DynamicDashboard
From Domoticz Wiki
Revision as of 07:22, 3 April 2026 by Gizmocuz (talk | contribs) (Created page with "<span id="dashboard-dynamic"></span> = Dashboard Dynamic = '''Revision:''' 2026-04-03 '''Minimum build:''' 17584 ----- <span id="enabling-dashboard-dynamic"></span> == Enabling Dashboard Dynamic == Dashboard Dynamic is opt-in per user. To enable it, go to '''My Profile''' (top-right menu) and check '''Use Dynamic Dashboard''', then save. The '''Dashboard''' menu item will now open the dynamic dashboard instead of the classic one. Administrators can also enable or di...")
Dashboard Dynamic
Revision: 2026-04-03 Minimum build: 17584
Dashboard Dynamic is opt-in per user. To enable it, go to My Profile (top-right menu) and check Use Dynamic Dashboard, then save. The Dashboard menu item will now open the dynamic dashboard instead of the classic one.
Administrators can also enable or disable it for any user via Setup → Users.
Overview
Dashboard Dynamic is a fully modular, drag-and-drop dashboard system for Domoticz. It replaces the fixed-layout classic dashboard with a flexible, personalized workspace where users can freely compose, resize, and arrange widgets to their liking.
Key characteristics:
  • Per-user persistent layouts stored in the Domoticz database
  • Multiple named dashboards per user
  • Real-time device updates via the existing WebSocket (livesocket)
  • Fully theme-aware using CSS custom properties (--dz-* variables)
  • Responsive across screen sizes
Getting Started
Navigate to the Dashboard menu item. On first visit, a starter layout is created automatically containing a Clock, Sun Info, and Activity Log widget.
Toolbar (Compact Mode)
In view mode, a small floating pill bar appears in the top-right corner of the page. It contains:
  • Dashboard name — click to open the switcher dropdown if multiple dashboards exist
  • Pencil icon — enter Edit Mode
  • Play icon — start/stop Kiosk mode (visible when 2+ dashboards exist)
The bar fades to 50% opacity when not hovered to stay out of the way.
Edit Mode
Press the pencil button or Ctrl+E to enter Edit Mode. The full toolbar appears at the top:
Button Action
Dashboard title Click to rename inline
Dashboards Switch between or manage dashboards
Done Editing Save changes and exit edit mode
Add Widget Open the widget library panel
Save Manually save current layout
Export / Import Open the export/import dialog
Cancel Discard unsaved changes
Keyboard shortcuts:
  • Ctrl+E — toggle edit mode
  • Ctrl+S — save layout
  • Escape — exit edit mode (saves if dirty); also stops Kiosk mode
Widget Library
Click Add Widget to open the slide-in library panel on the right. Widgets are grouped by category. Use the search box to filter. Click a widget’s + button to add it to the grid.
Widget Actions (Edit Mode)
Each widget shows a header bar in edit mode with:
  • Drag handle — drag the title bar to reposition
  • Configure (gear icon) — open widget settings
  • Duplicate (copy icon) — clone the widget; the clone starts dragging immediately
  • Remove (× icon) — delete the widget
Resize any widget by dragging the bottom-right corner handle.
Managing Dashboards
Multiple Dashboards
Click Dashboards → Manage Dashboards… to open the dashboard manager where you can:
  • Create new dashboards
  • Rename existing dashboards
  • Set a dashboard as default
  • Copy a dashboard
  • Delete dashboards
  • Configure Kiosk / Auto-Swipe settings
  • Configure Screen Standby settings
Kiosk / Auto-Swipe Mode
Automatically cycles through a set of dashboards at a fixed interval — useful for wall tablets and kiosk displays.
