DynamicDashboard
Dashboard Dynamic
Revision: 2026-04-05 Minimum build: 17635
Enabling Dashboard Dynamic
Dashboard Dynamic is opt-in per user. To enable it, go to My Profile (top-right menu) and check Use Dynamic Dashboard, then save. The Dashboard menu item will now open the dynamic dashboard instead of the classic one.
Administrators can also enable or disable it for any user via Setup → Users.
Overview
Dashboard Dynamic is a fully modular, drag-and-drop dashboard system for Domoticz. It replaces the fixed-layout classic dashboard with a flexible, personalized workspace where users can freely compose, resize, and arrange widgets to their liking.
Key characteristics:
- Per-user persistent layouts stored in the Domoticz database
- Multiple named dashboards per user
- Real-time device updates via the existing WebSocket (livesocket)
- Fully theme-aware using CSS custom properties (
--dz-*variables) - Responsive across screen sizes
Getting Started
Navigate to the Dashboard menu item. On first visit, a starter layout is created automatically containing a Clock, Sun Info, and Activity Log widget.
Toolbar (Compact Mode)
In view mode, a small floating pill bar appears in the top-right corner of the page. It contains:
- Dashboard name — click to open the switcher dropdown if multiple dashboards exist
- Pencil icon — enter Edit Mode
- Play icon — start/stop Kiosk mode (visible when 2+ dashboards exist)
The bar fades to 50% opacity when not hovered to stay out of the way.
Edit Mode
Press the pencil button or Ctrl+E to enter Edit Mode. The full toolbar appears at the top:
| Button | Action |
| ⓘ (info icon) | Opens the Dynamic Dashboard wiki page |
| Dashboard title | Click to rename inline |
| Dashboards | Switch between dashboards, create a new one, or open Dashboard Settings |
| Edit | Access layout actions (Set as Default, Export/Import, Duplicate, Delete, Clear) |
| Done Editing | Save changes and exit edit mode |
| Add Widget | Open the widget library panel |
| Save | Manually save current layout |
| Cancel | Discard unsaved changes (button turns red when there are unsaved changes) |
Dashboards dropdown:
| Item | Action |
| (dashboard name) | Switch to that dashboard (prompts to discard unsaved changes if needed) |
| New Dashboard | Creates a new dashboard with an auto-generated name; rename it via the title field |
| Dashboard Settings… | Open kiosk and standby settings |
Edit dropdown:
| Item | Action |
| Export / Import | Open the export/import dialog |
| Reset to Favorites | Populate the dashboard from your favorite devices |
| Set as Default | Mark this dashboard as the default (shown with a checkmark when active) |
| Duplicate | Clone the current dashboard |
| Delete | Delete the current dashboard |
| Clear All Widgets | Remove all widgets from the current dashboard |
Keyboard shortcuts:
Ctrl+E— toggle edit modeCtrl+S— save layoutCtrl+L— toggle widget library panelEscape— close widget library (if open), otherwise exit edit mode; also stops Kiosk mode
Widget Library
Click Add Widget to open the slide-in library panel on the right. Widgets are grouped by category. Use the search box to filter. Click a widget’s + button to add it to the grid.
Widget Actions (Edit Mode)
Each widget shows a header bar in edit mode with:
- Drag handle — drag the title bar to reposition
- Configure (gear icon) — open widget settings
- Duplicate (copy icon) — clone the widget; the clone starts dragging immediately
- Remove (× icon) — delete the widget
Resize any widget by dragging the bottom-right corner handle.
Note: All interactive elements inside widget content (buttons, links, inputs) are non-clickable in Edit Mode — only the header chrome buttons (configure, duplicate, remove) remain active. This prevents accidental device control while rearranging the layout.
Managing Dashboards
Multiple Dashboards
Dashboard management is done directly from the Edit Mode toolbar:
| Action | How |
| Create | Dashboards → New Dashboard (auto-names; rename inline) |
| Rename | Click the dashboard title in the toolbar |
| Switch | Dashboards dropdown → pick a name |
| Set as Default | Edit → Set as Default |
| Duplicate | Edit → Duplicate |
| Delete | Edit → Delete |
Dashboard Settings (Edit → Dashboard Settings… or Dashboards → Dashboard Settings…) contains only the Kiosk and Screen Standby configuration — no layout management.
