Domoticz version table V2020.2
From Domoticz Wiki
Revision as of 22:37, 17 April 2021 by Rwaaren (talk | contribs) (Version table V2020.2)
Build Commit Date Type Description
13189 99aa1589b 20210416 Docker Docker rename XML parser helpfiles to dzVents/runtime
13188 9328c9173 20210416 Docker Added JSON.lua to dzVents folder (Solved userdata folder issues)
13187 be54d86ae 20210416 USBTin Fixed string buffer initialization and some minor log issues
13186 25e232852 20210415 dzVents Update documentation / wiki
13185 c9e299be2 20210415 Build Merge PR 4772 from xbeaudouin; Added CMake changes to allow external libfmt on FreeBSD
13182 d9461c66e 20210415 Logging Merge PR 4777 from gizmocuz; Use new Log method to allow user controlled logging for all hardware
13179 772a02ce4 20210415 MQTT Change from user controlled message to debug (hardware) message.
13178 22430617a 20210415 MQTT Merge PR 4776 from waaren; Use new Log method to allow user controlled logging
13176 8416fa012 20210414 Build Merge PR 4770 from neheb; Start using fmtlib (faster than C format functions)
13165 41b1ae7f6 20210414 USBTin Fixed compile warning and reformatted code.
13164 35209ce02 20210413 USBTin Merge PR 4769 from Reivax851; Added support for Bloc 9 & Multibloc improvements
13161 66437a25f 20210413 Build Added external submodule fmtlib
13155 0ea903e09 20210412 OpenZwave Fix for nodes reporting multiple voltage sensors.
13154 775fb7986 20210412 EvoHome Merge PR 4767 from sidepipe; Added the ability to set an EvoHomeWeb setpoint until next switchpoint in schedule
13151 4282c8af2 20210412 dzVents Removed duplicate templates
13150 92c15ba44 20210407 dzVents Added resilience to round function against wrong type of value parm
13148 2a8cd5c17 20210407 GUI Merge PR 4762 from paalkr; Filter Zwave devices on ID using hardware selection mechanism
13143 71cfe752f 20210406 dzVents Make deSerialize of JSON string optional
13142 b94c2eba5 20210402 dzVents Fix to escape backslash in deSerializeJSON()
13141 29258732b 20210402 dzVents Deserialize nested serialized JSON strings before conversion to Lua table
13140 749a45896 20210402 Meteorologisk Merge PR 4754 from kiddigital; Refactoring, saver handling of wrong parameters, etc
13135 956395bb9 20210331 dzVents Code refactoring
13134 ff5a0f66d 20210331 Logging Added debug message for rain subtype sTypeRAINByRate
13133 399b22fa4 20210330 Teleinfo Merge PR 4755 from lunakato; Added support for Teleinfo connected over TCP
13129 43d4f559f 20210330 Logging Using real hardware name instead of shortname
13128 32872b869 20210329 EvoHome Merge PR 4753 from brucemiranda; Capture ID from OpenTherm Bridge
13124 55e527e9a 20210328 Python plugins Merge PR 4752 from guillaumezin;Prevent Async Secure Read Exception: 335544539 on SSL/TLS connection
13122 41a579a15 20210326 RTL433 Merge PR 4749 from Chrominator; Rollback moisture sensor Opus-XT300 from custom to previous moisture
13119 7d4e73906 20210326 Energy device exception safe instructions to help solve wrong values in the database
13118 080667355 20210326 Energy device Added safety try/catch in UpdateDevice , fixes a possible crash when invalid data
13117 af2a7788f 20210325 Energy device issue 4736 Corrected old value
13116 402ce8ddb 20210325 Build Ignoring sub modules while checking current project status
13115 26c92c432 20210325 Energy device issue 4736Always returning Meter type