Controls:
  • Play/Stop button in the topbar (visible when 2+ dashboards exist)
  • Escape key stops kiosk mode
  • A thin progress bar at the bottom of the screen shows time remaining until the next switch
Settings (in Dashboard Manager → Kiosk section):
Setting Default Description
Enable on load off Automatically start kiosk when page loads
Interval (seconds) 30 Time to display each dashboard (5–3600)
Loop on Return to first dashboard after the last
Dashboards to cycle all Check specific dashboards to include; leave all unchecked to cycle all
Settings are saved in browser localStorage (dd_kiosk).
Screen Standby Mode
Dims or blanks the screen after a period of inactivity — prevents burn-in on wall-mounted displays. Any mouse movement, touch, keystroke, or click wakes the screen.
Settings (in Dashboard Manager → Screen Standby section):
Enable standby off Enable inactivity dimming
Inactivity timeout 5 min Minutes before screen dims (1–60)
Full blackout off Completely black screen instead of dimmed
Opacity when dimmed 5% Screen brightness when dimmed (0–30%)
Settings are saved in browser localStorage (dd_standby).
Export / Import
The Export / Import button opens a modal dialog with two tabs:
Export tab:
  • Clipboard — generates JSON and lets you copy it to the clipboard for sharing (e.g. in forum posts)
  • Download — downloads the dashboard as a .json file
  • Choose to export the current dashboard or all dashboards
The exported JSON includes the Domoticz build revision (domoticzRevision) so recipients know the minimum version needed.
Import tab:
  • Clipboard — paste JSON directly from the clipboard
  • File — select a .json file from disk
  • Choose to import as a new dashboard or replace current
  • If the imported dashboard was created on a newer Domoticz build, a warning is shown (but import still proceeds)
Widgets
Widgets are grouped into the following categories: Info, Charts & Data, Energy, Devices, Controls, Weather, Information, System, Custom Content.
Clock
Category: Info
Displays the current local time and date. No configuration required. Updates every second.
Sun Info
Category: Weather
Shows today’s sunrise and sunset times, derived from the configured location in Domoticz settings. No configuration required.
Weather
Category: Weather
Displays current weather conditions with an animated weather scene background (sun, clouds, rain, snow, moon/stars at night).
Configuration:
Field Description
Temperature device Any Temp / Temp+Hum / Temp+Hum+Baro device
Wind device A Wind type device
Barometer device A Temp+Baro or Temp+Hum+Baro device
Display style Style 1 (default) or Style 2 (see below)
Style 1: Data-dense view with the animated weather scene as a background. Shows temperature, wind speed/direction, barometer, humidity, and forecast string as individual rows.
Style 2: Full-height immersive scene card. The animated scene fills the widget (sun rays / moon + stars / clouds / rain / snow), with large temperature and forecast string centered over it. Includes dew point, humidity, and barometer. Night mode activates automatically between sunset and sunrise.
Live: updates instantly from WebSocket device updates.
Stat Counter
Category: Charts & Data
Displays a single large KPI number from any device.
Configuration:
Field Description
Device Any used device
Label Optional custom label (defaults to device name)
Live: updates instantly from WebSocket device_update events.
Temperature Graph
Highcharts chart showing temperature history.
Configuration:
Field Description
Device Temperature / Temp+Hum type device
Chart type See table below
Custom title Optional override
Chart types:
Type Description
Last 24h Hourly temperature spline
Last 7 days Daily temperature spline
Last month Daily temperature spline
Last year Monthly temperature spline
Dew Point Temperature + dew point dual-line
Temp vs Humidity Temperature and humidity with dual y-axis
Comfort Zone Temperature/humidity scatter plot with comfort zone bands
Counter / Energy Chart
Column chart for counter and energy devices (kWh, Gas, Water, P1, generic counter). Automatically detects the device type and display unit.
Configuration:
Field Description
Device Counter / kWh / Gas / Water / P1 Meter device
Chart types:
Type Description
Today Hourly bars
Last week Daily bars
Last month Daily bars
Last year Monthly bars
Compare months Multiple years overlaid as grouped bars
P1 Smart Meters with return capability display import and export as two separate series.
