Plugins
From Domoticz Wiki
Python Plugins List
This list in maintained by the community. If you have created a plugin please request a Wiki account by sending a private message (PM) to forum user gizmocuz.
Go to the link for installation and usage instructions. Also go to the Forum, section Python to see more plugins.
Before installing a plugin visit page Using_Python_plugins for some prerequisites that have to be fullfilled.
  • Note 1: There is a Python Plugin named as "Python plugin Manager (PP-Manager)" that can be used to install other plugins.
    Still the plugin prerequisites (if any) should be installed manually. Domoticz restart required after every plugin installation. Most plugins run on all platforms supported by Domoticz but the PP-Manager itself currently is only for Debian Based Installations (Linux,Raspberry Pi). To use a plugin on a non-Debian platform follow the manual install instructions for the individual plugin itself
  • Note 2: A second plugin manager (Domoticz Plugin Manager) is created with an extra User interface to select the plugins.
Plugin Name Legacy Plugin Name/Remark Forum Link Github Link
Python Plugin Manager(Linux Only) https://github.com/ycahome/pp-manager
Domoticz Plugin Manager https://github.com/stas-demydiuk/domoticz-plugins-manager
AirPurifier Xiaomi AirPurifier 2/2S and Pro https://github.com/kofec/domoticz-AirPurifier
Airsend for AirSend (https://devmel.com/) devices link https://github.com/FlyingDomotic/domoticz-airsend-plugin/
Airzone Manage AirZone system via local REST API (No Cloud) https://github.com/Elwinmage/AirZone
Alarm System https://github.com/Wizzard72/Domoticz-Alarm
Android TV https://github.com/enesbcs/domo-androidtv
APC UPS https://github.com/jgaalen/domoticz-apc-ups-plugin
Atrea Atrea ventilation with heat recuperation https://github.com/mar-svo/atrea
AWTRIX3 AWTRIX3 Smart Pixel Clock Link https://github.com/galadril/Domoticz-AWTRIX3-Plugin
Balboa Spa Balboa Spa Hot Tub. https://github.com/Swedlund/Balboa-Spa-plugin-for-Domoticz
Battery monitoring for Z-Wave nodes ZWave Devices Battery Monitoring Plugins/BatteryLevel.html
Bluetooth Beacon Presence https://github.com/mrin/domoticz-bt-presence
Bluetooth Presence detect if a given bluetooth MAC address is within reach https://github.com/mvdklip/Domoticz-Bluetooth-Presence
Bluetooth MAC Ping https://github.com/heggink/domoticz-bluetooth-ping
Bluetti Bluetti power stations via Bluetooth link https://github.com/lemassykoi/Domoticz-Bluetti-Plugin
BMW Connected Drive https://github.com/FilipDem/Domoticz-BMW-plugin
Bosch EasyControl Bosch Easycontrol CT200 Thermostat link https://github.com/ggraat/domoticz-easycontrol-plugin
Botvac (Neato) Vacuum https://github.com/gilmrt/Domoticz-Botvac-Plugin
Brel Home Hub https://github.com/superjunky/Domoticz-Brel-Plugin
Broadlink IR Remote Broadlink MP1 / A1 / SP1-2-3 / RM2-3 Pro & mini / RM4 Pro & mini Link https://github.com/zak-45/Broadlink-Domoticz-plugin
Broadlink Universal IR Remote Controller Broadlink RM2 Pro/Plus, RM Mini3 https://github.com/Whilser/Broadlink-RM2-Universal-IR-Remote-Controller-Domoticz-plugin
Buienradar.nl (Weather lookup) Buienradar Weather Lookup https://github.com/ffes/domoticz-buienradar
Climacell Weather and Air quality https://github.com/afer92/domotiz-plugin-climacellV4
Creasol DomBus Modules designed for Domoticz with analog and digital inputs, pulsed counters, NTC temperature inputs, relays outputs, temperature humidity and touch sensors. Also, EVSE module for EV charging and one dual axis sun tracker controller. link https://github.com/CreasolTech/CreasolDomBus
