Machinon Theme
From Domoticz Wiki
Revision as of 07:20, 3 April 2024 by Walter vl (talk | contribs) (Update)
This is a theme for Domoticz with some great features.
Theme is also in progress with project machinon: https://www.machinon.com
Machinon is a Theme under developement. In sept 2018 it's quite stable and looks promising
Designed in 2018 by EdddiN.
Install
We recommend you to use the Theme manager plugin to install and keep up-to-date the theme.
You can also manually install it, in Domoticz theme directory :
cd /home/${USER}/domoticz/www/styles
git clone https://github.com/domoticz/machinon.git machinon
sudo /etc/init.d/domoticz.sh restart
Update
cd /home/${USER}/domoticz/www/styles/machinon
git pull
Then you might have to push reset to default in theme settings in gui and clean browser cache.
Theme Settings
Theme adds an extra page for theme specific settings and a About file where settings are explained Accessible under Setup -> settings -> Theme
Custom Settings page
Special settings page for better overview.
Dark theme
Like the header says a darker theme.
Standby Mode
Screen saver. Great if you use a tablet on the wall.
Switch intead of BigText
Switch in the upper right corner instead of text.
Popup options menu
A small popup for device options
Flexible device rows
Bigger screen more rows.
Display Dashboard in columns (screen width > 1200px)
Display Camera Preview on Dashboard
You need to attach a switch to your camera (create a switch then in Settings/Camera, add the switch to the camera)
Add the switch to the dashboard
Navbar
Options are Side Menu, Icons/Text
Notification
Option to check for updates
How to get visual notifcation when a device is changing status or value etc:
- Go to the device notifications
- In notifications settings select browser
Custom Page (Iframe)
Custom Page with menu button. Add button name and custom page url. Add url e.g: https://www.domoticz.com or a local file e.g: ../templates/custompage.html
And much more..
Report bugs, contribute to theme Machinon theme on github
Forum link