Kiosk / Auto-Swipe Mode
Automatically cycles through a set of dashboards at a fixed interval — useful for wall tablets and kiosk displays.
Controls:
- Play/Stop button in the topbar (visible when 2+ dashboards exist)
- Escape key stops kiosk mode
- A thin progress bar at the bottom of the screen shows time remaining until the next switch
Settings (in Dashboard Settings → Kiosk section):
| Setting | Default | Description |
| Enable on load | off | Automatically start kiosk when page loads |
| Interval (seconds) | 30 | Time to display each dashboard (5–3600) |
| Loop | on | Return to first dashboard after the last |
| Dashboards to cycle | all | Check specific dashboards to include; leave all unchecked to cycle all |
Settings are saved in browser localStorage (dd_kiosk).
Screen Standby Mode
Dims or blanks the screen after a period of inactivity — prevents burn-in on wall-mounted displays. Any mouse movement, touch, keystroke, or click wakes the screen.
Settings (in Dashboard Settings → Screen Standby section):
| Enable standby | off | Enable inactivity dimming |
| Inactivity timeout | 5 min | Minutes before screen dims (1–60) |
| Full blackout | off | Completely black screen instead of dimmed |
| Opacity when dimmed | 5% | Screen brightness when dimmed (0–30%) |
Settings are saved in browser localStorage (dd_standby).
Export / Import
The Export / Import button opens a modal dialog with two tabs:
Export tab:
- Clipboard — generates JSON and lets you copy it to the clipboard for sharing (e.g. in forum posts)
- Download — downloads the dashboard as a
.jsonfile - Choose to export the current dashboard or all dashboards
The exported JSON includes the Domoticz build revision (domoticzRevision) so recipients know the minimum version needed.
Import tab:
- Clipboard — paste JSON directly from the clipboard
- File — select a
.jsonfile from disk - Choose to import as a new dashboard or replace current
- If the imported dashboard was created on a newer Domoticz build, a warning is shown (but import still proceeds)
Widgets
Widgets are grouped into the following categories: Info, Charts & Data, Energy, Devices, Controls, Weather, Information, System, Custom Content.
Clock
Category: Custom Content
Displays the current local time and date. Updates every second.
Configuration:
| Field | Default | Description |
| Show seconds | on | Include seconds in the time display |
| 24-hour format | on | Use 24h clock; off for 12h with AM/PM |
| Show date | on | Show the date line below the time |
| Timezone | local | Timezone for the displayed time; search by city or region name |
| Show panel background | on | Show the widget panel background |
Sun Info
Category: Weather
Shows today’s sunrise and sunset times, derived from the configured location in Domoticz settings.
Configuration:
Weather
Category: Weather
Displays current weather conditions with an animated weather scene background (sun, clouds, rain, snow, moon/stars at night).
Configuration:
| Field | Description |
| Temperature device | Any Temp / Temp+Hum / Temp+Hum+Baro device |
| Wind device | A Wind type device |
| Barometer device | A Temp+Baro or Temp+Hum+Baro device |
| Display style | Style 1 (default) or Style 2 (see below) |
| Show panel background | Show the widget panel background (default: on) |
Style 1: Data-dense view with the animated weather scene as a background. Shows temperature, wind speed/direction, barometer, humidity, and forecast string as individual rows.
Style 2: Full-height immersive scene card. The animated scene fills the widget (sun rays / moon + stars / clouds / rain / snow), with large temperature and forecast string centered over it. Includes dew point, humidity, and barometer. Night mode activates automatically between sunset and sunrise.
Live: updates instantly from WebSocket device updates.
Stat Counter
Category: Charts & Data
Displays a single large KPI number from any device.
Configuration:
| Device | Any used device |
| Label | Optional custom label (defaults to device name) |
Live: updates instantly from WebSocket device_update events.
Temperature Graph
Highcharts chart showing temperature history.
