiki
Past release ( V2021.1 development)
Build Commit Date Type Description
14121 20220130 build Updating build year
14120 20220130 OpenZwave marking deprecated in code
14119 20220130 Evohome Revert "Added support for Evohome Day Off With Eco controller mode"
14117 20220128 MQTT-AD check last kWh value when 0 is received, check if battery object is a number before processing, removed wrong brightness value template check
14116 20220128 Scenes Implemented 'Toggle' for switch actions
14115 20220128 Translations Update translations
14114 20220127 Hardware Merge PR 5133 Refactored GetManualHardware to be more self-explainatory
14112 20220126 MQTT-AD Removing default color_temp_value_template value
14111 20220126 Support scripts Merge Commits/build and MQTT-AD support scripts together:
14110 20220126 MQTT-AD Allow brightness to be send for XY/CT types
14109 20220126 Teleinfo Merge PR 5129 Combine used/delivered energy in same meter
14105 20220125 Hardware Allow manual add Light/Switch for disabled hardwared (was removed by previous PR)
14104 20220122 Hardware Fixed crash caused by PR #4923 (Fixed #5128)
14103 20220122 MQTT-AD removed setting the brightness when setting a color (moved to color temp)
14102 20220124 MQTT-AD Fix logfilename when search string contains invalid filecharacter
14100 20220123 build Added get_build_versions script to easily get ta list of Domoticz version and commits
14098 20220122 MQTT-AD Better handling of Selector switch configuration
14097 20220121 MQTT-AD Merge PR 5120 Scripts add Userid and Password support
14093 20220121 Build Making sure script files always end with LF
14092 20220120 MQTT-AD Merge PR 5118 Capture scripts to facilitate AD debugging.
14089 20220120 MQTT-AD Added support for 'mm' unit if icon contains rainy
14088 20220120 MQTT-AD Counter bypassing state_class/total_increasing for now
14087 20220120 MQTT-AD Fixed Counter detection, added counter based on state_class
14086 20220120 MQTT-AD always calculate level (Fixes #5017)
14085 20220120 Webserver Added missing files to appcache
14084 20220120 Build Cleaning up Visual Studio project
14083 20220120 RFLink Merge PR 5112 Added RFLINK gateway MQTT device
14082 20220119 MQTT-AD handling value templates with array
14081 20220117 MQTT-AD Better "hs" support
14080 20220117 Build Fix compile warning (and use internal reader)
14079 20220117 MQTT-AD Escaping special characters
14078 20220117 Teleinfo Merge PR 5113 Fix a bug in variables name in alertlevel function
14076 20220117 Build Fixed compile warnings under windows
14075 20220117 MQTT-AD Making sure correct discovery topic is matched (Fixes #5114)
14074 20220116 Hardware Merge PR 4923 Allow hardware to declare manual switches they are able to handle.
