Eastron SDM120C
From Domoticz Wiki
Revision as of 08:12, 30 March 2022 by Walter vl (talk | contribs)
How to get the info from SDM120c DIN-rail kWh meter into Domoticz
Hardware needed
-Eastron SDM120C (approx. €20)
-RS485 to USB convertor (€ 0.70)
Installing SDM120c
sudo apt-get install libmodbus5 libmodbus-dev git
git clone https://github.com/gianfrdp/SDM120C.git
cd SDM120C
make clean && make
sudo make install
cd ..
Domoticz
Add dummy and virtual device Electric(Instant+counter)
Script for reading SDM120C and putting it in Domoticz
Make a file and copy code below
#!/bin/bash
#title           :solar
#description     :Read current from sdm120 and sends it to Domoticz.
#author		 :JM
#date            :20160605
#version         :0.1
#usage		 :./solar
#notes           :
#bash_version    :
SERVER="http://###.###.###.###:###"   #server location
IDX=#	  #id of your device
#SDM120C
SDM120="/home/pi/SDM120C/sdm120c" #location sdm120c script
TTY="/dev/ttyUSB0"		  #USB port sdm120c
CURRENT=$($SDM120 $TTY -p -q -z 10 | awk '{print $1}') #get current from sdm120c
# echo "$SERVER/json.htm?type=command&param=udevice&idx=$IDX&nvalue=$CURRENT&svalue=POWER;ENERGY"
x=0
for gelezenWaardE in $($SDM120 $TTY -z 10  -ip|awk -F ":" '!/OK/ {print $2} '|sed 's/[ a-zA-Z]//g') ; do
if [ ! $x -eq 1 ]; then
	watt=$gelezenWaardE
	x=1
	kilowattuur=$(($gelezenWaardE/1000))
fi
done
curl -s {"$SERVER/json.htm?type=command&param=udevice&idx=$IDX&nvalue=0&svalue=${watt};${kilowattuur}"}  #send current to domoticz
curl -s {"$SERVER/json.htm?type=command&param=addlogmessage&message=SolarSDM120Update"}  #send current to domoticz
Change the file to your specific situation and add to cron
SDM220-Modbus adaptation
cd SDM120C
make clean && make
sudo make install
cd ..
Adding "-P N" could solve "NOK issues" while reading values
sdm120c -P N /dev/ttyUSB0 -p -t -q
Modified sdm220.sh script
File : /home/pi/domoticz/scripts/user/sdm220.sh
SERVER="http://127.0.0.1:8080"   #server location
IDX=1974          #id of your device
VALUES=NOK
#echo $VALUES #Debugging line
while [ "$VALUES" = "NOK" ]
do
        VALUES=`/usr/local/bin/SDM120C/sdm120c /dev/ttyUSB0 -P N -p -t -q` #p=power / t=total / q=short output
#       echo $VALUES #Debugging line
done
        POWER=`echo $VALUES | cut -d ' ' -f1`
        TOTAL=`echo $VALUES | cut -d ' ' -f2`
curl -s {$SERVER"/json.htm?type=command&param=udevice&idx="$IDX"&nvalue=0&svalue="$POWER";"$TOTAL""}  #send current to domoticz
Automating readings
Domoticz logs on 5min periods, let's create a 5min cronjob
crontab -e
*/5 * * * * /home/pi/domoticz/scripts/user/sdm220.sh >/dev/null 2>&1