Configuration:
| Device | Temperature / Temp+Hum type device |
| Chart type | See table below |
| Custom title | Optional override |
Chart types:
| Type | Description |
| Last 24h | Hourly temperature spline |
| Last 7 days | Daily temperature spline |
| Last month | Daily temperature spline |
| Last year | Monthly temperature spline |
| Dew Point | Temperature + dew point dual-line |
| Temp vs Humidity | Temperature and humidity with dual y-axis |
| Comfort Zone | Temperature/humidity scatter plot with comfort zone bands |
Counter / Energy Chart
Column or area chart for counter and energy devices (kWh, Gas, Water, P1, generic counter). Automatically detects the device type and display unit.
Configuration:
| Device | Counter / kWh / Gas / Water / P1 Meter device |
Chart types:
| Short Log | Area chart of recent power readings (W) — high resolution, last few hours |
| Today | Hourly bars |
| Last week | Daily bars |
| Last month | Daily bars |
| Last year | Monthly bars |
| Compare years | Multiple years overlaid as grouped bars per month |
P1 Smart Meters with return capability display import and export as two separate series.
Zooming: Drag horizontally on any chart to zoom in on a time range. A Reset zoom button appears to return to the full view.
Wind Chart
Wind data charts for a Wind type device.
Configuration:
| Device | Wind type device |
| Title | Optional override |
Chart types:
| Last 24h | Speed + gust line chart. Tooltips show Beaufort scale notation (Calm, Light Breeze, Strong Breeze, etc.) |
| Wind Direction | Wind rose (polar chart) showing frequency per direction sector |
| Speed Frequency | Histogram of wind speed occurrences |
| Last Month | Daily average speed bars |
| Last Year | Monthly average speed bars |
Rain Chart
Rain data charts for a Rain type device.
Configuration:
| Device | Rain type device |
Chart types:
| Last 24h | Rain rate (mm/h) line + cumulative total area, dual y-axis |
| Last week | Daily total bars |
| Last month | Daily total bars |
| Last year | Monthly total bars |
Gauge
Circular arc gauge showing the current value of any numeric device against a configurable min/max range with colour-coded thresholds.
Configuration:
| Device | — | Any numeric device |
| Title | device name | Optional override |
| Min | 0 | Minimum scale value |
| Max | 100 | Maximum scale value |
| Unit | % | Display unit |
| Warn threshold | 50 | Value where colour shifts from first to second zone |
| Critical threshold | 80 | Value where colour shifts from second to third zone |
| Threshold mode | low-is-good | low-is-good (e.g. CPU load): green → yellow → red as value rises. high-is-good (e.g. battery %): red → yellow → green as value rises |
The gauge is rendered as a pure SVG arc — no Highcharts required. The fill animates smoothly on value changes.
Live: refreshes every 30 seconds and on WebSocket device_update for the configured device.
Custom Chart
Free-form Highcharts chart where you can combine up to 10 sensors (temperature, counter, humidity, rain, wind, etc.) on a single chart with a shared time range.
Configuration:
| Time range | Last 24h | Last 24h / Last 7 days / Last month / Last year |
| Title | — | Optional chart title |
| Show legend | on | Toggle chart legend |
| Device 1–10 | — | Up to 10 device pickers; each added device becomes one series |
The sensor type and y-axis unit are detected automatically from the device type. Series with matching units share a y-axis; incompatible units get separate axes.
kWh Summary
Category: Energy
Compact stat card showing current power (W) and today’s energy total (kWh).
Configuration:
| Device | Energy / Counter type device |
| Title | Optional override (defaults to device name) |
| Color | Token color: import (orange) / export (green) / solar (yellow) / gas (red) |
Live: refreshes every 30 seconds and on WebSocket device updates.
Gas Summary
Category: Energy
Compact stat card showing today’s gas usage and cumulative total.
Configuration:
| Device | Gas type device |
Live: refreshes every 60 seconds and on WebSocket device updates.
P1 Electricity
Category: Energy
Dedicated widget for Dutch P1 smart meters showing current import/export power and today’s totals.
