Lua - Powermonitor with Ping Using Telegram
DRAFT TO BE COMPLETED
Purpose
I live in a village where despite the recent expense to put all the cables in the village underground, our electricty supply comes to the village via overhead lines, which are susceptible to trip due to a number of safety related reasons. Sometimes they reset in a second, other times they need manual intervention so a 10 minute power cut every 3 months is not unknown. Recently, my residual current detectors (RCD) seem to have become rather sensitive and so while I can detect an external power cut by detecting 0 amps on the incoming supply using my Owl energy monitor, this doesn't tell me when one of my RCDs trip.
I have a Raspberry Pi WiFi access point powered from the downstairs mains which is on all the time, so by pinging this device I have a simple way of seeing if the power is off downstairs either due to external power cut or an RCD trip
Dependencies
Raspberry Pi, Raspbian (current 14/9/9), Telegram
Domoticz Setup - switches, variables, version
Domoticz v1.1970, 1 user varaible DownPowerFail - 0 = power on, 1 = power off
Installation instructions
Create the user variable DownPowerFail and set to 0. Create the script in lua scripts directory - change the ip address and change mail_name in the 2 calls to telegram to your telegram name.
=Script (comments to be completed)=
-- ~/domoticz/scripts/lua/script_time_downpowermonitor.lua
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference
function timeCount(numSec)
local nSeconds = numSec
if nSeconds == 0 then
return "0seconds"
local sTime = ""
local nHours = math.floor(nSeconds/3600)
local nMins = math.floor(nSeconds/60 - (nHours*60))
if(nHours > 0) then
sTime = sTime .. nHours
if(nHours == 1) then
sTime = sTime .. "hour "
sTime = sTime .. "hours "
if(nMins > 0) then
sTime = sTime .. nMins
if(nMins == 1) then
sTime = sTime .. "minute "
sTime = sTime .. "minutes "
local nSecs = math.floor(nSeconds - nHours*3600 - nMins *60)
if(nSecs > 0) then
sTime = sTime .. nSecs
if(nSecs == 1) then
sTime = sTime .. "second"
sTime = sTime .. "seconds"
return sTime
print('Checking Downstairs Power')
DownPowerFail = tonumber(uservariables['DownPowerFail'])
ping_success=os.execute('ping -c1 192.168.1.8')
if ping_success then
-- print('Ping success')
if(DownPowerFail == 1) then
interval = timedifference(uservariables_lastupdate['DownPowerFail'])
print('Downstairs Power Restored after ' .. timeCount(interval))
os.execute('/home/pi/telegram/scripts/generic/telegram.sh msg telegram_name "Downstairs Power Restored - back in contact with study WiFi after ' .. timeCount(interval) .. '"')
commandArray['Variable:DownPowerFail'] = '0'
-- print('Ping fail')
if(DownPowerFail == 0) then
commandArray['Variable:DownPowerFail'] = '1'
print('Downstairs Power Failed')
os.execute('/home/pi/telegram/scripts/generic/telegram.sh msg telegram_name "Downstairs Power Failed - lost contact with study WiFi"')
