Domoticz version table V2022.2
From Domoticz Wiki
Revision as of 15:04, 20 June 2023 by Walter vl (talk | contribs)
Changes from 2022.2 to 2023.1
From 2023.1 Stable: By default Domoticz is protected by a username (admin) and password (domoticz). Also major security changes are implemented. Please check Wiki page Security!
Build Date Type Description
15079 20230214 WebUI Livesearch ignoring switchtype when switchtype is "On/Off"
15077 20230214 RFXtrx Added check for type TempBaro
15076 20230214 SBFSpot Fix Frequency of PV invertor display
15073 20230213 MQTT-AD Supporting battery level via value template (Fixed #5595)
15072 20230211 Build Updated History
15071 20230210 RFXtrx Disabled RFX debugging
15070 20230210 RFXtrx Corrected Chime length check caused by new firmware
15069 20230210 Build Updating history
15068 20230210 P1 Meter P1 Meter (DSMR5) added new values (power failures, voltage sags/swells)
15066 20230210 UnZip limiting path
15065 20230210 Livesearch Livesearch enhancements
15060 20230210 MQTT-AD Fixed MQTT-AD Climate, fixed setpoint temperature display (Fixes #5586)
15059 20230209 Uservariables Removed uservariable length check (Fixes issue #5467)
15058 20230209 WebUI Cache non frequently changed files for a day
15057 20230209 WebUI Changed ETag version (Speeds up compiling)
15056 20230209 Enphase Added version number in hardware overview
15054 20230208 WebUI Prevent flash event when browser/tab is not active
15052 20230208 Uservariables Change UserVariables Value type to TEXT
15052 20230208 Enphase Correcting firmware version check caused by PR #5545
15051 20230207 WebUI Merge PR 5589 Updated highcharts
15049 20230207 P1 Meter Don't display usage if it's zero and we have delivery
15048 20230207 WebUI Merge PR 5588 javascrypt syntaxe error
15046 20230206 MQTT-AD Initial support for raw state template with if/else (Fixes #5562)
15045 20230206 WebUI Merge PR 5587 Fix multidevicedelete (fixes #5554)
15042 20230206 Enphase Merge PR 5545 Add installer password to get inverter details
15028 20230205 Eventsystem Eventsystem treat 'Set level' as ON
15027 20230205 Dimmer Restores to previous Set Level state after Off
15026 20230205 Security Setpoint popup when using protection (Fixes #5585, thanks to timmpo)
15025 20230205 Translations Updated translations
15024 20230205 Enphase Using inverter serial as DeviceID (will cause new devices, fixes issues in the feature)
15024 20230205 P1 Meter Corrected P1 Meter display on Dashboard/Utility Page
15021 20230204 Security Dashboard disable scenes/lights if this is disabled by user
15019 20230204 Security Hide scene tabs for admin if this is disabled
15018 20230131 MQTT Increase MQTT keepalive time to 2 minutes
15017 20230131 MQTT-AD Changed compare method
15016 20230131 MQTT-AD Better end of string search method
15015 20230131 Graphs Fixed possible wrong first start value in certain charts (Fixes #5569)
15014 20230131 MQTT-AD Sending status offline when going down
15013 20230129 MQTT-AD Support brightness on RGB sensors (Fixes #5575)
15012 20230127 MQTT-AD Optimized and ignoring more configuration values (Fixes #5566)
15011 20230126 MQTT-AD better handling of config/state messages
15010 20230126 Counters Ignore usage for managed counters
15009 20230125 Timers Merge PR 5567 Weekly planning selector
15006 20230125 WebUI Fixed missing icons (Fixes #5565)
15005 20230124 DataPush Added more error logging for pushers (Fixes #5564)
15004 20230124 WebUI Making sure CustomImage is valid
15003 20230124 WebUI Making sure CustomImage is valid (that got 'somehow') messed up (Fixes #5558)
15002 20230124 Security Merge PR 5557 [OAuth2] Present a nice Auth form instead of using Browser Basic-Auth dialog
14991 20230123 Build Added style sheet to VStudio project, updated history
14990 20230123 WebUI Merge PR 5542 5052 Implement Weekly Planning Selector, Timer, Grid option for selected switches and thermostats.
