Enphase
Domoticz supports the Enphase inverters. For each solar panel a measuring device can be created.
From Stable 2023.1 the Enphase integration has been updated to support Inverters (IQ7/8) and Storage (battery) on firmware 5 and 7.
Firmware 7 supports Authorization tokens, these are also supported.
Create Hardware
- Type: Select
Enphase Envoy with LAN (HTTP) interface - Enabled/Disabled: you can disable the hardware gateway. The created devices stay active (but greyed out) but will not be updated.
- Name: Enter a meaningful name for the Enphase Gateway
- Select Log Levels:
- Info: Shows info logging about the hardware and its devices in the log file or log page. This will normally generate the most log lines
- Status: Shows Status logging in the log file or log page.
- Error: Shows Error logging in the log file or log page.
- Data Timeout: Enable Data Timeout if needed (1 minute to 24 hours). Domoticz will restart the Hardware thread/plugin if after the set timeout still no data is received by the gateway.
- Enter Enphase LAN IP address and port (default 80)
- Enter Username and password of Enphase online (not the installer account). If Token is requested leave empty an store the Token in Domoticz (see Token section)
- Set polling interval ( (5/10/20/30/60/120 seconds)
- Poll Inverters: Enable individual Inverters if needed. This will create a kWh device fore every individual inverter for monitoring.
- Site ID: Fill the Site ID (top left in enlighten site) to be able to switch on/off power generation. A separate on/off switch will be created.
Click on ADD to add the gateway to Domoticz. .
Inverter Devices
After adding the Domoticz Hardware Gateway a General kWh Device type production is created that monitors the complete installation of all inverters.
If Poll Inverters is enabled also a similar kWh device is created for each individual inverter.
Please check the device list (menu Setup - Devices) for new created Enphase devices and activate the if needed.
Note: Domoticz is only monitoring the inverter from 1 our before Sunrise to 1 hour after Sunset. If you enable/start the device outside this timeframe (in the dark) not all devices will be created immediately but only after the inverters become active.
Note: In a previous version of this integration a P1 Smart meter was created. This device is deprecated from 2023.1 Enphase integration and will not be updated anymore if present.
Storage (battery devices)
If the installation consists a storage facility the additional devices are created for monitoring the battery
- percentage device showing the battery level
- a Usage, Electric device that ways how much Watt device drawn or charged (negative value) from the battery
- a text device showing the mode (charging/discharging/idle)
Authentication Token
Note: Only when asked for.
When you are using Firmware 7 and you go directly to your Enphase Envoy's IP address you can be asked to create a token (points you to the website https://entrez.enphaseenergy.com/ to do so)
Then copy this token and past it into the Enphase Envoy Autthentication page (see screenshot below) and submit to login the website.
This token is valid for at least a year when you do so.
Once you have done this, then you can use it in Domoticz.
When Domoticz logs in with the user/password it will read and store the token internally in a UserVariable starting with 'EnphaseToken_'
You can also use the contents of this uservariable to login to your system (instead of creating a new token)
