PHP: Store switch states and values in variables
From Domoticz
Revision as of 06:04, 4 February 2016 by Egregius (talk | contribs)
Purpose
Store switch states, device values etc in variables so they can be used in scripting or web design.
The complete code is available at https://github.com/Egregius/PHP-Custom-Floorplan-for-Domoticz
Dependencies - hardware / software / operating system
sudo apt-get install apache2 php5 php5-memcached sqlite3 php5-cli php5-dev make libsqlite3-0 libsqlite3-dev php5-sqlite php5-curl
This will install all nescessary packages to enable all functions of my scripts.
Domoticz Setup - switches, variables, version
Disable security for localhost 127.0.0.1
files/scripts
Create a subfolder 'secure' and protect it so it isn't accessible from the outside. In apache this can be done in the virtualhost file: basically we block everybody except localhost and the computer you use to develop.
<Directory /var/www/secure>
  Options Indexes FollowSymLinks MultiViews
  AllowOverride None
  order deny,allow
  Deny from All
  allow from 127.0.0.1
  allow from 192.168.0.10
</Directory>
secure/functions.php
All values are stored in variables based on the name of the device in lowercase.
The name is prepended with 2 letters. First is the type of device, second the stored value.
Examples:
$Toutside = temperature value of device 'outside'
$TIoutside = idx
$TToutside = last timestamp
$Ddining = On/Off state of dimmer 'dining'
$Dleveldining = dim level
$DIdining = idx
$DTdining = last timestamp
$Rbathroom = Setpoint temperature of device 'bathroom'
$RIbathroom = idx
$RTbathroom = last timestamp
All non specified devices are starting with S (switch):
$Skitchen = state of kitchen light
$SIkitchen = idx
$STkitchen = last timestamp
Code:
<?php
$domoticzurl='http://127.0.0.1:8080/json.htm?';
$domoticz=json_decode(file_get_contents($domoticzurl.'type=devices&used=true&plan=2'),true);//I only get devices on roomplan 2. This way I only get nescassary devices and the speed is at it best.
if($domoticz){
  foreach($domoticz['result'] as $dom) {
    (isset($dom['Type'])?$Type=$dom['Type']:$Type='None'); //Some devices don't have all Type fields filled
    (isset($dom['SwitchType'])?$SwitchType=$dom['SwitchType']:$SwitchType='None');
    (isset($dom['SubType'])?$SubType=$dom['SubType']:$SubType='None');
    $name=strtolower($dom['Name']); //Convert all switchnames to lowercase
    if($Type=='Temp + Humidity'||$Type=='Temp'){${'T'.$name}=$dom['Temp'];${'TI'.$name}=$dom['idx'];${'TT'.$name}=strtotime($dom['LastUpdate']);}
    else if($SwitchType=='Dimmer'){${'DI'.$name}=$dom['idx'];$dom['Status']=='Off'?${'D'.$name}='Off':${'D'.$name}='On';$dom['Status']=='Off'?${'Dlevel'.$name}=0:${'Dlevel'.$name}=$dom['Level'];${'DT'.$name}=strtotime($dom['LastUpdate']);}
    else if($Type=='Usage'&&$dom['SubType']=='Electric') ${'P'.$name}=substr($dom['Data'],0,-5);
    else if($Type=='Radiator 1'||$Type=='Thermostat') {${'RI'.$name}=$dom['idx'];${'R'.$name}=$dom['Data'];${'RT'.$name}=strtotime($dom['LastUpdate']);}
    else {
      if(substr($dom['Data'],0,2)=='On') ${'S'.$name}='On';
      else if(substr($dom['Data'],0,3)=='Off') ${'S'.$name}='Off';
      else if(substr($dom['Data'],0,4)=='Open') ${'S'.$name}='Open';
      else ${'S'.$name}=$dom['Data'];${'SI'.$name}=$dom['idx'];${'ST'.$name}=strtotime($dom['LastUpdate']);${'SB'.$name}=$dom['BatteryLevel'];}
  unset($domoticz,$dom);