Configuration:
| Device | P1 Electricity Meter device |
| Show price | Show today’s cost (if reported by meter) |
Displays an up-arrow (exporting) or down-arrow (importing) with current watts, coloured green for export and orange for import. Sub-line shows today’s totals for both directions.
Battery Status
Category: Energy
Battery energy storage widget showing today’s imported/exported kWh, net, and live SOC / watts / voltage.
Configuration:
| Auto mode | Read device IDs from the Energy Dashboard settings |
| Battery energy in | Manual: import kWh device |
| Battery energy out | Manual: export kWh device |
| Battery SOC | Manual: state-of-charge % sensor |
| Battery watts | Manual: current power device |
| Battery voltage | Manual: voltage sensor |
When Auto mode is on, device IDs are read automatically from getenergydashboarddevices — zero extra configuration if the Energy Dashboard is already set up.
Live: refreshes every 60 seconds.
Energy Dashboard
Category: Energy
Full energy overview widget — combines all cards (Weather, Grid, Solar, Gas, Battery) and the self-sufficiency balance bar in one resizable widget. Lifted directly from forecast.html.
Configuration:
| Show weather card | on | Weather conditions |
| Show solar card | on | Solar power and yield |
| Show gas card | on | Gas usage |
| Show battery card | on | Battery status |
| Show balance bar | on | Self-sufficiency stats |
| Refresh interval | 60s | Seconds between data refresh |
Device IDs are read automatically from the Energy Dashboard settings (getenergydashboarddevices).
Self-Sufficiency
Category: Energy
Compact bar showing energy self-sufficiency percentage and today’s balance stats (house consumption, solar yield, battery net). Device IDs are read automatically from the Energy Dashboard settings.
Configuration:
| Show gauge bar | on | Green→red percentage bar |
Self-sufficiency formula:
batNet = batCharge - batDischarge houseConsumption = p1Import + solar - p1Export - batNet selfSufficiency = (solar + batDischarge) / houseConsumption × 100
Result is clamped to 0–100%. Battery discharge counts as local generation — energy stored earlier from solar and discharged later correctly reduces grid dependence.
Text Sensor
Category: Devices
Displays the text value (Data field) of a Domoticz Text sensor device.
Configuration:
| Device | — | Text sensor device |
| Show title | on | Show device name as header |
| Font size | 14px | Text size in pixels |
| Refresh interval | 60s | Seconds between refresh |
Content preserves whitespace and line breaks. Live: re-fetches immediately on WebSocket device_update for the configured device.
Device
Category: Devices
Embeds any single Domoticz device using its native widget (the same widget used in the classic dashboard).
Configuration:
| Device | Any device |
The background is transparent in view mode. Live: instant WebSocket updates.
Scene / Group
Category: Devices
Embeds a Domoticz scene or group with its native widget.
Configuration:
| Scene or Group | Any defined scene or group |
Live: WebSocket scene_update events.
Favorites
Category: Devices
Shows all favorite devices grouped by category, reproducing the classic dashboard tabs in a single widget.
Configuration:
| Category filter | All / Switches & Lights / Temperature / Weather / Utility |
| Limit to room/plan | Optional plan ID |
| Show category tabs | Toggle tab bar |
| Custom Title | Optional override |
Live: WebSocket device_update / scene_update + 60s polling fallback.
Room / Plan
Category: Devices
Shows all devices belonging to a specific Domoticz plan (room).
Configuration:
| Plan / Room ID | Numeric ID of the plan |
Live: WebSocket device_update / scene_update.
Setpoint
Category: Controls
Display and control a Domoticz setpoint device with +/− step buttons and a click-to-edit popup.
Configuration:
| Device | — | Setpoint type device |
Step, min, max, and unit are read automatically from the device. Clicking the value opens a number input popup (pre-filled with current value) for direct entry. Commands use setdevice&idx=X&setpoint=Y. Live: WebSocket device updates re-fetch the current value.
Thermostat
Category: Controls
Combined widget showing current temperature from a sensor alongside setpoint controls. Ideal for room thermostats.