14983 20230123 Graphs Added graph 'Usage' type for certain charts
14982 20230121 WebUI Fix Fan icon on Floorplan
14980 20230121 MQTT-AD Silence unknown components
14979 20230120 MQTT-AD Silence returned status message
14978 20230120 Enphase Removed debug line
14977 20230119 MQTT-AD better error logging if invalid data is received in discovery topic
14976 20230118 MQTT-AD Small refactoring
14975 20230118 MQTT-AD Small code refactoring and changing order of sensor type detection
14974 20230118 MQTT-AD Merge PR 5548 Allow wildcards in MQTT auto discovery topics
14969 20230117 Enphase Setting inverter device types to computed
14968 20230117 SQLHelper Cleanup code
14967 20230116 MQTT AD Removing invalid topic subscription
14966 20230116 Build Update CONTRIBUTING.md
14964 20230116 Counters Managed counter, update LastUpdate when updating values
14963 20230115 Floorplan Lux sensor did not call correct log method
14962 20230115 MQTT-AD small code refactoring
14961 20230115 MQTT-AD Climate, Preset mode, now has it's own Unit (2) so we can distinguish between other modes
14960 20230114 MQTT-AD small code refactoring
14958 20230113 WebUI Making sure status does not wrap for scenes/lights/switches
14957 20230112 Webserver Small code refactoring
14955 20230111 P1 meter P1 Enabling the possibility that counter values can be less then previous (due to meter change)
14953 20230111 WebUI Merge PR 5525 LiveSearch also searches in Status + displays results count
14940 20230111 WebUI Remove debug alert
14939 20230111 MQTT AD Using position template above state template to solve covers that transmit both (Fixes #5528)
14938 20230110 Translations Update
14937 20230110 Security Merge PR 5522 Removal of Website Protection setting (Only Login screen, Basic-Auth only for API)
14930 20230110 MQTT AD Treat dew point sensor as stand-alone sensor
14929 20230109 Blinds Added the option to schedule a blind open level at 0%
14928 20230109 WebUI Remove unneeded/noisy console log
14927 20230107 Security Moved IP static declaration to header
14926 20230107 Security Merge PR 5504 Improved IP address checking function (used in Proxy header processing)
14922 20230106 Build Merge PR 5523 Gherkin: improve function success/fail handling
14920 20230106 SolarEdge corrected text sensors
14919 20230106 WebUI LiveSearch also searches IDX
14915 20230106 Security Improved checking before default Admin is added, fixes 5513
14912 20230106 Webserver Undo new stock_reply change
14911 20230106 Webserver Added Date and ETag, improve caching refresh
14909 20230105 SolarEdge Forcing json response
14908 20230105 WebUI Fix Weather Tab log page, fixes #5510
14905 20230101 WebUI Revert "Weathertab, hiding devices"
14903 20220101 WebUI Weathertab, hiding devices
14901 20221231 Netatmo Using weathertype to make the correct data request (Fixes #5508), thanks to tuinstoelen
14900 20221228 WebUI Update translations
14899 20221228 WebUI Update info links to Security Wiki
14895 20221226 CounterLogs Aligned day/column
14894 20221226 CounterLogs Removed duplicate chart
14893 20221226 Flootplan Floorplan, fixed percentage icon graph display (Fixes #5497)
14892 20221225 EnOcean Added namespace
14891 20221225 EnOcean Merge PR 5488 Update Blinds behavior to new way of working Fixes #5395
14880 20221223 Docker Build Merge PR 5495 Fixed boost location
14878 20221223 Satel/Integra Merge PR 5491 update/fix read past zone/output 128
14874 20221222 DataPush Make ProcessSendValue static
14873 20221220 Web UI Merge PR 5485 Css Small cleanup
14870 20221220 Web UI Merge PR 5484 Fully responsive SelectMenu
14867 20221220 EnOcean Remarked unused code
14866 20221220 EnOcean changed function argument type
14865 20221220 EnOcean Small code cleanup
14864 20221220 Build Added missing header to Visual Studio project, moved include to .cpp file
14863 20221220 Web UI Fixing browser crash (Fixes #5445)
14862 20221220 Web UI Merge PR 5474 Better TopBar on Mobile fixes #5466
14860 20221219 Build builds on Ubuntu-latest again
14859 20221216 Web UI Merge PR 5475 Fix edit temperature device multi line description
14857 20221216 Security Merge PR 5471 Improve use of Basic Auth as authentication method for API calls with in- and outside Trusted Networks
14856 20221216 Build hardware/EnOceanRawValue.h: include stdarg.h
14855 20221216 Security Merge PR 5464 Deny access on invalid Basic Auth. Retain realhost
14853 20221216 Secutity Basic auth only accepted for Trusted networks
14851 20221215 Secutity Merge PR 5458 Improvements and refactoring of some authchecks
14849 20221215 Secutity Merge PR 5443 Better handling of remote and local proxy headers - Continued
14836 20221215 WebUI Fixed: display correct tabs after login and when creating initial admin user
14835 20221215 WebUI Fixed: Dashboard, not showing disabled sections (temperature/weather/utility)
when a device has multiple properties (for instance temperature + weather)
14834 20221215 WebUI Implemented: User device selection now displays type/subtype
14833 20221214 WebUI Merge PR 5433 Implemented LiveSearch in Lights/Scenes/UtilityTemperatures and Weather page
14833 20221212 Readme Added DigitalOcean sponsor and link.