14073 20220116 Charts Partly fix for Meter Counter report
14072 20220116 MQTT-AD Merge PR 5100 Fixes for RGB/RGBW dimmers (eg Fibaro FGRGBW)
14071 20220116 MQTT-AD Making sure JSON object is not a object
14070 20220115 MQTT-AD Putting unknown sensor types back into general type
14069 20220115 MQTT-AD Added more exception information
14068 20220115 MQTT-AD Added detection of CT nodes (needs more work from other pR)
14067 20220115 Webserver Replace light/switch now only transfers new HardwareID/DeviceID/Unit to the old devic
14066 20220115 Dummy Making sure a new sensor is created (could already exist a device with same type/id)
14065 20220115 General Updated History
14064 20220115 Anna Thermostat Merge PR 5111 Add annathermostat metrics, Hot waterflow and -temp
14058 20220114 Notifications Validity checks HTTP actions
14055 20220114 Webserver Fix for dirs with a dot in name that messed up extension handling
14053 20220113 Webserver Increased range of www/ssl port to 49151
14052 20220113 GUI Fixed display thermostat problem problem in mobile view
14051 20220113 MQTT-AD MQTT-AD: Add support for rain-rate
14050 20220113 MQTT-AD Making sure Setpoint is also correctly handled for Fahrenheit
14049 20220113 Icons Added Irrigation icon (also thanks to dbemowsk)
14048 20220113 MQTT-AD Initial support for cubic meter sensors (needs testing)
14047 20220113 MQTT-AD Percentage sensor not displayed as custom sensor anymore
14046 20220112 MQTT AD Making sure setpoint temperature is updated when received
14045 20220112 MQTT AD Climate device, continue parsing if wrong/unknown data is received
14043 20220112 Webserver Merge PR 5105 fix to add charset to stock reply content-type
14040 20220111 Notifications Merge PR 5103 Add optional http/script action
14036 20220111 MQTT AD Making sure kWh sensor is only updated when received before
14035 20220110 MQTT AD using device_class field for illuminance/lux type detection
14034 20220110 Code cleanup Merge PR 4976 unique_ptr conversions
14028 20220110 Webserver Merge PR 4994 Code refactoring in WebServer
14022 20220110 Build Merge PR 5021 Add dzVents automated unit-tests for PR's
14018 20220110 Tools removed transifex binary, users can download this themselves
14017 20220110 Translations Update translations
14016 20220109 OpenZwave add support for ZW164 Indoor Siren 6+ (Should fix issue #5080)
14015 20220109 EnOcean Removed invalid code
14013 20220109 Scripts (Non-Windows) Use stat instead of lstat to allow symlinks to be used
14011 20220109 MQTT Added string validation check
14010 20220109 MQTT AD Added MQTT-AD web configuration
14008 20220109 Hardware Simplify Hardware classes
14004 20220109 MQTT AD Split of MQTT and MQTT Auto Discovery code into new hardware type
13997 20220109 MQTT AD Setpoint now also works for Fahrenheit
13996 20220109 MQTT AD Support for Fahrenheit temperatures
13995 20220109 MQTT AD Better/Faster Unique ID matching
13994 20220108 Build Reverting is_number function that was not (caused by #4891)
13992 20220108 MQTT AD Update kWh sensor if Watt is received
13990 20220108 MQTT AD Better support for matiching kWh en Watt sensors
13988 20220108 MQTT AD Merge PR 5081 Fix MQTT AD Selector switch
13984 20220108 Teleinfo Fix warning in TeleinfoBase
13981 20220108 Code cleanup Merge PR #4891, use auto with iterators
13978 20220108 Build X64 build, use right openzwave library
13977 20220108 Python Framework Fix crashes on badly-formed http response
13976 20220108 Charts Merge PR 5075 Chart Fixes ENERGY and POWER, tooltip, color compare arrow, CSS
13969 20220108 Teleinfo Merge PR 5076 Add support for EAIT/SINSTI/STGE (Linky standard mode)
13966 20220108 OpenZwave Updated OZW configuration file
13965 20220108 Webserver Merge PR 5084 Improvement: Serve files without extension
13962 20220108 Webserver Merge PR 5090 Improve webserver security
13956 20220104 Build Merge PR 5047 Fixes Python plugin issues on armv7 Debian 11 builds
13954 20211224 Python Plugin Upgrade Python locking to protect against Python Threads changing memory
13953 20211220 EvoHome Merge PR 5073 Fix Evohome Web API crash when a new zone is added.
13951 20211220 MQTT AD Fix for #5072 : Only show MQTT Unhandled state received error message when debugging
13949 20211218 Teleinfo Small code fixes
13947 20211217 Teleinfo Fix #5066: more permissive detection between historic/standard mode
13945 20211217 Build Merge PR 5050 Support for homebrew python on Apple Silicon
13943 20211217 EnOcean Merge PR 5067 Add new fields to domoticz.db to better manage EnOcean nodes + minor fixes
13939 20211216 MQTT AD MQTT Cover/Blinds Slider Fix
13935 20211216 MQTT AD Small fixes
13931 20211215 Email Notifications Merge PR 5063 Fix jpeg inline attachment handling for K9 mail
13929 20211215 OZW Added support for Heatit ZM Single Relay 16A
13927 20211215 Anna Thermostat Medrge PR 5029 More sensors for Anna Thermostat
13925 20211215 SSL Correcting log parameter (Fixed #5033)
13923 20211215 General Setpoint selector bottom limit removal (#5056)
13922 20211215 InfluxDB Merge PR 5057 Alert and Current devices data push to influxdb.