Configuration:
| Temperature sensor | — | Temp / Temp+Hum sensor |
| Setpoint device | — | Setpoint device |
| Title | — | Optional override |
Step, min, max, and unit are read automatically from the setpoint device. Displays the current temperature large and prominent, with +/− setpoint controls below. Both devices are fetched in a single API call.
Thermostat6
Category: Controls
Widget for the Thermostat6 device type. Displays all available measured values (Temp, Humidity + status, Barometer) and setpoint controls. Only rows for values present on the device are shown.
Configuration:
| Device | — | Thermostat6 device |
Step, min, and max are read automatically from the device.
Weather Forecast
Category: Weather
Multi-day weather forecast using the Open-Meteo API (free, no API key required). Location is read automatically from Domoticz settings.
Configuration:
| Days | 7 | Forecast days to display (1–14) |
| Show wind | on | Wind speed row |
| Show precipitation | on | Precipitation row |
| Title | Weather Forecast | Optional override |
Displays a horizontal grid of day columns, each with a weather icon (mapped from WMO weather codes), temperature range, precipitation (mm), and wind speed (km/h).
Data is cached for 30 minutes to avoid excessive API calls.
RSS Feed
Category: Information
Displays items from any RSS or Atom feed.
Configuration:
| Feed URL | — | Full URL of the RSS/Atom feed |
| Max items | 5 | Items to display (1–20) |
| Refresh interval | 300s | Seconds between fetches |
| Show images | on | Show thumbnail images |
| Show date | on | Show relative timestamp |
| Open in new tab | on | Links open in a new browser tab |
| Title | feed title | Optional override |
Fetches feeds via the rss2json.com proxy (free tier, no API key needed) which solves CORS limitations.
Single item mode (Max items: 1): Shows the latest item with a large image, headline, and excerpt.
Multi-item mode: Shows a scrollable list with thumbnails, truncated titles, and relative timestamps (“2h ago”, “3d ago”). Each item has a link icon to open the original article.
Google Calendar
Displays upcoming events from a Google Calendar or any ICS-compatible calendar, grouped as Today / Tomorrow / upcoming days.
Configuration:
| Calendar URL | — | Public ICS URL or Google Calendar API endpoint |
| Max events | 7 | Maximum upcoming events to show |
| Show time | on | Show event start time |
| Refresh interval | 900s | Seconds between fetches (minimum 60) |
| Title | Calendar | Optional override |
Getting a Google Calendar ICS URL: In Google Calendar → Settings → click the calendar → Integrate calendar → copy the Secret address in iCal format (ends in .ics).
Using the Google Calendar JSON API: Requires a public calendar and a Google API key:
https://www.googleapis.com/calendar/v3/calendars/{calendarId}/events
?key={apiKey}&orderBy=startTime&singleEvents=true&timeMin={now}
The widget auto-detects .ics vs JSON API URLs.
CORS handling: The widget fetches calendar data using a fallback chain:
- Direct request (works for CORS-friendly URLs)
- Domoticz server-side proxy (
json.htm?type=command¶m=fetchurl&url=<encoded>) — avoids CORS entirely for any URL reachable from the Domoticz server - Public CORS proxies (corsproxy.io / codetabs) as last resort
A helpful error message is shown if all methods fail.
Past events today are shown in muted color. All-day events display without a time.
System Log
Category: System
Displays recent Domoticz system log entries with filter toggles.
Configuration:
| Max entries | 50 | Log lines to display |
| Show Normal | on | Show Normal (white) entries |
| Show Status | on | Show Status (blue) entries |
| Show Error | on | Show Error (red) entries |
| Auto-refresh | 10s | Seconds between refresh (0 = off) |
| Title | System Log | Optional override |
Toggle buttons in the widget header show the count per level (e.g. N 42, S 8, E 2) and can be clicked to show/hide each level. The Error button is coloured red when errors are present. A refresh button is also available.
Moon Phase
Shows the current moon phase with a large emoji graphic, phase name, illumination percentage, and next full/new moon date. Calculated entirely in JavaScript — no external API required.
