Write Domoticz logfile to Synology Log Center
From Domoticz
Revision as of 16:09, 20 August 2016 by Trixwood (talk | contribs)
Configuration Synology DSM 5.2
  1. - Log on to Synology DSM 5.2 and open Log Center
  2. - Go to Storage Settings, Destination and choose a location to save the file for logging.
  3. - Apply
  4. - Go to Log Receiving, mark BSD format settings and use TCP and Port 514 or choose your own port number.
  5. - Apply
Configuration Raspberry
log on with Putty to the Rapsberry
Fist we need the change the location of the logfile from Domoticz. For this example we use /var/log/domoticz.log
cd /etc/init.d/
sudo nano domoticz.sh
Change the line witch starts with DAEMON_ARGS line this:
DAEMON_ARGS="-daemon -www 8080 -sslwww 443 -log /var/log/domoticz.log
note: remove the # from the line you want to use!!''
Restart Domoticz so the log file will be created in /var/log,
sudo service domoticz.sh restart
Installation syslog-ng
Log in as Root user
sudo –i
Install syslog-ng
sudo apt-get install syslog-ng
Open file syslog-ng.conf
nano /etc/syslog-ng/syslog-ng.conf
Add to # Sources
source s_domoticz { file("/var/log/domoticz.log"); };
Add to # Destinations and change the IP Synology and Portnr Log Center to your NAS.
destination d_centralsyslog { tcp( "IP Synology" port(Portnr Log Center) ); };
Add to # Log paths
log { source(s_domoticz); destination(d_centralsyslog); };
Restart syslog-ng
sudo service syslog-ng restart
Synology Log Center
  1. - Open Synology Log Center
  2. - Click on Log Search
  3. - Click on From Other Servers
  4. - Refresh screen with round Arrow (down right side of the screen)
If all went well you can now see the log file from Domoticz in Synology Log Center.
Logrotate
When you start using Synology Log Center it is best to also use logrotate. The Domoticz lofile grows very fast and logrotate will delete the log file at certain moments.
Create a file called domoticz in /etc/logrotate.d
sudo nano /etc/logrotate.d/domoticz
Put inside this file
rotate 4
weekly
missingok
notifempty
delaycompress
compress
postrotate
if [ -f /var/run/domoticz.pid ]; then
/etc/init.d/domoticz.sh restart > /dev/null
fi
endscript
Your Done.