13920 20211215 Teleinfo Merge PR 5045 Basic support for standard mode (Linky)
13918 20211215 EnOcean Merge PR 5058 Fix compile warning Debug message escape percent sign
13916 20211214 MQTT Reverted old Blinds behavior by testing for MQTT HardwareType. #5055
13914 20211214 MQTT AD Scene/Group with RGB, code moved to mainworker
13912 20211214 MQTT AD Support for Base topic
13911 20211214 Daikin Merge PR 5037 Updates to Daikin hardware and some typos
13909 20211214 Charts Merge PR 5047 Chart changes, bug fixes, Computed kWh, usage calculation, zoom
13883 20211214 Build Merge PR 5051 Upgrading to Visual Studio 2022
13882 947af87 20211213 Denkovi Merge PR 5035 Improved http get communication
13879 ddc958b 20211213 TTNMQTT Merge PR 5036 Handling objects better
13877 8ba97ea 20211213 MQTT AD Merge PR 5048 Scenes/Groups: Fix sending color_temp & RGB info for MQTT devices
13875 71f525f 20211129 TTNMQTT Merge PR 5034 Fix for empty frm_payload
13872 b8adb0e 20211110 MQTT AD Correct kWh value
13871 9fa2374 20211109 MQTT AD Selector switch now populated on initial config receive
13870 2f7eabb 20211109 Build Fixed compile warning
13869 19319ce 20211109 Webserver Merge PR 5016 Improved robustness of processing Settings update
13866 3b7da50 20211109 TTNMQTT Merge PR 5005 The Things Network (TTN): Switch to new V3 stack
13858 197c36a 20211109 Eventsystem Merge PR 5018 Fix "Set Level xx" not working for the new "BlindsPercentageWithStop"
13855 e841b35 20211109 EvoHome Merge PR 5019 Decoded the latest version of the OT Bridge messages
13854 0c09637 20211108 MQTT AD Silence string conversion
13853 5520f46 20211108 MQTT AD Fixed possible crash and apply received battery level to all sensors of the device
13852 59db50 20211107 Python plugin Feature: Allow field descriptions for plugins in Hardware tab
13851 a1c6c28 20211106 EnOcean Merge PR 5015 Correction of level translation 0..100% --> 0..15 : put 99 to have 100% & test pNode->RORG
13847 e850dcd 20211105 EnOcean Merge PR 5011 implementation of new EnOcean Devices : D2-05-00 :Blinds Control for Position and Angle and D2-01-0C : Pilot Wire
13845 ff6cc69 20211104 MQTT AD Fix for climate devices
13844 5014bcb 20211104 MQTT AD Fix for select/climate where users change the option label
13843 9db5b44 20211103 Python plugin Added count of scanned plugins to start up message
13841 82bb29e 20211103 MQTT AD Using correct Set Level for RGB switches
13835 52679e0 20211103 MQTT AD Support for Lock type
13827 7f8d6ad 20211102 MQTT AD Merge PR 5007 Reverted the ON Level to 255 instead of max level
13824 843dc43 20211102 Python plugin Bugfix: Remove warning on linux
13823 d9a23d7 20211102 Python plugin Bugfix: Removed double plugin name in log messages
13821 f1885dd 20211101 MQTT AD Merge PR 5004 Fix for brightness_topic payload
13820 3f4c420 20211101 MQTT AD Fix Cover/Blinds percentage calculations
13815 3af96db 20211101 MQTT AD Merge PR 5003 Cover Blinds inverted patch
13813 0d7303b 20211031 Build Merge PR 5002 Use Domoticz fork of OpenZwave for compilation
13805 df041b2 20211031 Build Merge PR 4998 Add running automated tests to GitHub action for PR workflow (and fix buildnr and more)
13895 6d4cb32 20211030 MQTT AD Merge PR 4995 Fix cover devices
13790 1c394a5 20211030 MQTT AD Merge PR 4997 Empty payload_stop creates STYPE_BlindsPercentage