Configuration:
| Show phase name | on | Display phase label (e.g. “Waxing Gibbous”) |
| Show next event | on | Next full moon or new moon date |
| Show illumination | on | Illumination percentage |
| Title | Moon | Optional override |
Phase names: New Moon 🌑, Waxing Crescent 🌒, First Quarter 🌓, Waxing Gibbous 🌔, Full Moon 🌕, Waning Gibbous 🌖, Last Quarter 🌗, Waning Crescent 🌘.
Updates daily.
Quick Actions
One-click buttons to trigger scenes and control switch devices, displayed in a grid or list layout.
Supported device types:
| Type | Behaviour |
| Switch | Toggle button; icon tinted when device is On |
| Push On / Push Off | Dedicated On or Off button; no toggle, no state indicator |
| Selector switch | Shows current level text; click opens an inline level picker |
| Blind | Up / Close buttons, plus optional Stop button (shown automatically when the device supports it) |
| Scene | One-click activate button |
Configuration:
| List layout | off | Display actions as a vertical list (label left, icon/status right) instead of a grid |
Action list editor:
Use the action list to add, reorder, and remove actions. Drag the grip handle (⠿) to reorder. Click the pencil icon to rename; click the trash icon to delete.
To add an action:
- Select Device or Scene from the type dropdown
- Pick the device or scene from the searchable picker (only switch-type devices are shown)
- For selector switches: the level is not chosen here — it is selected at click-time in the widget
- Optionally enter a custom label (auto-filled from device/scene name if blank)
- Click + to add
In the widget:
- Click a switch button to toggle it; the icon turns accent-coloured when the device is On
- Click a selector button to open the inline level picker; the current level is shown beneath the label; the active level is highlighted
- Blind Up/Stop/Close buttons are shown as a compact group with the label on the left
Text Note
Displays custom text with configurable appearance. Useful for section headers, labels, or status messages.
Configuration:
| Content | — | The text to display |
| Font | Default (theme) | Default (theme), Arial, Verdana, Tahoma, Trebuchet MS, Helvetica Neue, Georgia, Times New Roman, Palatino, Courier New, Lucida Console, Impact, System UI |
| Size | 14 px | Font size in pixels (8–72) |
| Alignment | Center | Left / Center / Right |
| Style | Normal | Normal / Bold / Italic / Bold + Italic / Underline |
| Text color | rgba(255,255,255,1) | Color + opacity picker |
| Background color | rgba(0,0,0,0) | Color + opacity picker (default: transparent) |
HTML Widget
Renders arbitrary HTML inside a sandboxed <iframe>. Full documents (<html>…</html>) and plain snippets are both supported.
Configuration:
| Widget Title | — | Optional label overlaid at the top of the widget |
| HTML Content | — | Full HTML document or a snippet |
| Allow backend API access | off | Adds allow-same-origin to the sandbox, enabling scripts to call json.htm and other Domoticz API endpoints
Security: By default the iframe runs with sandbox="allow-scripts" — scripts execute in isolation and cannot access cookies, localStorage, or the parent page. Enabling Allow backend API access lifts the origin restriction so scripts can make authenticated requests to the Domoticz backend. Only enable this for HTML you wrote yourself.
Camera Feed
Category: Controls
Shows a live snapshot image from a Domoticz-configured camera.
Configuration:
| Camera | — | Pick from configured cameras |
| Refresh interval | 5s | Seconds between snapshot refreshes |
| Show camera name | on | Display the camera name in the widget header |
Remote Image
Displays a remote image from a URL, with optional auto-refresh.
Configuration:
| Image URL | — | Full URL to the image |
| Caption | — | Optional label shown over the image |
| Fit | Contain | Contain (full image visible) / Cover (fill area, crop) / Stretch to fill |
| Refresh interval | 0 | Seconds between reloads; 0 = no auto-refresh |
Website Embed
Embeds any external website or web app in an iframe.
Configuration:
| URL | — | The page to embed (https:// recommended) |
| Title | — | Optional widget header label |
| Allow scripts | off | Enable JavaScript in the embedded page (trusted sources only) |
| Auto-reload | 0 | Seconds between iframe reloads; 0 = off |
Note: Many external sites block iframe embedding via X-Frame-Options. Works best with local network pages.
