LUA commands
From Domoticz Wiki
Revision as of 14:23, 19 December 2025 by Walter vl (talk | contribs) (General)
Lua tables, commands and variables list for use in Domoticz
This page is created to give an overview of tables, possible commands and variables in Lua that can be used in Domoticz. There is already a lot of information available on the forum, but this is scattered throughout. Next to that, the syntax is not always clear.
See also the LUA scripts section in the eventsystem page for more background info.
Tables available in your scripts
Available in time triggered scripts
timeofday
uservariables
uservariables_lastupdate
globalvariables
otherdevices
otherdevices_idx
otherdevices_lastlevel
otherdevices_lastupdate
otherdevices_svalues
-- Below tables only when such devices exist on your system. (else nil)
otherdevices_barometer
otherdevices_dewpoint
otherdevices_humidity
otherdevices_rain
otherdevices_rain_lasthour
otherdevices_temperature
otherdevices_utility
otherdevices_weather
otherdevices_winddir
otherdevices_windgust
otherdevices_windspeed
otherdevices_zwavealarms
otherdevices_scenesgroups
otherdevices_scenesgroups_idx
Tables available in device triggered scripts
All of the tables available in device triggered scripts
devicechanged
devicechanged_ext
Tables available in variable triggered scripts
All of the tables available in variable triggered scripts
uservariablechanged
General
if (devicechanged['MyDeviceName'] == 'On' and otherdevices['MyOtherDeviceName'] == 'Off') then
   commandArray['MyOtherDeviceName1']='On'
   commandArray['MyOtherDeviceName2']='On'
   commandArray['MyOtherDeviceName3']='Off'
   commandArray['MyOtherDeviceName4']='On FOR 10' -- minutes
   commandArray['MyOtherDeviceName5']='Off RANDOM 30' -- random within x minutes
   commandArray['MyOtherDeviceName6']='On REPEAT 5 INTERVAL 5' -- command will be repeated 5 times with 5 seconds interval
   commandArray['MyOtherDeviceName7'] = "On FOR 2 SECONDS REPEAT 9 INTERVAL 4 SECONDS" -- every 4 seconds and do that 9 times, put device On for 2 seconds
   commandArray['MyBlind']='Open'
   commandArray['Scene:MyScene']='On'
   commandArray['Group:MyGroup']='Off AFTER 30' -- seconds
   commandArray[#commandArray + 1] = { SendNotification = 'subject#body#prio#sound#extraData#subSystem1;subSystem2;subSystem3'
   commandArray['OpenURL']='www.yourdomain.com/api/movecamtopreset.cgi'
   commandArray[#commandArray + 1] = { OpenURL = url .. ' AFTER 0.2' } -- send the url after 0.2 seconds
   commandArray['SendNotification']='subject#body#priority#sound#extradata#subsystem'
          -- Subject is .. the subject
          -- Body is the content of the message
          -- priority is a number from 0 (low) to 4 (emergency)
          -- sound is the sound you want to use if you use pushover
          -- extradata can be used by some of the notification.
          -- subsystem is one or more of: clickatell;email;fcm;http;kodi;lms;prowl;pushalot;pushbullet;pushover;pushsafer;telegram
   commandArray['SendEmail']='subject#body#to'
   commandArray['TriggerIFTTT']='EventName#Value1#Value2#Value3'
   commandArray['Variable:MyVar']='Some value'
   commandArray[Text:1234]='Some value'
   commandArray['SetSetPoint:MySetPointIdx']='20.5'
   commandArray['SendCamera:1'] = 'SubjectOfMessage AFTER 5' -- This is equal to 'Send camera snapshot with subject "Subject of Message" after 5 seconds. The number (1) in this case is the ID of the camera, not the name!
   commandArray['UpdateDevice']='idx|nValue|sValue' -- for updating Dummy devices e.g. '96|0|Hello World'
Round function
local function round(num, dec)
	return ( math.floor( num * 10^dec ) / 10^dec )
Update multiple devices in one pass
local function update(idx, value1, value2)
    local cmd = string.format("%d|0|%.2f;%.2f", idx, value1, value2)
    table.insert (commandArray, { ['UpdateDevice'] = cmd } )
update (16, 320, 0)
update (19, 4, 25)
Update (one or more) numerical devices without using the device idx code
local function updatenum(dev, value1)
    local cmd = string.format("%d|0|%d", otherdevices_idx[dev], value1)
-- example 1: increment a counter
updatenum('Counter1', tonumber(otherdevices['Counter1']) + 1)
-- example 2: set a fixed value
updatenum('Counter2', 85)
Debugging
Function to dump all variables supplied to the script
function LogVariables(x,depth,name)
    for k,v in pairs(x) do
        if (depth>0) or ((string.find(k,'device')~=nil) or (string.find(k,'variable')~=nil) or
                         (string.sub(k,1,4)=='time') or (string.sub(k,1,8)=='security')) then
            if type(v)=="string" then print(name.."['"..k.."'] = '"..v.."'") end
            if type(v)=="number" then print(name.."['"..k.."'] = "..v) end
            if type(v)=="boolean" then print(name.."['"..k.."'] = "..tostring(v)) end
            if type(v)=="table" then LogVariables(v,depth+1,k); end
-- call with this command
LogVariables(_G,0,'');
Function to dump content of any table
local function tprint (t, indent, done) -- introduced done to prevent infinite loops for tables with self-references
  local done = done or {}
  indent = indent or 0
  for key, value in pairs (t) do
    pre = (string.rep (" ", indent)) -- indent it
    if type (value) == "table" and not done[value] then
      done [value] = true
      print (pre .. tostring (key) .. ":");
      tprint (value, indent + 2, done)
    elseif type(value) == 'function' and not done[value] then
      print( pre .. (tostring (key) .. "()"))
      pre = pre .. (tostring (key) .. ": ")
      print (pre .. tostring(value))
Date and Time
Start script at a specific minute
local atMinute = 12
if tonumber(os.date('%M')) ~= atMinute then
    print ('Not the right minute. No further execution.')
Start script at a specific time
local executionTime = '23:21'
local light = 'Flicker' -- Name of your light
if os.date('%H:%M') == executionTime then
     for i = 0, 12, 2 do
        commandArray[#commandArray + 1] = { [light] = 'Off AFTER ' .. i }
        commandArray[#commandArray + 1] = { [light] = 'On AFTER ' .. (i + 1) }
Function to get timestamp
local function timestamp(dateString, pattern)
    if dateString == nil then return os.time() end
    local pattern = pattern or  "(%d+)%-(%d+)%-(%d+)%s+(%d+):(%d+):(%d+)"
    local year, month, day, hour, minute, seconds = dateString:match(pattern)
    return os.time( { year = year, month = month, day = day, hour = hour, min = minute, sec = seconds } )
Function to calculate the time difference (uses timestamp function)
function timedifference(t1, t2) -- both dates with format 'yyyy-mm-dd HH:MM:SS' or nil
  return timestamp(t1) - timestamp(t2)
Usage
local mydevice_changed = false
if (mydevice_changed ~= nil and devicechanged['mydevice']) then
    mydevice_changed = true
s = otherdevices_lastupdate['mydevice']
if(otherdevices['mydevice']=='On' and timedifference(s) > 600 and not mydevice_changed) then
    commandArray['mydevice']='Off'
Note: You should only define and check for mydevice_changed variable when using 'All' scripts.
Time of day
Check if it is daytime or nighttime
Example:
if (timeofday['Daytime']) then ...
or
if (timeofday['Nighttime']) then ...
Devices
