Battery level check
From Domoticz Wiki
Purpose
These scripts are used to check battery level.
Be aware that there is also a general Application setting for battery Level notifications so only use and modify these scripts if you need other functionality than the standard one.
Script 1 - DZevents
The forumTopic of this script is here : https://www.domoticz.com/forum/viewtopic.php?f=59&t=18542&p=142962
This script check all devices that have a device.batterylevel attribute.
local BATTERY_THRESHOLD = 10
	active = true,
--	    devices = {
--		  'testSwitch',
		timer = {
			'at 18:00 on fri,sat,mon,wed',   -- sun,mon,tue,wed,thu,fri,sat
	execute = function(domoticz)
		local message = ''
		-- first filter on low battery level
		local lowOnBat = domoticz.devices().filter(function(device)
			local level = device.batteryLevel -- level is 0-100
			return (level ~= nil and -- not all devices have this attribute
					level <= BATTERY_THRESHOLD)
		end)
		-- then loop over the results
		lowOnBat.forEach(function(lowDevice)
			message = message .. '' ..
				lowDevice.name .. ' : ' .. tostring(lowDevice.batteryLevel) .. '% left\n'
		end)
        if (message ~= '') then
			message = '-- Low battery warning ------\n' .. message
			domoticz.notify('Low battery warning', message, domoticz.PRIORITY_NORMAL)
--			domoticz.log('Low battery warning: ' .. message, domoticz.LOG_ERROR)
Script 2 - Lua
Dependencies - hardware / software / operating system
This script will work on Linux systems and needs jq installed. You can install jq using the following instructions:
wget https://github.com/stedolan/jq/releases/download/jq-1.4/jq-1.4.tar.gz
tar -zxvf jq-1.4.tar.gz
rm jq-1.4.tar.gz
cd jq-1.4
./configure
make
sudo make install
Before you can use jq it needs it needs to be compiled. If you never configure or make a installation before. You probably won't have the development tools needed. Follow the instructions to install the development tools and continue with the jq installation.
sudo apt-get update
sudo apt-get install build-essential
Domoticz Setup - switches, variables, version
The single user variable DevicesWithBatteries set in Domoticz with the name of each device seperated by a | i.e. stored as "name one|name 2|name 3|name Forty one" with correct case and spacing.
Installation instructions
Copy this script in your domoticz\scripts\lua\ folder.
Script with comments
--~/domoticz/scripts/lua/script_time_battery.lua
-- Check battery level of devices
--Uservariables
BatteryLevelSetPoint=99
EmailTo="[email protected]"
ReportHour=20
ReportMinute=01
DomoticzIP="192.168.5.70"
DomoticzPort="8080"
Message = 'Batterijchecker'
DeviceFileName = "/var/tmp/JsonAllDevData.tmp"
-- Time to run?
time = os.date("*t")
if time.hour == ReportHour and time.min == ReportMinute then
    -- Update the list of device names and ids to be checked later
    os.execute("curl 'http://" .. DomoticzIP .. ":" .. DomoticzPort .. "/json.htm?type=devices&order=name' 2>/dev/null| /usr/local/bin/jq -r '.result[]|{(.Name): .idx}' >" .. DeviceFileName)
    BattToReplace = false
    -- Retrieve the battery device names from the user variable - stored as name one|name 2|name 3|name forty one
    DevicesWithBatteries = uservariables["DevicesWithBatteries"]
    DeviceNames = {}
    for DeviceName in string.gmatch(DevicesWithBatteries, "[^|]+") do
       DeviceNames[#DeviceNames + 1] = DeviceName
    -- Loop round each of the devices with batteries
    for i,DeviceName in ipairs(DeviceNames) do
       --Determine device id
       local handle = io.popen("/usr/local/bin/jq -r '.\"" .. DeviceName .. "\" | values' " .. DeviceFileName)
       local DeviceIDToCheckBatteryLevel = handle:read("*n")
       handle:close()
       --Determine battery level
       local handle = io.popen("curl 'http://" .. DomoticzIP .. ":" .. DomoticzPort .. "/json.htm?type=devices&rid=" .. DeviceIDToCheckBatteryLevel .. "' 2>/dev/null | /usr/local/bin/jq -r .result[].BatteryLevel")
       local BattLevel = string.gsub(handle:read("*a"), "\n", "")
       handle:close()
       print(DeviceName .. ' batterylevel is ' .. BattLevel .. "%")
       -- Check batterylevel against setpoint
       if tonumber(BattLevel) < BatteryLevelSetPoint then
          BattToReplace = true
          print("!!!" .. DeviceName .. " batterylevel below " .. BatteryLevelSetPoint .. "%, current " .. BattLevel .. "%")
          Message = Message .. '\n *** ' .. DeviceName .. ' battery level is ' .. BattLevel .. '%'
    -- Only send an email if at least one battery fails the test
    if(BattToReplace) then
       commandArray['SendEmail']='Domoticz Battery Levels#'.. Message .. '#' .. EmailTo
--LUA default
Script 3 - Alternate LUA script
This script will execute once a day at the time that you specify. It will check all your used devices and send an email with a list of all devices below the battery threshold. Optionally you can also receive a weekly summary of all your battery devices and their current battery level regardless of the threshold.
