SharingSerialDevices
From Domoticz
Revision as of 13:34, 22 November 2021 by Walter vl (talk | contribs) (This guide is not finished)
Ser2Net
With 'ser2net' you can share serial devices under unix over TCP/IP
Installation
sudo apt-get install ser2net
a configuration file is created in /etc/ser2net.conf
an example line to share an opentherm gateway can be:
2000:raw:400:/dev/ttyUSB0:9600 8DATABITS NONE 1STOPBIT
an example line to share an zwave usb stick:
2000:telnet:600:/dev/ttyUSB22:115200 8DATABITS NONE 1STOPBIT
In both cases the serial port is shared on port: 2000
Example USB/serial connections to DSMRv4 smart meters
2001:raw:600:/dev/ttyUSB0:115200 NONE 1STOPBIT 8DATABITS XONXOFF LOCAL -RTSCTS
Example USB/serial connections to DSMRv2.2 smart meters
2001:raw:600:/dev/ttyUSB0:9600 EVEN 1STOPBIT 7DATABITS XONXOFF LOCAL -RTSCTS
Windows
It is possible to create a virtual comport that can connect to a ser2net share.
VSP application:
http://new.hwg.cz/download/sw/version/hw-vsp3-single_3-1-2.exe
Unix
To create a virtual comport, use the program socat
sudo apt-get install socat
example to create a USB device that connects to a share on host 192.168.0.116 on port 2000:
sudo socat pty,link=/dev/ttyUSB30,raw,echo=0 tcp:192.168.0.116:2000
this creates a /dev/ttyUSB30 serial device link
Auto start socat on boottime
git clone https://github.com/asaif/socat-init.git
sudo cp socat-init/socat /etc/init.d/
sudo chmod +x /etc/init.d/socat
sudo update-rc.d socat defaults
sudo cp socat-init/defaults/socat.conf /etc/default/
Now edit the configuration file like:
sudo vi /etc/default/socat.conf
OPTIONS="pty,link=/dev/ttyUSB30,raw,ignoreeof,echo=0 tcp:192.168.0.116:2000"
start the service with:
sudo service socat start
you can check the status with:
sudo service socat status