Battery Monitor
Category: System
Shows all Domoticz devices whose battery level is at or below a configurable threshold — a maintenance overview so you know which sensors need fresh batteries.
Configuration:
| Threshold | 25% | Show devices at or below this battery level |
| Show all | off | When on, shows every device with a battery (above threshold shown in muted style) |
| Sort by | level | Sort by battery level ascending, or by device name |
| Refresh interval | 300s | Seconds between refresh (5 minutes) |
| Title | Battery Monitor | Optional override |
Battery level colours: ≤10% red, ≤25% orange, ≤50% yellow, >50% green. When nothing is below the threshold, a green “All batteries OK” message is shown. Devices without a battery (level = 255 in Domoticz) are always excluded.
Timeout Monitor
Category: System
Shows all Domoticz devices that have not reported within their expected timeout interval — a quick way to spot sensors that have gone silent or lost power.
Configuration:
| Title | (empty) | Optional title override |
| Sort by | Last update | Sort by last update time (oldest first) or device name (A–Z) |
| Refresh interval | 300s | Seconds between refresh |
When no devices are timed out, nothing is shown in the list. The device list shows each device name and how long ago it last reported (e.g. “3h ago”).
kWh Top Consumers
Category: System
Lists kWh-metered devices ranked by today’s energy consumption, highest first. Useful for spotting which appliances are using the most energy on any given day.
Each row shows the device name, current power draw (W), and today’s total (kWh). The list updates instantly via WebSocket when any tracked device reports — including devices currently off-screen due to the row limit, which may move up the ranking in real time.
Excluded automatically: - Devices from P1 Smart Meter hardware (L1/L2/L3 phase sensors, both serial and LAN variants) - Devices configured as type Return / Energy Generated (e.g. solar export meters) - Devices that have timed out
Configuration:
| Max devices to show | 20 | Maximum number of rows displayed |
| Exclude device IDX | (empty) | Semicolon-separated list of device IDX values to hide (e.g. 42;107)
| Refresh interval | 300s | Seconds between full refresh from the backend |
Activity Log
Category: System
Shows the most recently updated devices, ordered by last update time.
Configuration:
| Max items | 5–50 items (default 15) |
Live: reloads on every WebSocket device update and polls every 15 seconds.
System Status
Category: System
Shows Domoticz version, build number, and hardware count. No configuration required.
Live Update Reference
| Widget | Update method |
| Clock | 1-second interval |
| Device / Scene | Instant — WebSocket |
| Stat Counter | Instant — WebSocket (no HTTP) |
| Weather | Instant — WebSocket per sensor |
| Activity Log | Instant — WebSocket |
| Favorites / Room | Instant — WebSocket + 60s fallback |
| Temperature Graph | 60s debounced reload on device update |
| Counter/Energy Chart | 60s debounced reload on device update |
| Wind / Rain Chart | 60s debounced reload |
| kWh Summary | 30s interval + instant WebSocket |
| P1 Electricity | 30s interval + instant WebSocket |
| Gas Summary | 60s interval + instant WebSocket |
| Battery Status | 60s interval |
| Energy Dashboard | 60s interval |
| Self-Sufficiency | Configurable interval (default 60s) |
| Text Sensor | Configurable interval + instant WebSocket |
| Setpoint / Thermostat | 30s interval + WebSocket |
| Thermostat6 | 30s interval + WebSocket |
| System Log | Configurable interval (default 10s) |
| Weather Forecast | 30-minute interval (cached) |
| RSS Feed | Configurable interval (default 5 min) |
| Google Calendar | Configurable interval (default 15 min) |
| Moon Phase | Daily |
| Gauge | 30s interval + instant WebSocket |
| Battery Monitor | Configurable interval (default 5 min) |
| Timeout Monitor | Configurable interval (default 5 min) |
| kWh Top Consumers | Configurable interval (default 5 min) + instant WebSocket per tracked device |
| Custom Chart | 60s debounced reload on config/range change |
| Sun Info / Text Note / HTML / Image | Static |
| Website Embed | Configurable auto-reload interval (default off) |
| Camera Feed | Configurable interval (default 5s) |