This script will run on Linux or Windows and does not require an external json parsing library. It uses the json library provided with Domoticz. It also doesn't need to write any temporary json files to disk.
Instructions
Under Setup..More Options..Events add a new LUA script named battery_check to execute on 'time' and overwrite the sample code with the below script.
-- Check battery level for all used devices
-- User Configuration
BatteryThreshold = 40
WeeklySummary = true
SummaryDay = 1 -- Sunday is 1
EmailTo = "[email protected]"
ReportHour = 9
ReportMinute = 01
Domoticz = "localhost"
DomoticzPort = "8080"
Message = ''
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- linux
--json = (loadfile "C:\\Domoticz\\scripts\\lua\\json.lua")() -- windows
-- Weekly Device Battery Summary
if WeeklySummary == true and time.wday == SummaryDay and time.hour == ReportHour and time.min == ReportMinute then
    -- Get a list of all devices
    handle = io.popen("curl 'http://" .. Domoticz .. ":" .. DomoticzPort .. "/json.htm?type=devices&order=name'")
    devicesJson = handle:read('*all')
    handle:close()
    devices = json:decode(devicesJson)
    for i,device in ipairs(devices.result) do
        if device.BatteryLevel < 100 and device.Used == 1 then
            Message = Message .. device.Name .. ' battery level is ' .. device.BatteryLevel .. '%<br>'
            print(device.Name .. ' battery level is ' .. device.BatteryLevel .. '%')
-- Daily Low Battery Report
elseif time.hour == ReportHour and time.min == ReportMinute then
    handle:close()
        if device.BatteryLevel < BatteryThreshold and device.Used == 1 then
Script 4 - Alternative script using PHP, Pushover and CRONTAB
For people that have already PHP installed and want to use Pushover for alerts there is an alternative script that can be used using PHP instead of LUA. Create the following batt.php file in /home/pi/domoticz/scripts (fill in your Domoticz IP and port number for your_ip and your_port )
nano /home/pi/domoticz/scripts/batt.php
contents:
<?php
// Test if Battery level from sensors is still within range.
// If below, send pushover alert
// Called every 4 hours from crontab
$json = json_decode(file_get_contents('http://your_ip:your_port/json.htm?type=devices&order=name'));
$threshold = 65;
$hst = "";
foreach  ($json->result as $r) {
        if ($r->BatteryLevel > 0 && $r->BatteryLevel<$threshold) {
                $hst = $hst . $r->Name.": ".$r->BatteryLevel."%\n";
if ($hst) {
        $hst = "Batt Low:\n".$hst;
        echo $hst;
        $url = "https://api.pushover.net/1/messages.json";
        $data = array(
            "token" => "[ your pushover application token ]",
            "user" => "[ your pushover user token ]",
            "message" => $hst,
        $options = array(
                'http' => array(
                        'header'  => "Content-type: application/x-www-form-urlencoded\r\n",
                        'method'  => 'POST',
                        'content' => http_build_query($data),
        $context  = stream_context_create($options);
        $result = file_get_contents($url, false, $context);
        var_dump($result);
We do not use a varable called DevicesWithBatteries as with the LUA script. We simply loop through all devices and select the devices that have a battery level >0. Devices without a battery typically show a value of 0 or 255.
We then create a crontab file with root priviledges in /etc/cron.d
sudo nano /etc/cron.d/domoticzbatt
contents:
# Battery check run ever 6 hours at a few minutes past the hour
2 0,6,12,18     * * *   root    php /home/pi/domoticz/scripts/batt.php