13788 068bf5a 20211029 MQTT AD better template stripping
13787 multiple 20211028 MQTT AD Various improvements
13783 9eee297 20211027 MQTT AD implement enabled_by_default flag
13781 multiple 20211026 MQTT AD Various improvements
13774 5a11e25 20211026 MQTT AD Merge PR 4988 Update_climate_discovery
13773 a830e31 20211026 Webserver Merge PR 4962 Fix for serving already compressed sourcefiles and some refactoring
13768 d40dfdc 20211026 Webserver Merge PR 4987 add getLanguages command
13755 db521a8 20211025 Build Correcting some compile warnings
13754 a999e1c 20211025 MQTT AD Merge PR 4989 Fix cover perc recalc
13750 67ae3c9 20211024 MQTT AD Adding extra temperature unit check
13749 0ea2773 20211024 General String Conversion and locale setting
13746 f33116f 20211024 MQTT AD better unique_device_id for stand-a-lone temp/hum,baro, implemented global RSSI, non-numeric sensors with empty unit will now be a text sensor again
13745 d45ea17 20211022 MQTT AD Handling of more complex templates
13743 6ea865c 20211021 MQTT AD Merge PR 4984 Fix for cover devices status updates received
13738 00d5dc5 20211018 MQTT AD Cover, reversing open/close
13737 36a6015 20211018 OZW Updated OpenZwave Config files
13736 972912c 20211018 MQTT AD Blinds using command topic if available
13735 4834dc6 20211017 Mercedes EV Fix so RefreshToken is properly stored and retrieved in the UserVariables table on 32-bit platforms (like RaspberryPi)
13733 24ab415 20211017 Code Cleanup Bugfix: Revert Various PR.s 4913,4894,4889,4888
13724 0ab679e 20211015 Code Cleanup Various PR.s 4913,4894,4889,4888
13720 f6d076b 20211015 OpenWeatherMap Fix to resolve OWM City for default location. Used by OWM based forecast screen
13719 358fa65 20211015 EnOcean Various fixes PR 4972
13718 ab53881 20211015 MQTT AD Fix missing thermostat-climate thermostat_command_template PR 4971
13704 ef38e36 20211011 Python Plugin Ext Bugfix: Event and notification functions being invoked for devices that are not 'Used'
13703 120c384 20211006 Charts Merge PR #4958, Minor chart improvements
13690 96ca602 20211006 MQTT AD Better RGB support
13689 d29a27f 20211005 MQTT AD Change to better support rgbcct
13688 16a4bd9 20211004 Logging Added executed command in error log
13685 e30521c 20211004 Python Plugin Bugfix: MQTT Protocol crashed on extremely short partial messages
13682 378a115 20211003 MQTT AD simplify rgbcct code
13681 486e8a5 20211003 DB Selector actions are url encoded (bug in dbversion 128)
13680 0b4eb67 20211003 Charts Several fixes PR #4954
13679 ed06b33 20211003 MQTT AD Better handling of RGB/CT
13670 1ab6042 20211002 MQTT AD small tweak for brightness
13669 f30dc72 20211001 Themes Fix for updated theme processing to serve other relative custom theme files correctly PR #4952
13664 780755b 20211001 Themes Refactored way of serving theme files PR #4942
13648 b7105dc 20211001 MQTT AD More work on RGB/W/CT lights
13647 5f6d847 20210930 Python Plugin Ext Bugfix: LastLevel not updated in Unit.Update()
13645 b931e9a 20210930 Web User Interface Updating ui-bootstrap and fontawesome
13644 5a0fc83 20210930 Charts Fixed light on/off graph
13643 faa5066 20210929 MQTT AD Supporting more actions
13642 47df27e 20210929 Plugin Bugfix: MQTT Ping response and disconnect formats incorrect
