WebServer Proxy
From Domoticz Wiki
Revision as of 16:51, 14 October 2025 by Walter vl (talk | contribs)
Introduction
If you are running a NGINX or Apache webserver or a Synology NAS and you want to forward (proxy) requests to your internal Domoticz installation then this is a guideline how to do so:
See for more background information the Security page
We assume the following:
Domoticz is running on a system with:
IP Address: 192.168.0.210
Port: 8080 (No SSL)
We will forward all requests ending on domoticz/ to the Internal Domoticz application
for example: https://www.mydomain.com/domoticz/ ===> http://192.168.0.210:8080
Please Note:
For the "Forwarded" (RFC7239), "X-Forwarded-For" or "X-Real-IP" HTTP Header to be recognized in Domoticz, make sure you enter the IP address of your proxy server (which could be on the same machine like 127.0.0.1) in the main Domoticz setup page underneath "Local Networks" or when you run a old version (<14299) in "RemoteProxyIPs". Else external Users are either not allowed at all or can enter Domoticz without login.
APACHE:
 <IfModule mod_ssl.c>
 <VirtualHost *:443>
       ServerName www.mydomoain.com
       ServerAlias www.mydomoain.com
       ProxyPreserveHost On
       # ProxyPass domoticz/json ws://192.168.0.210:8080/json
       # ProxyPassReverse domoticz/json ws://192.168.0.210:8080/json
       ProxyPass domoticz/ http://192.168.0.210:8080/
       ProxyPassReverse domoticz/ http://192.168.0.210:8080/
       <Location "domoticz/json">
           ProxyPass "ws://192.168.0.210:8080/json"
       </Location>
       ErrorLog ${APACHE_LOG_DIR}/site1-web_error.log
       # Possible values include: debug, info, notice, warn, error, crit,
       # alert, emerg.
       LogLevel warn
       CustomLog ${APACHE_LOG_DIR}/domoticz_access.log combined
       Include /etc/letsencrypt/options-ssl-apache.conf
       SSLCertificateFile /etc/letsencrypt/live/www.mydomoain.com/fullchain.pem
       SSLCertificateKeyFile /etc/letsencrypt/live/www.mydomoain.com/privkey.pem
 </VirtualHost>
 </IfModule>
NGINX:
 server {
       listen 443 ssl default_server;
       listen [::]:443 ssl default_server;
       server_name www.mydomoain.com;
       ssl_certificate www.mydomoain.com.crt;
       ssl_certificate_key www.mydomoain.com.key;
       access_log /var/log/nginx/domoticz-access.log;
       error_log /var/log/nginx/domoticz-error.log;
       location /domoticz {
               rewrite ^/domoticz/?(.*) /$1 break;
               proxy_http_version		1.1;
               proxy_read_timeout		90;
               proxy_set_header        Host $host;
               proxy_set_header        X-Real-IP $remote_addr;
               proxy_set_header        X-Forwarded-For $proxy_add_x_forwarded_for;
               proxy_set_header        X-Forwarded-Proto $scheme;
               proxy_set_header		X-Scheme $scheme;
               proxy_set_header		Upgrade $http_upgrade;
               proxy_set_header		Connection $connection_upgrade;
               add_header				X-Frame-Options SAMEORIGIN;
               proxy_pass http://192.168.0.210:8080;
Synology NAS
IIS
Using IIS as a reverse proxy for Domoticz does not require any configuration and will work out-of-the-box
