Installing and running Domoticz on CubieBoard2
From Domoticz Wiki
This guide is for installing domoticz on a cubieboard2 or cubietruck
Firmware Requirements
You need a microSD card from at least 4GB.
Please install the latest software from: https://www.armbian.com/download/
For cubietruck use: http://www.igorpecovnik.com/2013/12/24/cubietruck-debian-wheezy-sd-card-image/comment-page-1/
For cubieboard2 use: https://www.armbian.com/cubieboard-2/
Select the Mainline Jessie kernel 4.x.x image
For old cubieboard images:
after you boot for the first time (username root, password 1234), flash this image on the nand or ssd,
scripts can be found in the /root folder
This script (for nand at least) you have to execute 2 times
After you booted from the nand or ssd, update the system with:
Create Linaro user: Add a user called 'linaro'
adduser linaro
next add this user to the sudo group
adduser linaro sudo
next we make sure we do not need to enter a password when issuing a sudo command
visudo
at the bottom of this file place the following line:
linaro ALL=(ALL) NOPASSWD: ALL
For current images:
- after reboot (for 2 times), the disk is expanded automatically. You can login (username root, password 1234) via tty or ssh. You are asked to change pwd foor root. You are asked to add a sudo enabled user. Type "linaro" as user.
sudo apt-get update
sudo apt-get upgrade
Domoticz Setup
Login to your cubieboard with the "linaro" user (for windows you can use the program putty)
Setup you timezone with:
sudo dpkg-reconfigure tzdata
Installing from Binary (old images)
mkdir domoticz
cd domoticz
wget http://domoticz.sourceforge.net/beta/domoticz_linux_armv7l.tgz
tar xvfz domoticz_linux_armv7l.tgz
rm domoticz_linux_armv7l.tgz
Installing from Binary (new images)
Login as linaro user
cd ~
mkdir domoticz
cd domoticz
sudo curl -L install.domoticz.com | bash
follow the wizard.
- select http and or https access
- select used ports. I choose 80 (https) and 443 (https)
- select web root folder
Test Domoticz
old images:
First we are going to test if domoticz is correctly installed:
While still in the domoticz folder (if not issue: cd ~/domoticz)
./domoticz
domoticz should now start, to quit domoticz press control-c
current images
- open a browser, go to your website. (output of setup will show the ip and port info)
Make Domoticz startup at boot time (Also needed for Web Update) - auto done for installation "current images"
sudo cp domoticz.sh /etc/init.d
sudo chmod +x /etc/init.d/domoticz.sh
sudo update-rc.d domoticz.sh defaults
Edit the startup script and point the DAEMON location to point to the installation folder:
sudo nano /etc/init.d/domoticz.sh [ or use the vi editor ]
Change: DAEMON=/home/pi/domoticz/domoticz
In to: DAEMON=/home/linaro/domoticz/domoticz
If you want to use another web interface port change:
OPTIONS="-www 8080" For example: 8070
Start Domoticz
sudo service domoticz.sh start
Now connect with a browser ip:port to see if it is up and running.
Updating Domoticz
Use the Web Interface to update Domoticz (Setup->Check for Updates)
Choose Beta or Stable in the application settings
Compiling from scratch with CubieTruck (dualcore 1 GHz) takes 38:30 min.