Wind Chart
Wind data charts for a Wind type device.
Configuration:
Field Description
Device Wind type device
Title Optional override
Chart types:
Type Description
Last 24h Speed + gust line chart. Tooltips show Beaufort scale notation (Calm, Light Breeze, Strong Breeze, etc.)
Wind Direction Wind rose (polar chart) showing frequency per direction sector
Speed Frequency Histogram of wind speed occurrences
Last Month Daily average speed bars
Last Year Monthly average speed bars
Rain Chart
Rain data charts for a Rain type device.
Configuration:
Field Description
Device Rain type device
Chart types:
Type Description
Last 24h Rain rate (mm/h) line + cumulative total area, dual y-axis
Last week Daily total bars
Last month Daily total bars
Last year Monthly total bars
Gauge
Circular arc gauge showing the current value of any numeric device against a configurable min/max range with colour-coded thresholds.
Configuration:
Field Default Description
Device Any numeric device
Title device name Optional override
Min 0 Minimum scale value
Max 100 Maximum scale value
Unit % Display unit
Warn threshold 50 Value where colour shifts from first to second zone
Critical threshold 80 Value where colour shifts from second to third zone
Threshold mode low-is-good low-is-good (e.g. CPU load): green → yellow → red as value rises. high-is-good (e.g. battery %): red → yellow → green as value rises
The gauge is rendered as a pure SVG arc — no Highcharts required. The fill animates smoothly on value changes.
Live: refreshes every 30 seconds and on WebSocket device_update for the configured device.
Custom Chart
Free-form Highcharts chart where you can combine any number of sensors (temperature, counter, humidity, rain, wind, etc.) on a single chart with a shared time range.
Configuration:
Series (JSON) [] JSON array defining each series (see format below)
Time range day Last 24h / Last 7 days / Last month / Last year
Title Optional chart title
Left axis label Label for the left y-axis
Right axis label Label for the right y-axis
Show legend on Toggle chart legend
Series JSON format:
  { "idx": 123, "sensor": "temp",    "label": "Living Room", "color": "#ff6600", "axis": 1 },
  { "idx": 456, "sensor": "counter", "label": "Power (W)",   "color": "#43a4d3", "axis": 2 },
  { "idx": 789, "sensor": "humidity","label": "Humidity",    "color": "#66bb6a", "axis": 1 }
Series field Required Description
idx yes Domoticz device index
sensor no temp, counter, humidity, rain, wind, lux, uv, setpoint — default temp
label no Series name in legend (defaults to “Series N”)
color no Hex color (e.g. "#ff6600"); omit to use Highcharts defaults
axis no 1 = left y-axis (default), 2 = right y-axis
A helpful error message is shown if the JSON is invalid. All series are fetched in parallel.
kWh Summary
Category: Energy
Compact stat card showing current power (W) and today’s energy total (kWh).
Configuration:
Field Description
Device Energy / Counter type device
Title Optional override (defaults to device name)
Color Token color: import (orange) / export (green) / solar (yellow) / gas (red)
Live: refreshes every 30 seconds and on WebSocket device updates.
Gas Summary
Category: Energy
Compact stat card showing today’s gas usage and cumulative total.
Configuration:
Field Description
Device Gas type device
Live: refreshes every 60 seconds and on WebSocket device updates.
P1 Electricity
Category: Energy
Dedicated widget for Dutch P1 smart meters showing current import/export power and today’s totals.
Configuration:
Field Description
Device P1 Electricity Meter device
Show price Show today’s cost (if reported by meter)
Displays an up-arrow (exporting) or down-arrow (importing) with current watts, coloured green for export and orange for import. Sub-line shows today’s totals for both directions.
Battery Status
Category: Energy
Battery energy storage widget showing today’s imported/exported kWh, net, and live SOC / watts / voltage.
