Enever
From Domoticz Wiki
Revision as of 12:05, 11 October 2024 by Walter vl (talk | contribs)
With the Enever hardware gateway, Dutch users can query/log their dynamic energy prices from various energy suppliers for Gas and Electricity into Domoticz. Source is the enever.nl website.
These prices can be used to control various devices (like washing machines, batteries) and be used for real-time cost calculations.
Note: After you have enabled and configured the Enever hardware gateway as instructed below you can go to menu Setup -> Settings, tab Meters/Counter to enable real time energy cost calculations based on the dynamic prices in the price devices created by the Enever hardware gateway.
Configure Enever
Go to https://enever.nl, tab Prijzenfeeds. Create a token (it's free), it will be sent by email. After activation copy the token, to be used below.
Go in Domoticz to menu Setup -> Hardware and fill in code below
  • Type: Enever Dutch Electricity/Gas Price feed
  • Enabled/Disabled: you can disable the hardware gateway. The created devices stay active (but greyed out) but will not be updated.
  • Name: Enter a meaningful name for the Gateway
  • Select Log Levels:
    • Info: Shows info logging about the hardware and its devices in the log file or log page. This will normally generate the most log lines
    • Status: Shows Status logging in the log file or log page.
    • Error: Shows Error logging in the log file or log page.
  • Data Timeout: Enable Data Timeout if needed (1 minute to 24 hours). Domoticz will restart the Hardware thread/plugin if after the set timeout still no data is received by the gateway.
  • Enter the access token you created on the Enever website
  • Select your Electricity and Gas provider
Click on Add
Now 4 devices will be created,
  • The actual price device for Electricity and Gas
  • A daily forecast device for Electricity and Gas for the next day. These device could be used to plan usage of other devices for example charging cars or switching of solar panels.
Example created devices in menu Setup - Devices
Activate Actual Energy Cost calculation
If you have activated the Enever gateway devices go to menu Setup -> Settings, tab Meters/Counter to enable real time energy cost calculations based on the actual dynamic prices in the actual price devices created by the Enever hardware gateway. You will get an extra cost line in the energy graphs and cost indication on the Energy dashboard
