Energy dashboard
From Domoticz Wiki
Revision as of 15:59, 18 November 2024 by Walter vl (talk | contribs)
From menu Setup -> Energy Dashboard you are able to view your energy flows in your house.
Setup
To configure the Dashboard, go to menu Setup -> Settings, tab Energy Dashboard.
There you can enable the devices you have available in your house and in Domoticz.
Minimum a P1/Grid meter device is needed to show the energy needs in you home.
There are several options available:
  • Display server time
  • the flow line behavior (dashed or dots)
  • Use of custom device icons instead of the default icons
  • Select Custom devices that can be used to show consumption of specific devices (eg water boiler, Electric car, washing machine). These devices will be connected to your home.
For latest information, questions and tips and tricks how to combine for example multiple solar inverters in a script check forum topic https://www.domoticz.com/forum/viewtopic.php?t=42405
Real time Cost calculation
For real time Energy cost calculations enable the prices in menu Setup -> Settings, tab Meter/Counters, section (Dynamic) Price calculation
See also wiki page Setup Settings
Example
