WAN IP Checker
From Domoticz Wiki
Revision as of 19:53, 12 December 2025 by Walter vl (talk | contribs)
Why do you need one?
Lots of people have experienced this: you are away from home, on a business trip or holidays, and your IP provider has given you a new external IP address. Lots of providers use dynamic IP, a static address is hard to come by. Unfortunately they don't tell you this in any way, but you find out the hard way: you can't get into your systems from remote.
There are ways around this, for instance by using a DynDNS service. But if the only thing you want is to VPN into your network, this is overkill.
There is a simple way to solve this: Install a small dzVents script on your system, that will automatically run periodically.
It will retrieve the external IP address and compare that to the address that was stored in the previous run. If they differ it will put the new IP address in the text device.
Instructions
Create a Dummy text device named ' Wan IP' and copy and paste the dzvents script in the internal event editor as a dzvents script.
The Script
local getIp    = 'https://api.ipify.org/?format=json'
     timer = { 'every 6 hours' },
     httpResponses = { 'wanIP' }
logging = {
     level = domoticz.LOG_FORCE,
     marker = '[WAN IP]'
  execute = function(dz, devNil)
     local actIP = dz.devices('Wan IP').text
     local newIP = 'Unable to retrieve IP'
     if (devNil.isTimer)  then
        dz.log("Send WanIP request")
        dz.openURL({
           url = getIp,
           method = 'GET',
           callback = 'wanIP'
     elseif (devNil.isHTTPResponse) then
        dz.log("WanIP response")
        if (devNil.ok) then -- statusCode == 2xx
           newIP = devNil.json.ip
        if newIP ~= actIP then
           dz.devices('Wan IP').updateText(newIP)