Crow Runner Alarm Crow/AAP Alarm IP Module https://github.com/febalci/DomoticzCrowAlarm
Dahua VTO Dz Dahua VTO doorbell https://github.com/rbrouwer/dahua-vto-dz
Daikin Airconditioning (BRP069A42) Daikin BRP069A42 WiFi adapter https://github.com/leejoow/domoticz_daikin_BRP069A42
DDS238 ZN/S energy meter Modbus RTU (serial port): 1 or more devices can be attached to the same RS485 bus https://github.com/CreasolTech/domoticz-dds238
DDS238-2 ZN/S Modbus over TCP Hikking and compatible link https://github.com/xbeaudouin/domoticz-ds238-modbus-tcp
DTS238-7-modbus DS238-7 3 phase electric power meter with RS485 modbus https://github.com/voyo/DDS238-7-modbus
deCONZ bridge (For Conbee,Raspbee) https://github.com/Smanar/Domoticz-deCONZ
Denon/Marantz Amplifier https://github.com/dnpwwo/Domoticz-Denon-Plugin
DevmelAirSend AirSend and Airsend Duo (https://devmel.com/) https://github.com/ultrasuperpingu/DomoticzDevmelAirsend
Dexcom Share API https://github.com/MSe-5-14/Domoticz-Dexcom-API/
Dingtian Relay Dingtian Relay Controller https://github.com/dtlzp/Domoticz-Dingtian-Relay-Plugin
domoticz-storm-report (burze.dzis.net) Storm Reporting (Europe) https://github.com/lrybak/domoticz-storm-report
DSC EnvisaLink DSC EnvisaLink Alarm Interface https://github.com/dnpwwo/Domoticz-DSCEnvisalink-Plugin
DWD WeatherAlarm German weather alarm https://github.com/belzetrigger/domoticz-DWDWeatherAlarm
Dyson Pure Link https://github.com/JanJaapKo/DysonPureLink
ebusd bridge for e.g. Vaillant and Saunier-Duval boilers https://github.com/guillaumezin/DomoticzEbusd
Elprisetjustnu fetch Swedish energy prices from Elpriset just nu.se https://github.com/j-b-n/sweden_energyprice
Emmeti Mirai SMI heat pump Manages main parameter for Emmeti heat pumps link https://github.com/CreasolTech/domoticz-emmeti-mirai
EMS bus Wi-Fi Gateway (EMS-ESP/Nefit/Proddy) https://github.com/bbqkees/ems-esp-domoticz-plugin
Enigma2 to control Enigma2 tuner link https://github.com/kofec/Domoticz-Enigma2
eQ-3 MAX! ELV/EQ-3 MAX! Python plugin https://github.com/mvzut/maxcube-Domoticz-plugin
ESP8266 Milight hub https://github.com/etsach/espmilighthub-domoticz
EspNow Serial https://github.com/FlyingDomotic/domoticz-espnowserial-plugin
Ewpe Smart Air Conditioners via MQTT (Gree Smart/TOSOT) https://github.com/stas-demydiuk/domoticz-ewpe-smart-mqtt-plugin
Freebox https://github.com/supermat/PluginDomoticzFreebox
Frisquet-Connect For Frisquet Connect Boiler control link https://github.com/Krakinou/FrisquetConnectDomoticz
Fritz Presence https://github.com/belzetrigger/domoticz-FritzPresence
FroniusHTTP Fronius Solar inverter https://github.com/ayasystems/froniusHttp
Fujitsu-AC Fujitsu Airconditioning link https://github.com/593304/Domoticz-Fujitsu-AC
GlobalCache GC-100 https://github.com/dnpwwo/Domoticz-GlobalCache-Plugin
GoodWe solar inverter via SEMS API https://github.com/dylian94/domoticz-GoodWeSEMS
https://github.com/janjaapko/domoticz-GoodWeSEMS
GoodWe Modbus UDP GoodWe inverters over LAN or WLAN via UDP that supports Modbus https://github.com/remco-k/domoticz-goodwe-modbusudp-plugin
Goodwe RS485 Goodwe Solar Inverters via RS485/modbus https://github.com/nijmeijer/goodwe_rs485_domoticz
Google Home & Chromecast https://github.com/dnpwwo/Domoticz-Google-Plugin
Google Nest and Protect Nest thermostats and Nest Protect devices https://github.com/FilipDem/Domoticz-NEST-plugin
Govee Govee lights link https://github.com/galadril/Domoticz-Govee-Plugin
Growatt Inverter Growatt Inverter via APP Webservice https://github.com/sincze/Domoticz-Growatt-Webserver-Plugin