13114 7578da23d 20210325 Energy device issue 4736Assigning the correct pointer to sValue
13113 0904ed783 20210325 Energy device issue 4736Added another error message if a invalid sValue was found
13112 7047724b7 20210325 Energy device issue 4736Log when there is a invalid sValue
13111 f3d4586f4 20210324 Energy device issue 4736Improved fix (2nd try) for issue 4733; Corrected Energy read (Computed)
13110 d802f64e9 20210324 dzVents Fixed typo in dayname and added logging section to templates
13109 c997900e7 20210323 dzVents Code refactoring
13108 682afb813 20210322 dzVents Merge PR 4742 from waaren; Update to 3.1.7
13107 b4810fc88 20210322 GUI Merge PR 4735 from ridderr; Corrected speaker and blinds in dashboard view
13104 7b6aa32b1 20210321 EventSystem Merge PR 4741 from gizmocuz; Revert PR 4715 "Use standard mutex code"
13102 eb16e884f 20210321 OpenZwave Merge PR 4738 from gizmocuz; Do not check for a dimmer label anymore
13100 2daccab5c 20210321 Clang-Tidy Merge PR 4710 from neheb; replace some boost functions with std versions
13098 2b6796d93 20210321 Build Remove compile warning
13097 5986b8e24 20210321 EventSystem Merge PR 4715 from gizmocuz; Use standard mutex code
13092 9d3ca3b2b 20210321 Energy device issue 4736 Improved fix for issue 4733;Corrected Energy read (Computed)
13091 c5dc8c071 20210318 OpenZwave Added Volatile Organic Compound sensor
13090 997cd0e3b 20210318 Notification Undo Fix for issue 4730; Ungraceful shutdown on OSX
13089 e98ee3c1a 20210318 Notification Fix for issue 4730; Ungraceful shutdown on OSX
13088 eedd56a0f 20210318 Energy device issue 4736 Fix for issue 4733; Crash for kWh sensor when sValue left empty at device creation.
13087 c61798d92 20210317 EnOcean Added test option
13086 e24938bb6 20210317 EnOcean Moving mutex one up
13085 e75ec258d 20210316 dzVents Update Documentation, added tests and allow cross dates for delta to astronomical moments.
13084 28e6925de 20210316 Notifications Added missing mutex
13083 1d32fffce 20210316 EnOcean Merge PR 4731 from alexis-via; restore default profile to F6-02-01
13081 64ab30323 20210315 dzVents Fix for bug in Time handling
13080 68b6cf7de 20210315 Python plugins Fix for issue 4727; heartbeat issue and start creating Python Device objects correctly
13079 b5787da30 20210314 dzVents Performance improvement and simplified Time rule handling
13077 1100c86b6 20210313 Clang-Tidy Merge PR 4718 from neheb; Run through performance checks
13075 05471a94f 20210313 Windows Added uninstall icon
13074 9d65bc5c1 20210313 Windows Merge PR 4726 from laplug; Fix for Issue 4622 Naming log fail when path\name have spaces
13072 69288d9eb 20210312 Python plugins Merge PR 4720 from cclauss; Various mods and checks on github actions
13065 e31c70c24 20210311 Build Bumping version
13064 da41e4918 20210311 OpenZwave Updated configuration files
13063 2e54c3e25 20210310 dzVents Fixed bug in timerules with except and code cleanup
13062 d4081b7d6 20210310 Python plugins Add event Target functionality to Connections objects
13061 1b8136370 20210309 dzVents Merge PR 4716 from waaren; Update to 3.1.6
13060 739ba60b0 20210309 Build Disabling Github Actions (glibc_2.29 issue)
13059 224afb952 20210309 Build Travis, updating cmake and boost, forcing gcc 8
13058 066f3f261 20210308 Notifications Fixing not existing notifier deletion error
13057 82888c165 20210308 Python plugins Move plugins to have separate event queues