13640 9806e37 20210929 Python Plugin Added some extra error handling
13639 d20f51b 20210929 Devices Different XYFromRGB method
13638 73dbf44 20210929 Charts Compare-chart should be able to handle new devices #4948
13637 e2bed9d 20210929 Command Line Merge PR #4917 Fix --help for -loglevel & -debuglevel
13636 e6876f0 20210929 MQTT Merge PR #4947 Fix for currentValue containing a JSON with the value field
13624 32f528f 20210928 Python Plugin Ext Bugfix: Selector handling, insert and update
13624 28a7541 20210927 Python Plugin Add Subscribe acknowledgement to plgin MQTT protocol
13623 f425e95 20210927 Device Logs Merge PR #4943 update-highcharts-9.2.2
13622 53758e5 20210927 DzVents Merge PR #4945, fix for #4944, skipping device without lastUpdate
13621 37d4ad1 20210927 MQTT AD sending X/Y in the range of 0-1
13620 76610b3 20210927 Python Plugin Ext Switch notifications
13517 e7da43d 20210926 Build Added missing include file for GCC
13516 0e8122b 20210926 MQTT x/y now in range of 0-65535
13516 c834530 20210926 Build Silenced compile warnings
13517 ffc7ad5 20210926 MQTT Adding support back for XY
13509 bbd930a 20210925 Python Plugin Uplift: Plugin MQTT protocol to support being a broker
13508 6ba5922 20210924 EnOcean Fixes and new features (#4939)
13507 c34bba7 20210924 MQTT AD Moving RGB detection up
13506 b7635f4 20210924 MQTT AD Correcting blinds status in gui
13505 9dda265 20210923 MQTT Fixing kWh sensor
13504 65bfbac 20210923 Devices New widgets for Blinds (percentage) + Stop and Blinds (percentage) Inverted + Stop
13503 a2d4630 20210922 MQTT AD Taking more cover/blinds parameters into account
13502 7e709e3 20210921 MQTT AD Auto correct commands for open/close for cover type
13501 4bee920 20210919 EnOcean Fixed parameters in Debug messages (#4934)
13500 db69b03 20210917 MQTT Displaying correct device id for non-numeric id's
13499 eee4de7 20210916 MQTT Better random client id for MQTT
13498 ef8b962 20210915 MQTT AD Better internal device type recognition
13497 2c271b6 20210910 MQTT AD Correcting sensor name
13496 f57eb52 20210910 MQTT AD Implementation Mqtt Auto Discovery (part 1) (#4921)
13495 811e1cf 20210909 Python Plugin Bugfix: Memory leak in JSON Protocol.
13494 f9663cd 20210906 EnOcean Replace compilation directives by DEBUG messages
13493 7bda657 20210906 Python Plugin Ext Uplift: Add feature to UnitEx Update function to add 'Log' option
13492 30933f2 20210903 RTL433 Merge PR 4927 Rtl433: add support for light_klx field (SendLuxSensor)
13491 9afde01 20210831 Python Plugin Ext Bugfix: UnitEx updates not being sent to event system
13490 e8436ea 20210829 Python Plugin Ext Bugfix: quotes in UnitEx strings causing errors.
13489 0a72c49 20210827 EnOcean Merge PR 4916 Fix SetDebugFlag for 'all' or number values
13487 a2167d3 20210826 Python Plugin Bugfix: Resolve UDP/IP Send crash when Connection is not associated with a Plugin
13486 67a334e 20210825 Build Small adjustment to log output, fix compiler warnings
13482 e8eb6e3 20210824 USBtin/Multibloc V8 Merge PR 4908 IBS integration - time-left correction + some over modifications
13477 87f499544 20210824 Python Plugin Bugfix: Connection objects failed to initialise
13476 a517bb4 20210824 MercedesMe Merge PR 4909 Check password fixed. Additional Status info incl. cURL SSL errors.