GPSLogger Location and presence detection link https://github.com/TurnOfAFriendlyCard/Domoticz-GPSLogger-Plugin
H801 LED WiFi controller Plugin H801 LED WiFi controller with Tasmota firmware https://github.com/stas-demydiuk/domoticz-h801-tasmota-plugin
Hewalex Hewalex heat and solar pumps https://github.com/mvdklip/Domoticz-Hewalex
Hive Plugin Hive Active Heating https://github.com/imcfarla2003/domoticz-hive
Home Connect Siemens/Bosch Home Connect Ecosystem https://github.com/mario-peters/Domoticz-Home-Connect-Plugin
Homewizard https://github.com/rvdvoorde/domoticz-homewizard
HomeWizard Battery https://github.com/etmmvdp/HomeWizard-Battery-plugin
HomeWizard Wifi P1 Meter HomeWizard Wifi P1 meter https://github.com/Eraser3/HomeWizard-Wifi-p1-plugin
HomeWizard Wifi Watermeter https://github.com/Eraser3/HomeWizard-Wifi-Watermeter
HomeWizard Wifi Energy Socket https://github.com/Eraser3/HomeWizard-Wifi-Energy-Socket
HomekitInsecureClient control Homekit Insecure Clients from Domoticz link https://github.com/macjl/Domoticz-HomekitInsecureClient
Hosola / Omnik solar inverter https://github.com/ericstaal/domoticz/tree/master/plugin/hosola
Husqvarna automower link https://github.com/FilipDem/Domoticz-Husqvarna-Automower-plugin
Huawei-Inverter Huawei-Inverter over Modbus TCP link https://github.com/JWGracht/Domoticz-Huawei-Inverter
Hyperion https://github.com/ericstaal/domoticz/blob/master/plugin/hyperion
Hyundai Kia connect Monitor and control connected cars by Hyunday and Kia link https://github.com/CreasolTech/domoticz-hyundai-kia
iCloud device locator https://github.com/heggink/domoticz-icloud
iDetect Presence detection https://github.com/d-EScape/Domoticz_iDetect
IHC (Intelligent House Control) Schneider / LK IHC (all generations) link https://github.com/kjlisby/domoticz-ihc-plugin
IKEA Tradfri Trådfri Gateway (Ikea) https://github.com/moroen/IKEA-Tradfri-plugin
IntesisBox / IntesisHome IntesisBox WMP-1 Protocol https://github.com/luismalddonado/IntesishomewithDomoticz
IOplus relay board https://github.com/josefpavlik/domoticz.plugin.ioplus
IR Climate Controller Tasmota IR climate controller integration link https://github.com/szelessavalapitvany/domoticz-ir-climate-controller
Itho Wifi link https://github.com/galadril/Domoticz-Itho-Wifi-Plugin
Kesser For Clima/ of brand Kesser with WiFi Tuya https://github.com/jmichault/kesser
Jablotron SIA Alarm https://github.com/andyboeh/domoticz-jablotron
KinCony KC868 Smart Controller KC868 Wifi Relay Controller https://github.com/hzkincony/Domoticz-KinCony-KC868-Ethernet-WiFi-Relay-Module-Plugin
KNMI weather https://github.com/bramvreugd/Domoticz-KNMI-Weather-Plugin
Kodi Players Kodi https://github.com/dnpwwo/Domoticz-Kodi-Plugin
Ledenet / Ufolight RGB controller https://github.com/ericstaal/domoticz/tree/master/plugin/ledenet
LG Smart AC (SmartThinQ) LG Smart AC devices Api V1 link https://github.com/olinek2/LGAC_SmartT
LG Smart AC (SmartThinQ) LG Smart AC devices Api V2 link https://github.com/majki09/domoticz_lg_thinq_plugin
LGTV WebOS https://github.com/GameDevHobby/Domoticz-LGTV-WebOS-Plugin
Life 360 Presence Life 360 Presence Detection No longer available, use GPSLogger plugin
Linky https://github.com/guillaumezin/DomoticzLinky
LinkyStdMode Linky Standard mode https://github.com/bnj-04/LinkyStdMode
Link-Tap Link-Tap watering timer https://github.com/DebugBill/Link-Tap
Luxtronic2 Heatpump controller (AlphaInnotec) link https://github.com/ajarzyn/domoticz-luxtronic2