13056 a2ec619d7 20210308 Various code Refactoring
13055 5cf81a473 20210307 Clang-Tidy Merge PR 4713 from gizmocuz; Revert "PiFace: constexpr conversions"
13053 da7565067 20210307 Clang-Tidy Merge PR 4709 from neheb; replace boost::array with std version
13051 4b7cd2a69 20210304 EvoHome Merge PR 4707 from brucemiranda; Process OpenTherm Status flags like in OTGW
13049 f7ff8a4b6 20210303 Limitless Adding empty destructor (who knows what the feature might need)
13048 37c6017ba 20210303 Limitless Reverted 'const' changes (Clang-Tidy)
13047 f41681015 20210303 EvoHome Merge PR 4706 from brucemiranda; Process negative OpenTherm data
13045 0692d2d0c 20210302 HEOS Merge PR 4703 from MarcBeige; Harmonize and fix log messages
13042 b6987feb1 20210302 Python plugins Add local variable dump on Python exception when debugging is turned on
13041 f17754040 20210301 EvoHome Merge PR 4699 from brucemiranda; Adding new baud rate for Evohome DIY devices
13039 20b58ac45 20210301 openWeathermap Merge PR 4698 from kiddigital; Updated hardware settings in GUI incl. warning text
13034 e0367843f 20210228 Clang-Tidy Reverted make shared
13033 d66c9b72e 20210228 MySensors Merge PR 4697 from derrij; Fix 4691 Integer overflow when parsing Samsung TV IR codes
13031 0c0647c58 20210228 Clang-Tidy Merge PR 4694 from neheb; (boost dependency) changed boost::to_string to std::to_string
13029 ae04872b0 20210228 Clang-Tidy Merge PR 4693 from neheb; Change luathread variable name
13027 1db6c5859 20210228 JSON Merge PR 4684 from waaren; Added option to delete daterange of one ID in history tables
13023 2720cb89f 20210228 Python plugins Add Device dictionary reference count checking on stop. Bugfix: Python exception
13022 a926555ca 20210226 Build Fix Clang compile error
13024 9c50b09d2 20210226 Clang-Tidy Reverted 13017-13022 and reset build numbering due to GUI hangs
13022 633a7f502 20210226 Build Fixed compile error and warning under debug mode
13021 0ab8945f7 20210226 Clang-Tidy Merge PR 4681 from neheb; EventSystem: constexpr conversions
13019 98ce14e1d 20210226 Clang-Tidy Merge PR 4667 from neheb; Remove std::fill
13017 06f5f78dd 20210226 Clang-Tidy Merge PR 4679 from neheb; Manual conversion to use std::make_unique
13015 6ae6747d5 20210226 Python plugins Merge PR 4687 from moroen; Fix terminate plugin subinterpreters on exit
13013 e3de18052 20210226 Python plugins Rolled out Python smart pointers to majority of codebase
13012 8e6c646e6 20210226 Build Fix link issue on some platforms caused by cb587d035
13009 0450852fe 20210225 HEOS Merge PR 4665 from MarcBeige; Increase buffer size for HEOS to allow more then 6 players
13007 658e30b6b 20210225 Python plugins Add onTimeout functionality to secure TCP
13006 cb587d035 20210225 Python plugins onTimeout integrated into TCP and Serial transports
13005 0455e25e9 20210224 Python plugins Add onTimeout callback and convert to using CConnection type rather than PyObject
13004 1644caa8e 20210224 Clang-Tidy Merge PR 4676 from neheb; BleBox: constexpr conversion
13000 59676ed60 20210224 Clang-Tidy Merge PR 4678 from neheb; Limitless: constexpr conversions
12997 438cf3d29 20210224 Clang-Tidy Fixing missing close character
12996 ffe181139 20210224 Clang-Tidy Merge PR 4677 from neheb; Honeywell: constexpr conversions
12994 70db48fb8 20210224 Clang-Tidy Merge PR 4675 from neheb;PiFace: constexpr conversions
12992 f17d422ea 20210224 Clang-Tidy Constexpr conversions