13475 79a9f53 20210823 EnOcean Merge PR 4904 Review all supported EEP according to current specifications
13437 9ab1f2c 20210822 Weather Implemented Wind Meter, Angle Rotation
13436 a8ddfba 20210822 Translations Updated Translations
13435 f613d8fec 20210821 Weather Solar radiation value validation
13434 61a52564e 20210820 Weather Implemented wind log in devices overview
13433 c81901a98 20210819 RFPlayer Merge PR 4905 Send command to RFPlayer devices through dzEvent not working
13422 507054f2 20210816 USBTin CAN add management of IBS (Intelligent Battery Sensor) with BLOC_9
13421 9c50bf3 20210812 Python plugin Bugfix Batterylevel and RSSI update mechanism
13420 c7c0f005 20210808 User Interface Bugfix: Rain icon has been broken since the end of May
13419 c76c9fd8d 20210805 Extended plugin Refined API for DomoticzEx events
13355 918c72878 20210625 EnOcean Merge PR 4853 from efdeb;Rename Get Profile@@@@ to Get@@@@
13333 6b34d9921 20210624 Python Plugin Ext Allow reading and writing of Connection event target
13332 bb62ac2f8 20210619 EnOcean Merge PR 4863 from labelette91580; correction problem with Enocean device
13330 cbacba2c2 20210618 BugFix: BugFix: Removed P ython 3.9 specific function Refactor: Standardised conversion f
13329 24521c255 20210616 Correcti Correcting some c ompile warnings and formatting
13328 51fa988a8 20210616 Updated Updated installer script
13327 5e673c127 20210615 Python Plugin Ext Bugfix: Domoticz crashes when 'listening' connections don't have an event target
13326 19cb03bde 20210615 Fix debu Fix debug message parameter defect
13325 d438f26a8 20210615 Change C Change CUnitEx Up date handling and fix dictionary issue on create
13324 9f4603f2b 20210612 dzVents dzVents fix docum entation
13324 9f4603f2b 20210612 dzVents Merge PR 4855 from jp-keros; Fix documentation
13323 6f87423d6 20210612 Python Plugin Ext Add broadcast reception to UDP Listen
13322 789f5e76a 20210611 Python Plugin Ext Initial Python version plugin framework
13321 94d31bd21 20210607 Logging Merge PR 4858 from kiddigital; Fix for wrong usage of binary logging flags.
13319 e79edbc9b 20210606 Build Merge PR 4857 from xbeaudouin; Fix clang compilation error
13314 dab55c4f8 20210605 RTL433 Merge PR 4850 from hvbommel; RTL-SDR TFA Raindrop 16bit device id
13312 465a86903 20210605 Charts Merge PR 4851 from michahagg; Fix for empty P1 year and month charts
13311 0dcd33472 20210603 Charts Merge PR 4830 from michahagg; Added compare charts
13309 91386cd12 20210603 Charts Changed filler to id4
13308 dcefeb75d 20210603 RFXCom Updated RFXCom SDK version to 9.31
13307 c93cb5881 20210603 Plugin manager Merge PR 4849 from proxyfix; Adjusting Python plugin transport system
13300 508a8f27b 20210528 Plugin manager Redirecting log of to actual plugin log
13299 725c75c80 20210527 dzVents Change errormessage to debug message on empty lastUpdate
13298 e4c3c00f8 20210525 Xiaomi Merge PR 4839 from Huupke; Add workaround to support devices not reporting their model
13277 16492be90 20210525 Network Ensure settings are reloaded for both HTTP and HTTPS after a change
13276 011e73010 20210524 Authorisation Fix for issue 4833; Access to Domoticz API by using IP from CLI
13274 f9103b8df 20210523 Favorites Merge PR 4838 from waaren; Fix for loosing user's favorites when shared device is added
13272 2ad63c4dd 20210519 EnOcean Merge PR 4829 from efdeb;Correct VLD messages management
13269 b7237eeef 20210518 EnOcean Merge PR 4828 from efdeb; Correct EEP D2-01-xx status response, EnOcean EEP 2.6.8
13267 080ce1336 20210518 Various code Corrected some typos