Luxtronik Luxtronik Heat Pump Controller link https://github.com/Rouzax/luxtronik-domoticz-plugin-v2
Lyrion Music Server formaly known as Logitech Media Server link https://github.com/MadPatrick/domoticz_Lyrion
MBusSerial https://github.com/Net-time/MBusSerial
MegaIO relay board https://github.com/josefpavlik/domoticz.plugin.megaio
MELCloud Control Mitsubishi AC [https://github.com/gysmo38/domoticz-python-melcloud
Meteo Alarm EU RSS Reader https://github.com/ycahome/MeteoAlarmEU
Midea Dehum Midea Dehumidifier https://github.com/meaninglessvanity/midea_dehum_plugin
Mikrotik RouterOS https://github.com/mrin/domoticz-routeros-plugin
Mitsubishi AC MQTT interface AC control with Swicago's serial and MQTT interface [https://github.com/Masurov/Domoticz-MitsubishiHpMQTT-Plugin
Modbus RTU / ASCII / TCP/IP Link https://github.com/DomoticX/domoticz-modbus
Moon Phases https://github.com/ycahome/MoonPhases
Moonraker Moonraker/Klipper 3D-printers Link https://github.com/klym-tatarnikov/MoonrakerDomoticz/
Motherboard PSUtil Sensors https://github.com/febalci/DomoticzPsutil
MQTT discovery MQTT Discovery plugin with Sonoff-Tasmota extensions link https://github.com/emontnemery/domoticz_mqtt_discovery
MQTT Mapper Map MQTT messages to Domoticz devices link https://github.com/FlyingDomotic/domoticz-mqttmapper-plugin
Myenergi Myenergi Zappi EV charger https://github.com/mvdklip/Domoticz-myenergi
NIBE Uplink https://github.com/flopp999/NIBEUplink-Domoticz
Niko Home Control https://github.com/tnys/nikohomecontrol-domoticz
Nissan Leaf EV link https://github.com/BreizhCat/DomoticzNissanLeaf
NUKI Locks https://github.com/heggink/domoticz-nuki
OctoPrint https://github.com/jneilliii/OctoPrint-Domoticz
Omnik Inverter Local Omnik Inverter via Local device https://github.com/sincze/Domoticz-Omnik-Local-Web-Plugin
Onkyo AV Receiver Onkyo receivers https://github.com/jorgh6/domoticz-onkyo-plugin
OpenAQ Air Quality link https://github.com/waltervl/Domoticz-OpenAQ-Plugin
OpenEVSEPlugin OpenEVSE mqtt https://github.com/ayasystems/OpenEVSEPlugin
Ouman-C203-Modbus https://github.com/pawelmuszynski/domoticz-Ouman-C203-Modbus
IntesisBox-Panasonic IntesisBox Panasonic-Tcap over modbus https://github.com/voyo/IntesisBox-Panasonic-Tcap-modbus
Panasonic Cloud Comfort Panasonic Cloud Comfort through CZ-TACG1 WiFi adapter https://github.com/sdamasoc/domoticz_panasonic_CZ-TACG1/
Paradox Alarm PRT3 serial interface Domoticz-ParadoxPrt3-Plugin https://github.com/Masurov/Domoticz-ParadoxPrt3-Plugin
Parrot Flower Power & Pot plugin https://github.com/tazounet/parrot_flower_plugin
Pi Clock Speeds Reimplements clockspeeds (after removal from 2024.1) https://github.com/akamming/Domoticz_pi_Clockspeeds_Plugin: Domoticz_pi_clockspeeds_plugin
Pinger (ICMP) Pinger https://github.com/dnpwwo/Domoticz-Pinger-Plugin
Pioneer AVR https://github.com/febalci/DomoticzPioneerAVR
Powerview Hunter Douglas shades https://github.com/jgaalen/domoticz-powerview-plugin
pyViCare Viessmann API for eg Vitovalor PT2 https://github.com/wimmme/pyViCare-domoticz
PZEM-004T PZEM-004T energy meter https://github.com/mce35/Domoticz-PZEM-004T
PZEM-016 PZEM-016, PZEM-014 and PZEM-004T energy meters: supports up to 51 meters on the same bus https://github.com/CreasolTech/domoticz-pzem-016
PZEM-017 Modbus PZEM Energy Monitor https://github.com/mar-svo/PZEM-017
RAVEn Zigbee energy monitor RAVEn Power Monitor https://github.com/dnpwwo/Domoticz-RAVEn-Plugin
Remeha Home Remeha thermostats link https://github.com/tuk90/RemehaHome-Domoticz
Renault EV for the My Renault API Link https://github.com/HomeACcessoryKid/Domoticz-Renault-Plugin