Configuration:
Field Description
Auto mode Read device IDs from the Energy Dashboard settings
Battery energy in Manual: import kWh device
Battery energy out Manual: export kWh device
Battery SOC Manual: state-of-charge % sensor
Battery watts Manual: current power device
Battery voltage Manual: voltage sensor
When Auto mode is on, device IDs are read automatically from getenergydashboarddevices — zero extra configuration if the Energy Dashboard is already set up.
Live: refreshes every 60 seconds.
Energy Dashboard
Category: Energy
Full energy overview widget — combines all cards (Weather, Grid, Solar, Gas, Battery) and the self-sufficiency balance bar in one resizable widget. Lifted directly from forecast.html.
Configuration:
Show weather card on Weather conditions
Show solar card on Solar power and yield
Show gas card on Gas usage
Show battery card on Battery status
Show balance bar on Self-sufficiency stats
Refresh interval 60s Seconds between data refresh
Device IDs are read automatically from the Energy Dashboard settings (getenergydashboarddevices).
Self-Sufficiency
Category: Energy
Compact bar showing energy self-sufficiency percentage and today’s balance stats (house consumption, solar yield, battery net).
Configuration:
Auto mode on Read device IDs from Energy Dashboard settings
Show sun times on Show current time, sunrise, sunset
Show gauge bar on Green→red percentage bar
Self-sufficiency formula:
batNet           = batCharge - batDischarge
houseConsumption = p1Import + solar - p1Export - batNet
selfSufficiency  = (1 − max(0, netGrid) / houseConsumption) × 100
Result is clamped to 0–100%.
Text Sensor
Category: Devices
Displays the text value (Data field) of a Domoticz Text sensor device.
Configuration:
Device Text sensor device
Show title on Show device name as header
Font size 14px Text size in pixels
Refresh interval 60s Seconds between refresh
Content preserves whitespace and line breaks. Live: re-fetches immediately on WebSocket device_update for the configured device.
Device
Category: Devices
Embeds any single Domoticz device using its native widget (the same widget used in the classic dashboard).
Configuration:
Field Description
Device Any device
The background is transparent in view mode. Live: instant WebSocket updates.
Scene / Group
Category: Devices
Embeds a Domoticz scene or group with its native widget.
Configuration:
Field Description
Scene or Group Any defined scene or group
Live: WebSocket scene_update events.
Favorites
Category: Devices
Shows all favorite devices grouped by category, reproducing the classic dashboard tabs in a single widget.
Configuration:
Field Description
Category filter All / Switches & Lights / Temperature / Weather / Utility
Limit to room/plan Optional plan ID
Show category tabs Toggle tab bar
Custom Title Optional override
Live: WebSocket device_update / scene_update + 60s polling fallback.
Room / Plan
Category: Devices
Shows all devices belonging to a specific Domoticz plan (room).
Configuration:
Field Description
Plan / Room ID Numeric ID of the plan
Live: WebSocket device_update / scene_update.
Setpoint
Category: Controls
Display and control a Domoticz setpoint device with +/− step buttons and a click-to-edit popup.
Configuration:
Device Setpoint type device
Step 0.5 Increment per button press
Min 5 Minimum allowed value
Max 35 Maximum allowed value
Unit °C Display unit
Clicking the value opens a number input popup (pre-filled with current value) for direct entry. Commands use setdevice&idx=X&setpoint=Y. Live: WebSocket device updates re-fetch the current value.
Thermostat
Category: Controls
Combined widget showing current temperature from a sensor alongside setpoint controls. Ideal for room thermostats.
Configuration:
Temperature device Temp / Temp+Hum sensor
Setpoint device Setpoint device
Step 0.5 Setpoint increment
Min 5 Minimum setpoint
Max 35 Maximum setpoint
Displays the current temperature large and prominent, with +/− setpoint controls below. Both devices are fetched in a single API call.
