Doorbel a virtual Switch
From Domoticz Wiki
Revision as of 18:45, 24 July 2017 by Philchillbill (talk | contribs) (Your doorbell as switch in Domoticz.)
First you need to connect your 12 AV relays in parallel with your doorbell.
When your doorbell button is pressed, the contact of your relays will connect GPIO18 to ground.
Now install the software
sudo apt-get install python-dev python-pip
sudo install --upgrade distribute
sudo install ipython
sudo install --upgrade RPi.GPIO
This is the python script I made
# Doorbell py with read contact uitlezen,
# GPIO 18 to Ground when button is pushed
# Release 0.1/
# Author J. Jeurissen
# Copyright (c) 2015  J. Jeurissen
# Python 3
import urllib
import urllib.request
import json
import RPi.GPIO as GPIO
import time
# Settings for the domoticz server
domoticzserver="ipadres:8080"
domoticzusername = ""
domoticzpassword = ""
domoticzurl = 'http://'+domoticzserver+'/json.htm?type=command&param=switchlight&idx=170&switchcmd=On'
GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.IN, pull_up_down=GPIO.PUD_UP)
while True:
	input_state = GPIO.input(18)
	if input_state == False:
		print('Button Pressed')
		time.sleep(5.0)
Add in crontab the following line so your python script is always running
@reboot python3 /path/doorbel.py
