Multifun
From Domoticz Wiki
Revision as of 16:16, 25 March 2022 by Walter vl (talk | contribs)
Controller for controlling retort boilers and pellet burners. The versions for eco-pea coal are equipped with a patented, extremely effective method of automatic selection of fuel doses. The heat sensor controls the height of the furnace and corrects the amount of fuel fed. This system has several thousand implementations and has been operating on the market for 6 years without failure. As a standard, the controller is equipped with an ETHERNET connector, which enables remote management of the boiler room via the Internet.
http://recalart.com/multifun/
To add to Domoticz
  • Setup -> Hardware.
  • Configuration:
    • Type: select 'Multifun LAN'.
    • Name: Enter a unique name to identify the controller in Domoticz
    • Remote address: set the ip of your Multifun Controller.
  • Press Add.
  • At the first connection, the system will be scanned and the supported devices will be created automatically*.
  • Setup -> Devices will show all the newly added devices.
