Talk:Wemo
From Domoticz
Revision as of 21:10, 16 February 2017 by Krizzz (talk | contribs) (Not Found)
The full IP adress isn't probably required, i think it will work also by using 127.0.0.1 (=localhost). Be sure to add 127.0.0.* to the trusted range of Domoticz (Setup >> Application settings). --ThinkPad (talk) 22:37, 28 January 2015 (CET)
Not Found
WHen doing the steps requested, and trying to make the script work. Domoticz report good behavior mentioning in the log that ""Admin initiated a switch command (37/Wemo/On). But nothing happens. Going back to the commandline, and trying to start the sh wemo_on.sh script, the following error has been given.
wemo_on.sh: 2: wemo_on.sh: /home/pi/domoticz/scripts/wemo_control: not found
When looking into the script, I followe the wiki and the path to the script is correct and the script is present in the directory: CODE: SELECT ALL pi@raspberrypi:~/domoticz/scripts/wemo$ ls -1 wemo_control.sh wemo_off.sh wemo_on.sh
Why can it not "find" the script? What am I missing?