Thermostat6
Category: Controls
Widget for the Thermostat6 device type. Displays all available measured values (Temp, Humidity + status, Barometer) and setpoint controls. Only rows for values present on the device are shown.
Configuration:
Device Thermostat6 device
Step 0.5 Setpoint step
Weather Forecast
Category: Weather
Multi-day weather forecast using the Open-Meteo API (free, no API key required). Location is read automatically from Domoticz settings.
Configuration:
Days 7 Forecast days to display (1–14)
Show wind on Wind speed row
Show precipitation on Precipitation row
Title Weather Forecast Optional override
Displays a horizontal grid of day columns, each with a weather icon (mapped from WMO weather codes), temperature range, precipitation (mm), and wind speed (km/h).
Data is cached for 30 minutes to avoid excessive API calls.
RSS Feed
Category: Information
Displays items from any RSS or Atom feed.
Configuration:
Feed URL Full URL of the RSS/Atom feed
Max items 5 Items to display (1–20)
Refresh interval 300s Seconds between fetches
Show images on Show thumbnail images
Show date on Show relative timestamp
Open in new tab on Links open in a new browser tab
Title feed title Optional override
Fetches feeds via the rss2json.com proxy (free tier, no API key needed) which solves CORS limitations.
Single item mode (Max items: 1): Shows the latest item with a large image, headline, and excerpt.
Multi-item mode: Shows a scrollable list with thumbnails, truncated titles, and relative timestamps (“2h ago”, “3d ago”). Each item has a link icon to open the original article.
Google Calendar
Displays upcoming events from a Google Calendar or any ICS-compatible calendar, grouped as Today / Tomorrow / upcoming days.
Configuration:
Calendar URL Public ICS URL or Google Calendar API endpoint
Max events 7 Maximum upcoming events to show
Show time on Show event start time
Refresh interval 900s Seconds between fetches (minimum 60)
Title Calendar Optional override
Getting a Google Calendar ICS URL: In Google Calendar → Settings → click the calendar → Integrate calendar → copy the Secret address in iCal format (ends in .ics).
Using the Google Calendar JSON API: Requires a public calendar and a Google API key:
https://www.googleapis.com/calendar/v3/calendars/{calendarId}/events
  ?key={apiKey}&orderBy=startTime&singleEvents=true&timeMin={now}
The widget auto-detects .ics vs JSON API URLs.
CORS handling: The widget fetches calendar data using a fallback chain:
  1. Direct request (works for CORS-friendly URLs)
  2. Domoticz server-side proxy (json.htm?type=command&param=fetchurl&url=<encoded>) — avoids CORS entirely for any URL reachable from the Domoticz server
  3. Public CORS proxies (corsproxy.io / codetabs) as last resort
A helpful error message is shown if all methods fail.
Past events today are shown in muted color. All-day events display without a time.
System Log
Category: System
Displays recent Domoticz system log entries with filter toggles.
Configuration:
Max entries 50 Log lines to display
Show Normal on Show Normal (white) entries
Show Status on Show Status (blue) entries
Show Error on Show Error (red) entries
Auto-refresh 10s Seconds between refresh (0 = off)
Title System Log Optional override
Toggle buttons in the widget header show the count per level (e.g. N 42, S 8, E 2) and can be clicked to show/hide each level. The Error button is coloured red when errors are present. A refresh button is also available.
Moon Phase
Shows the current moon phase with a large emoji graphic, phase name, illumination percentage, and next full/new moon date. Calculated entirely in JavaScript — no external API required.
Configuration:
Show phase name on Display phase label (e.g. “Waxing Gibbous”)
Show next event on Next full moon or new moon date
Show illumination on Illumination percentage
Title Moon Optional override
Phase names: New Moon 🌑, Waxing Crescent 🌒, First Quarter 🌓, Waxing Gibbous 🌔, Full Moon 🌕, Waning Gibbous 🌖, Last Quarter 🌗, Waning Crescent 🌘.
Updates daily.
