Wake-up On Lan
From Domoticz
Revision as of 17:17, 20 August 2016 by Trixwood (talk | contribs)
Wake-up On Lan
Setup
In domoticz add the WOL hardware option, as ip address enter 255.255.255.255 or your network broadcast address.
For example if your network address is 192.168.0.xxx enter 192.168.0.255
Port number = 9 (default WOL port)
Next press the setup button and add your computers(nodes) that you wish to wake-up.
You need to enter MAC addresses like 11-22-33-44-55-66, these can be found with the following command:
Windows
ipconfig /all | more
Unix
ifconfig
You need to enable WOL in your bios, please consult google or
http://www.howtogeek.com/70374/how-to-geek-explains-what-is-wake-on-lan-and-how-do-i-enable-it
For each added node you will get one new light/switch device (push on) that you can use to wake-up the node