Renault-Dacia Renault Dacia Electric Vehicle https://github.com/Kask29/Domoticz-Renault-Dacia-Plugin
Reolink Reolink Cameras Doorbells https://github.com/j-b-n/domoticz_reolink
Resol-VBUS https://github.com/bramvreugd/Domoticz-Resol-VBUS-Plugin
RFSwitches RF 433 Switches https://github.com/flatsiedatsie/433Switches
Rooted Toon rooted Toon thermostat link https://github.com/MadPatrick/domoticz_toon
Qlima Wifi airconditioner Midea/Inventor AC Clone https://github.com/awalsum/Qlima
Quatt Quatt Heat Pump link https://github.com/galadril/Domoticz-Quatt-Plugin
SAIC iSmart MG EV Cars link https://github.com/lemassykoi/Domoticz-MG-Plugin
SDM120-Modbus Eastron SDM120-Modbus RTU Single Phase kWh Meter https://github.com/simat-git/SDM120-Modbus
SDM630-Modbus Eastron SDM-72 SDM-72v2 SDM-120 SDM-230 SDM-630 kWh meters https://github.com/gizmocuz/SDM630-Modbus
Sessy Battery link https://github.com/JanJaapKo/SessyBattery
Shelly Cloud https://github.com/mario-peters/ShellyCloudPlugin
Shelly MQTT https://github.com/enesbcs/Shelly_MQTT
Shelly1 with temp sensors https://github.com/Net-time/Domoticz_Shelly_Plugin
SMA Inverters SMA Solar Inverters using Modbus TCP/IP link https://github.com/derenback/Domoticz-SMA-Inverter
Smart Virtual Thermostat Plugins/Smart_Virtual_Thermostat.html
SNMP Reader https://github.com/ycahome/SNMPreader
Snapcast Snapcast integration (control volume/muting of snapcast clients) link https://github.com/akamming/domoticz-snapcast
SolarEdge Modbus TCP https://github.com/addiejanssen/domoticz-solaredge-modbustcp-plugin
Solax Inverter https://github.com/syrhus/solax_inverter
Somfy Somfy Tahoma / Connexoon link https://github.com/MadPatrick/domoticz_somfy
Sonos https://github.com/gerard33/sonos
Sony Bravia TV (with Kodi remote) Sony Bravia TV https://github.com/gerard33/sony-bravia
SPRSUN-Modbus SPRSUN-Modbus Heat Pump link https://github.com/Sateetje/SPRSUN-Modbus
Steam status monitor your Steam status link https://github.com/galadril/Domoticz-Steam-Plugin
Stromer EBikes Link https://github.com/elnkosc/stromer_domoticz_plugin
Synology SurveillanceStation https://github.com/lolautruche/SurveillanceStationDomoticz
SYSFS-Switches GPIO SYSFS Switches https://github.com/flatsiedatsie/GPIO-SYSFS-Switches
Tapo TP-Link Tapo P100 and Tapo P110 smart plug https://github.com/Chouteau49/Domoticz_Tapo_TP-Link
Tasmoticz autodetecting ESP8266 devices with Tasmota firmware link https://github.com/joba-1/Tasmoticz
Tesy Modeco Boiler Supports local API for Tesy Modeco boilers https://github.com/heggink/domoticz-tesy
Thermostat weekly Timer https://github.com/ArtBern/Scheduler
Thermostate ESP thermostat with weather dependent heating control https://github.com/akamming/Domoticz_Thermostate_Plugin
ThesslaGreen ThesslaGreen recuperators with RS485 modbus interface link https://github.com/voyo/ThesslaGreen-modbus
Tibber Energy prices https://github.com/flopp999/Tibber-Domoticz
Tile collects the distance from your home to your Tile devices https://github.com/sydspost/Domoticz-Tile-plugin
tinycontrol LAN IOT controller https://github.com/kofec/domoticz-tinycontrol
ToonMonitor to monitor a Toon Thermostat https://github.com/JackV2020/Domoticz-ToonMonitor
Toyota for a Toyota car with connected services https://github.com/joro75/Domoticz-Toyota-Plugin
TP-Link-smartplug TP-Link smartplug HS100 / HS110 / HS110v2 (european version) https://github.com/lordzurp/domoticz-tplink-smartplug
TP-Link Tapo plug Tp-link Tapo P100 plugs, P105 plugs and L510E bulbs (on/off) link https://github.com/593304/Domoticz-Tapo