Quick Actions
Category: Custom Content
A row of one-click buttons to trigger scenes or toggle switches.
Configuration:
An action list editor lets you add, reorder, and remove actions: | Field | Description | |——-|————-| | Type | Device (toggle) or Scene (activate) | | Device/Scene | Picked from a dropdown | | Label | Button label (auto-filled from device/scene name if blank) |
Text Note
Displays custom text with configurable appearance. Useful for section headers, labels, or status messages.
Configuration:
Field Description
Content The text to display
Font size 8–72 px
Font Arial, Verdana, Georgia, Courier New, etc.
Alignment Left / Center / Right
Text color Color picker
Text opacity 0–100%
Background color Color picker
Background opacity 0–100%
HTML Widget
Renders arbitrary HTML inside a sandboxed <iframe>. Full documents and snippets are both supported.
Configuration:
Field Description
Widget Title Optional label in the header
HTML Content Full HTML or a snippet
Security: sandbox="allow-scripts" — scripts run in isolation but cannot access the parent page.
Camera Feed
Shows a live MJPEG or snapshot image from a Domoticz-configured camera.
Configuration:
Field Description
Camera Pick from configured cameras
Remote Image
Displays a remote image from a URL, with optional auto-refresh.
Configuration:
Field Description
Image URL Full URL to the image
Refresh interval 0 = no refresh, otherwise seconds
Object fit Contain / Cover / Fill
IFrame Embed
Embeds any external website or web app in an iframe.
Configuration:
Field Description
URL The page to embed
Allow interaction Enable pointer events
Note: Many external sites block iframe embedding via X-Frame-Options. Works best with local network pages.
Battery Monitor
Category: System
Shows all Domoticz devices whose battery level is at or below a configurable threshold — a maintenance overview so you know which sensors need fresh batteries.
Configuration:
Threshold 25% Show devices at or below this battery level
Show all off When on, shows every device with a battery (above threshold shown in muted style)
Sort by level Sort by battery level ascending, or by device name
Refresh interval 300s Seconds between refresh (5 minutes)
Title Battery Monitor Optional override
Battery level colours: ≤10% red, ≤25% orange, ≤50% yellow, >50% green. When nothing is below the threshold, a green “All batteries OK” message is shown. Devices without a battery (level = 255 in Domoticz) are always excluded.
Activity Log
Category: System
Shows the most recently updated devices, ordered by last update time.
Configuration:
Field Description
Max items 5–50 items (default 15)
Live: reloads on every WebSocket device update and polls every 15 seconds.
System Status
Category: System
Shows Domoticz version, build number, and hardware count. No configuration required.
Live Update Reference
Widget Update method
Clock 1-second interval
Device / Scene Instant — WebSocket
Stat Counter Instant — WebSocket (no HTTP)
Weather Instant — WebSocket per sensor
Activity Log Instant — WebSocket
Favorites / Room Instant — WebSocket + 60s fallback
Temperature Graph 60s debounced reload on device update
Counter/Energy Chart 60s debounced reload on device update
Wind / Rain Chart 60s debounced reload
kWh Summary 30s interval + instant WebSocket
P1 Electricity 30s interval + instant WebSocket
Gas Summary 60s interval + instant WebSocket
Battery Status 60s interval
Energy Dashboard 60s interval
Self-Sufficiency Configurable interval (default 60s)
Text Sensor Configurable interval + instant WebSocket
Setpoint / Thermostat 30s interval + WebSocket
Thermostat6 30s interval + WebSocket
System Log Configurable interval (default 10s)
Weather Forecast 30-minute interval (cached)
RSS Feed Configurable interval (default 5 min)
Google Calendar Configurable interval (default 15 min)
Moon Phase Daily
Gauge 30s interval + instant WebSocket
Battery Monitor Configurable interval (default 5 min)
Custom Chart 60s debounced reload on config/range change
Sun Info / Text / HTML / IFrame / Image Static
