Matter
From Domoticz Wiki
Revision as of 11:25, 1 May 2026 by Walter vl (talk | contribs)
This page is WIP!
From beta 2026.1 domoticz has a Matter integration based on matter.js
Matter.js server
For the matter integration to work you need a running matter-js-server (setup with docker: https://github.com/matter-js/matterjs-server/blob/main/docs/docker.md)
docker-compose.yml example:
services:
  matterjs-server:
    container_name: matterjs-server
    image: ghcr.io/matter-js/matterjs-server:latest
    read_only: true
    network_mode: host
    restart: unless-stopped
    volumes:
      - ./data:/data
Matter alone can run on your local network, e.g. with Tasmota32-nodes.
Thread Border router
If you want to use the wireless standard thread, that is needed for e.g. the new Ikea devices, you need a Thread-border-router.
There are many thread border routers available.
The commercial ones:
  • Apple TV
  • Apple Homepod
  • Google Nest Hub
  • Amazon Echo dot
  • Ikea dirigera (newest version)
Then there the open source ones:
Domoticz hardware gateway install
When matter.js is running you can add in Domoticz the Matter Hardware gateway and fill in the IP and port of your matter.js server eg 192.168.1.123:5580
Using Matter with Domoticz
Devices paired to the matter server are also being added to Domoticz and can be controlled from Domoticz User interface.
There is a setup button next to the Matter hardware in Domoticz that you can use, and you can also use the native web interface of the matterjs-server docker container (eg http://192.168.1.123:5580)