Trafikverket API Weather https://github.com/Net-time/Domoticz_Trafikverket_Plugin
Domoticz Tuya Cloud API Plugin https://github.com/lacha07/domoticz-tuya-cloud
Tuya-Powerplug https://github.com/sincze/Domoticz-Tuya-SmartPlug-Plugin
Tuya Plugin Controls TUYA devices your network (mainly on/off switches and Lights) https://github.com/Xenomes/Domoticz-TUYA-Plugin
Tuya Controls TUYA devices your network (mainly on/off switches and Lights) https://github.com/guino/tuyaha
Unifi Presence https://github.com/Wizzard72/Domoticz-Unifi-Presence
UniPi EVOK https://github.com/mccwdev/domoticz-unipi
UPS Monitor Plugins/NUT_UPS.html
Venta for venta device (LPH60 WiFi App Control) https://github.com/ajarzyn/domoticz-venta
Victron Energy Victron Energy GX https://github.com/xbeaudouin/victron-energy-domoticz
VictronMultiplusII Victron Multiplus-II Inverter https://github.com/pawcio50501/domoticz-VictronMultiplusII
VirtualThermostat-PID https://github.com/worops/Domoticz-VirtualThermostat-PID
Volumio control Volumio music player https://github.com/frepkovsky/Domoticz-Volumio-Plugin
Volvo All Volvo cars as of model year 2015 link https://github.com/akamming/Domoticz_VolvoRecharge_Plugin
Wallbox Wallbox EV charger link https://github.com/lokonli/domoticz-wallbox
WAN IP Checker https://github.com/ycahome/WAN-IP-CHECKER
Watermeter NPN Plugin https://github.com/akamming/domoticz-watermeter
We-Connect Read Volkswagen ID.3 battery percentage and distance left link https://github.com/Andreotti100/We-connect
Weather Dependent Heating Control OpenTherm weather dependent heating control link https://github.com/akamming/Domoticz_Thermostate_Plugin
WeHeat WeHeat heatpump link https://github.com/Tableflipper9001/weheat-domoticz-plugin
Wellbeing Electrolux / AEG Wellbeing Air Purifiers https://github.com/jgaalen/domoticz-wellbeing-plugin
Wiz Connected Wiz wifi lights link https://github.com/sydspost/Domoticz-WiZ-connected-plugin
WU Direct WuDirect interface for Personal Weather Stations link https://github.com/vaneeten/domoticz-wudirect
Xiaomi Mi Flower Mate Xiaomi Mi Flower Mates and other BT Flower mate or Flower care liink https://github.com/flatsiedatsie/Mi_Flower_mate_plugin
Xiaomi Mi Robot Vacuum https://github.com/mrin/domoticz-mirobot-plugin
Xiaomi PM2.5 Sensor Xiaomi PM2.5 Air Quality Sensor https://github.com/febalci/DomoticzXiaomiPM2.5
Xiaomi Universal IR Remote Controller Xiaomi Chuangmi IR https://github.com/Whilser/Xiaomi-Universal-IR-Remote-Controller-Domoticz-plugin
Xiaomi MiJia Philips LED Lamp Xiaomi MiJia Philips Bulb, ZhiRui, ZhiYi, etc. LED lamps https://github.com/Whilser/Xiaomi-MiJia-Philips-LED-Lamp
Yamaha AV Receiver https://github.com/thomas-villagers/domoticz-yamaha
YI-Hack https://github.com/galadril/Domoticz-Yi-Hack-Plugin
ZigbeeforDomoticz Zigate, Zigpy, TI CC2531, CC13x2, CC26x2, SiliconLabs, deConz (ConBee, raspBee). No need of mqtt or other middleware/broker. link https://github.com/zigbeefordomoticz/Domoticz-Zigbee
Zigbee MQTT Bridge for Tasmota Zigbee Gateway link https://github.com/Mibeus/domoticz_zigbee2tasmota
Zigbee2MQTT plugin https://github.com/stas-demydiuk/domoticz-zigbee2mqtt-plugin
ZoneMinder video surveillance software system https://github.com/Swedlund/ZoneMinder-plugin-for-Domoticz
$: Requires some pre-requisites to be installed. Check instructions.
$$: Cannot be integrated. Requires nested repository pull.
Some tips on using plugins: Using_Python_plugins
Creating a Python plugin: Developing_a_Python_plugin
Domoticz not finding Python on Linux: Linux#Problems_locating_Python
