StookAlert
From Domoticz
Revision as of 07:46, 20 August 2021 by Walter vl (talk | contribs) (StookAlert (only for the Netherlands))
Note: The old script that was here is not working anymore due to change of API on the website.
DzVents script that gives advice by RIVM when it's suitable to use your wood-burning stove. For more info: https://www.rivm.nl/stookalert
  • Create a dummy Alert Sensor, it will appear in the utility tab.
  • You can copy and paste this dzVents script with Setup - More Options - Events. Create a new dzvents script with trigger HTTP and paste the contents over the template.
  • Modify the script with your province and the idx of the Alert Sensor.
dzVents Script
-- StookAlert.
-- The stookalert sensor platform queries the RIVM Stookalert API for unfavorable weather conditions or poor air quality.
-- With a Stookalert, the RIVM calls on people not to burn wood.
-- This can prevent health problems in people in the area.
local Provincie = 'Noord-Brabant' --  Set Provincie to correct value: Drenthe, Flevoland, Friesland, Gelderland, Groningen, Limburg, Noord-Brabant, Noord-Holland, Overijssel, Utrecht, Zeeland or Zuid-Holland
local Alertidx = 359 -- Change to your idx for the Virtual Alert sensor you have created for this script
-- no changes needed below this section
		timer = {
			'at 12:15' -- RIVM updates the json at 12:00 hrs, running it between 0:00 and 12:00 results in an error.
		httpResponses = {
			'triggerSA' -- must match with the callback passed to the openURL command
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'StookAlert',
		if (item.isTimer) then
		    local Currentdate = domoticz.time.dateToDate(tostring(domoticz.time.rawDate),'yyyy-mm-dd', 'yyyymmdd')
		    domoticz.openURL({
				url = 'https://www.rivm.nl/media/lml/stookalert/stookalert_' .. Currentdate .. '.json',
				method = 'GET',
				callback = 'triggerSA', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
					local result_table = item.json
					local tc = #result_table
					for i = 1, tc do
					    if result_table[i].naam == Provincie then
                            StookAlertValue = result_table[i].waarde
					domoticz.log('StookAlertValue = ' .. StookAlertValue, domoticz.LOG_INFO)
					if StookAlertValue == 0 then
					    level = domoticz.ALERTLEVEL_GREEN 	-- domoticz.ALERTLEVEL_GREY, ALERTLEVEL_GREEN, ALERTLEVEL_YELLOW, ALERTLEVEL_ORANGE, ALERTLEVEL_RED
					    AlertText = 'Geen Stookalert'
					    level = domoticz.ALERTLEVEL_RED
					    AlertText = 'Stookalert!'
					-- update some device in Domoticz
					domoticz.devices(Alertidx).updateAlertSensor(level, AlertText)
				domoticz.log('There was a problem handling the request' .. url, domoticz.LOG_ERROR)
				-- domoticz.log(item, domoticz.LOG_ERROR)
