Compatible products
From Domoticz
Revision as of 06:51, 6 January 2024 by Admin (talk | contribs) (Z-wave)
Intro
The list will come in hand, when you want to start up or expand with Domoticz. These products can be bought via various online webshops like AliExpress, Bangood, RobbShop.
Please be aware that new import restrictions/rules are effective for importing goods from outside Europe (Like China) to Europe (specially importing them into the Netherlands).
For this reason it might be best to shop via an European webshop like ROBBshop.
If you have devices like doorbells/ipcams,sensors or other products available on Banggood or Aliexpress, that are compatible (tested by yourself), please tell us, so we can add them to the list.
An up-to-date list I placed on my site: www.gadget-freakz.com
I try to review all items and place Discount coupons deals
Gadget-freakz.com
Gadget-freakz.com
Buy your European Domoticz compatible products at ROBBshop
ROBBshop.nl
ROBBshop.nl
Raspberry pi basics
Raspberry 4
Xiaomi
Xiaomi Gateway LED, (besides a gateway also a Speaker/Alarm, Illumination Sensor This one is needed in order for all other devices to work Human Body Sensor (Motion Sensor) Wireless Smart Switch Door/Window Sensor
Temperature and Humidity Sensor Smart Socket/Plug - Zigbee version (The WiFi version is not supported) Xiaomi Mi Smart Cube (Xiaomi Mi Magic Controller) Wireless Aqara Switch (Dual Button)
Wireless Aqara Switch (Single Button) Wired Aqara Switch (Dual Button) (uses UK Wall Box) Wired Aqara Switch (Single Button) (uses UK Wall Box) Smoke Detector
Gas Leak Detector Window Door Sensor Temperature Humidity Sensor Water Sensor *this sensor currently requires the Beta version of Domoticz
more info: https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
Camera
Xiaomi_Camera
Z-wave
GC00AM NAS - PD01Z Z-Wave PIR Motion Sensor - EU VERSION WHITE GC00AM NAS - WR01ZE Z-Wave Smart Socket - EU PLUG WHITE NEO Coolcam NAS - SC01ZE - 1 Light Switch - EU 1GANG WHITE GC00AM NAS - DS01Z Door Window Sensor - EU FREQUENCY WHITE NEO Coolcam NAS - WS01Z Z-wave Water Sensor - EU PLUG WHITE
If you are using ZWaveJS-UI, see the below link for compatible devices:
https://devices.zwave-js.io/
Yeelight
Original Xiaomi Yeelight 220V E27 Smart LED Bulb - WHITE Xiaomi Yeelight AC220V RGBW E27 Smart LED Bulb - SILVER Xiaomi Mijia Smart LED Desk Lamp - WHITE Xiaomi Yeelight Smart LED Ceiling Light - WHITE Yeelight Smart Light Strip - RGB COLOR 19
IR and RF
Broadlink RM2 Device Broadlink A1 Device Broadlink SP2/SP3/SP3S Device Broadlink MP1 Device
Milight/limitless/applamp
MiLight 2.4G WiFi LED Light Strip Controller Milight E27 6W 2.4Ghz Wireless RGBW Dimming LED Bulb AC 86 - 265V - RGB + WARM WHITE MiLight WiFi LED Spot Bulb - RGB + WARM WHITE RGBW MiLight RF Remote Controller
Sonoff
SONOFF POW WiFi Wireless Smart Switch SONOFF Touch WiFi Wireless Remote Control Wall Timing Switch - EU VERSION SONOFF Touch WiFi Wireless Remote Control Wall Timing Switch - US VERSION SONOFF BASIC WiFi Wireless Smart Switch for DIY Home Safety SONOFF S20 WiFi Smart Switch Socket for Home Safety - US PLUG
IOT4
This devices support outofthebox with Wifi and MQTT, not need firmware change
IOT4SH01Relay OutOfTheBox MQTT WiFi Relay IOT4SH01Relay OutOfTheBox MQTT WiFi DS18B20 Waterproof temperature meter
DomBus RS485 modules
Modules designed for Domoticz, optimized for very low power consumption to get a smart home with no batteries and no RF pollution
DomBus12
9 configurable I/Os
DomBus23
2 relays, 1 110-240V inputs, 2 12-24V inputs, 2 I/O, 1 mosfet, 2 analog output 0-10V
DomBus31
7 SPST 5A relays + 2 SPDT 10A relays
DomBusTH
DomBusTH module within temperature + relative humidity sensors, 4 I/Os, 2 open-drain outputs, red led, green led, white led and 1 analog input.
Temp + Hum sensors, 4 I/Os, 2 outpus, R+G+W leds, 1 analog input
DomBus32
3 relays + 3 AC inputs + 5 I/Os
DomBus33
3 relays + 3 AC inputs + 5 I/Os with special firmware to work with existing light systems, using step-by-step relays
DomBus36
12 relays output module for Domoticz
12 relay outputs
DomBus37DomBus37 domotic module with 12 inputs, 3 AC inputs, 3 relay outputs
12 analog/digital inputs + 3 230V inputs + 3 relay outputs
DomBusEVSE
EVSE module to make a smart wallbox (electric vehicle charging station)
Make your home-made wallbox to charge your electric vehicle!
Only for technicians!!
width="250"
Various
Zigbee bulbs much cheaper then hue or ikea tradfri.
NodeMCU/ESP8266
Nodemcu ESP8266 gear Nodemcu ESP32 gear]
Todo
zigbee2mqtt robot vacuums tuya 433 devices
