Panasonic TV
Panasonic TV Support
This plugin enables you to be able to see the TV is on or off. It also enables a pop up remote control.
Configuration
Under hardware add type PanasonicTV
Then after clicking Setup add the indvidual TV's
Once you have done this the Plugin should connect to the TV(s) and show under Switches.
TV Remote
Once the TV is seen as "On", the remote will be enabled, this allows you to change channel, Epg, volume, mute etc, the Stop, Play, FF, Rewind buttons won't do anything normally with the TV itself although if you have a device that supports CEC over HDMI then the commands will be passed through.