13266 1f55110ee 20210516 Database Merge PR 4819 from waaren; Changed default journal mode to WAL (write ahead) for Windows
13261 4cc988193 20210516 Command line Fix for issue 4825; Command line argument count returns 1 with 0 arguments
13260 47d5c3ddc 20210514 Weather Merge PR 4823 from hvbommel; Improved fix tfa drop rain amount and battery percentage
13256 ab915f0a4 20210511 Weather Merge PR 4818 from hvbommel; Fix tfa drop rain amount and battery percentage
13254 0b1768bbc 20210509 MQTT Safety check for ID's that are not a valid number
13253 3c18566c1 20210509 Influx Data push, Influx 2.0 support
13252 86ac025ab 20210508 Database Add mutex to protect database during blob update
13251 c1526b127 20210506 MQTT Use same DeviceID presentation as in JSON/Web GUI
13249 1582636a9 20210505 OpenWebNet Merge PR 4812 from Spugna85; Added probe mode and selector status
13246 1b02746f2 20210503 Build Updated boost download location/version
13243 c11443402 20210502 OpenZwave Removed double log naming and added DEBUG received log option
13241 6c4786843 20210429 Build Merge PR 4808 Fix for compiler warning on Linux. Cast to correct integer size.
13240 d626bc52f 20210428 updatebeta Increased updater time (needed for backup creation feature)
13239 a05ee899d 20210427 Xiaomi Fix for issue 4807; Added missing definition for new model wireless single key switch
13238 dddefca5e 20210427 Windows Merge PR 4804 from rrozema;use stat to check if a folder exists
13235 d9bdec2ce 20210503 Build Updated boost library
13234 650a21f52 20210426 SatelIntegra Possible fix for issue 4784 domoticz crash when SatelIntegra is set to active
13232 bc80f4c84 20210426 MQTT Merge PR 4756 from kiddigital; Add option to set retain flag for some MQTT topics
13227 a064739ea 20210426 SolarEdgeAPI New Unit ID for DC sensor. Required because of conflict with 3 phase sensor.
13226 041a3dccb 20210426 Meteorologisk Use actual time block + add check for humidity
13225 b691104aa 20210425 Webserver Merge PR 4802 from waaren; Change loglevel on empty session id from error to debug
13223 b77f4aa2c 20210424 dzVents Added some resilience on time-rules.
13222 c956b59c4 20210423 Logging Merge PR 4799 from waaren; only log updateDevice from LUA message in debug mode
13220 bed785e09 20210421 updatebeta Removed 'stop on error'
13219 ae3ff62fe 20210421 updatebeta Remove oldest backup (keep 5 newest)
13218 3e8c61c76 20210421 updatebeta Merge PR 4702 from waltervl; option to automatically create backup before update
13207 0a4ccfb82 20210420 Build Adding closure
13206 b34627e48 20210420 Build Using available SQLite library instead of statically linking it
13205 e78e32d63 20210419 dzVents PR 4791 from waaren; Update to 3.1.8
13204 bfbf1d3e6 20210419 OpenZWave Added support for Electric_Pulse
13203 9e02d9a79 20210419 Build Merge PR 4789 from xbeaudouin; Removed obsolete pointers to fmtlib
13200 a98ced851 20210419 Various code Return correct string size in standard format function
13199 bd4531e4d 20210419 Authentication Fix for issue 4788; Master-slave authentication
13198 a6832c68b 20210419 Build Added Teleinfo header to Microsoft visual-C project
13197 667d394c0 20210419 Build Removed FMT link dependency from Microsoft visual-C project
13196 40194e618 20210418 Build Added missing include file for GCC compiler
13195 82043c4d5 20210418 Build Removed libfmt dependency
13194 17993b030 20210418 BleBox Changing variable name
13193 734c94f43 20210418 Build Switch back to development branch (beta)
13192 59831c4a1 20210418 dzVents Fix for failing combined time rule.
13191 8547c5b7e 20210417 Release Merge PR 4781 from gizmocuz; Stable release