14831 20221210 Security Merge PR 5452 Revert error status getConfig when no user found
14829 20221210 Arilux Merge PR 5451 fix Mono light type are added as RGB (fix 5448)
14827 20221210 Security FIX: ensure an active admin is present
14825 20221209 Scene/Group Implemented: Scene/Group, option to add manually activation device
14824 20221208 RFLink Made RFLink compatible with new Blind commands (Fixes #5442)
14823 20221206 Blinds Fix Somfy Venetian Blinds with RFXCOM
14822 20221206 Web UI Merge PR 5444 Updates font-awesome to v6.2.1 (for PR #5433)
14821 20221206 Security Merge PR 5430 Improve Trusted Network processing and no more anonymous user
14801 20221204 Build Merge PR 5441 Also domoticstester depends on the revisiontag being present
14799 20221204 Security Merge PR 5425 Better handling of remote and local proxy headers
14796 20221204 Build Use Ubuntu 20.04 (not 22.04) to build to prevent OZW build issues.
14795 20221204 MQTT AD Remove State value when sending brightness without a template (Fixes #5440)
14794 20221203 WebUI Updated translations
14793 20221202 Build Removed OpenZWave from build checks as it is deprecated anyway and caused compile errors
14792 20221202 WebUI Updated Translations
14788 20221202 EcoDevices Fix EcoDevices1 HP Jour Blanc (bug) #5439
14786 20221201 Enphase Remove duplicate value
14785 20221201 InfluxDB Force push daily start value to InfluxDB
14784 20221129 InfluxDB Force send counter value at beginning of today
14782 20221128 P1 Meter Added Tariff 1 and 2 percentage indication and made values bold
14781 20221128 Web UI Order by name queries now case insensitive
14780 20221126 Enphase Refractor code
14779 20221125 Enphase Escaping password and small changes
14778 20221125 Enphase Better error notifications and debug info added
14777 20221124 Enphase Remove strange P1 meter devices
14776 20221124 Login Fixing the last page of the internet link
14775 20221124 Enphase Support for previous firmware versions
14774 20221124 Enphase Sunset/Sunrise tweaks
14773 20221123 Enphase Enphase: Support for firmware 7.x and user defined poll interval
14768 20221122 Enphase Added support for Token (Firmware 7+)
14767 20221122 P1 Meter Possible fix for when multiple Gas meters are configured
14766 20221122 Translations Updated Translations
14762 20221121 EnOcean Add support for all D2-01-XX EEP & misc minor fixes/typos/comments
14744 20221121 OZW Merge PR 5420 Bugfix for MH9-CO2-WA / WD
14742 20221119 MQTT-AD Temperature fix
14741 20221115 Pinger Merge PR 5343 Fix protocol not set for ICMP and update Pinger plugin example
14736 20221115 RFLinkMQTT Merge PR 5376 RFLINK MQTT gateway multi domoticz node sync become configurable
14733 20221115 TeleInfo Merge PR 5388 Fix to French teleinfo with linky set in standard mode.
14728 20221115 WebUI Fixed: Waterflow sensor custom icon (Fixes #5410)
14727 20221114 MQTT-AD Corrected conversion for Fahrenheit
14725 20221114 Enphase Implemented: Enphase, Added battery readings
14724 20221113 MQTT-AD Separate Celsius and Fahrenheit
14722 20221113 WebUI Fixed: Navigation bar display issues on some mobile devices (Fixes #5408)
14721 20221113 WebUI Fixed: Highcharts dropdown menu z-index problem (Fixes issue #5407)
14720 20221112 WebUI Fixed: Mobile display text objects with long lines (Fixes #5398)
14718 20221112 Roomplans Little fix for reverse proxy to show the icons.
14716 20221110 DzVents Implemented HTTP Patch command #5404
14714 20221110 Security SECURITY_SETUP.md Corrected version info
14713 20221108 Security Various Security updates
14708 20221107 Security Merge PR 4872 Security updates and implementation of OAuth2 (RFC6749), PKCE extension (RFC7636) and JWT Tokens (RFC7519)
14600 20221105 Build Preparations for release 2022.2