12991 8b319e342 20210224 Clang-Tidy Merge PR 4673 from neheb; Reply: constexpr conversions
12987 f49dffc17 20210224 Clang-Tidy Correcting indent
12985 fbeb51768 20210224 Python plugins Prevent staic pointer from being reset to null
12984 8f28c734a 20210224 Python plugins Prevent Python 3.9 crashing on plugin stop
12983 20e62fd9b 20210223 Python plugins Merge PR 4669 from jkl1337; Fix 4487 Python 3.9.x segfault on exit
12981 e23daf343 20210223 Clang-Tidy Merge PR 4668 from neheb; constexpr conversions of point
12979 a921551dd 20210223 HEOS Merge PR 4666 from MarcBeige; Fix HEOS list of players parsing
12976 f4fdc10aa 20210222 EvoHome Merge PR 4663 from brucemiranda; Query the opentherm bridge parameters
12974 987b6ff13 20210221 dzVents Merge PR 4659 from waaren; Fix for 4658 Wait and kill commandShell processes that already ended
12972 cdb12d4ff 20210219 Clang-Tidy Fix for 4653; Iterator pointer parsing issue
12971 41e4e6cac 20210219 Spelling Correcting MHz spelling typo
12970 6ca0a88db 20210218 Clang-Tidy Merge PR 4646 from neheb; std::bind, lambda, and GCC6 fixes
12967 aa318cf64 20210217 Timeplan Merge PR 4645 from waaren; Fix for issue 4643; Timeplan duplication copies none existing Hue field
12965 1f62acaf7 20210216 OpenZwave Merge PR 4642 from markruys; Preserve whitespace for help texts
12963 d53ced590 20210215 dzVents Correct some typos in documentation and comments
12962 f69138705 20210213 EvoHome Merge PR 4634 from brucemiranda; Add support for day-off with Eco controller mode
12953 9b34272b0 20210213 EnOcean Merge PR 4629 from alexis-via; Add support for F6-05 profiles.Smoke, wind, liquid + RSSI
12949 667184580 20210213 dzVents Merge PR 4635 from waaren; dzVents update to 3.1.5
12947 1bb6920ea 20210211 OpenZwave Updated OpenZWave configuration files
12946 7e735f0ca 20210211 Clang-Tidy Removing unneeded string casts
12945 b38c19636 20210211 Clang-Tidy Merge PR 4630 from neheb; various Clang-Tidy commits
12945 1bbd53e25 20210211 Clang-Tidy Add missing namespace comment
12945 d2e412ea2 20210211 Clang-Tidy Use TAB instead of spaces
12945 bb8b7b90a 20210211 Clang-Tidy Use empty for strings
12945 285825456 20210211 Clang-Tidy Uppercase numeric literals
12945 cf7c1f138 20210211 Clang-Tidy Add missing commas to string literal
12945 fc3278f78 20210211 Clang-Tidy Fix misplaced widening cast
12945 e907fd85e 20210211 Clang-Tidy Fix too small loop variables
12945 1e9e8cc1b 20210211 Clang-Tidy Performance fixes
12936 c61652754 20210211 Data push Removed unnecessary conversion from string to float to string
12934 53b29b4f8 20210210 Clang-Tidy Merge PR 4625 from neheb; fix for some lambdas
12932 71d2fc229 20210210 Connected cars Merge PR 4628 from MrHobbes74; Fixed bug in home detection and added testcar API
12928 f88134a7a 20210210 Windows Removed duplicate function and added quotes for log path
12927 5c76d5189 20210209 Windows Fix for issue 4622 Windows installer to respect log output parameter setting
12926 4bb40f8b2 20210208 EventSystem Removing state when set unused, and calling Update single-state when set to used
12924 c468e44fd 20210208 EventSystem Merge PR 4619 from waaren; Get device record from database with ID as key
12923 a0df24ebd 20210207 Webserver Corrected API response for setdevused call and combined two DB updates into one
12922 d928e9301 20210207 1Wire Added Temperature memory
12921 3596d5663 20210207 Webserver Add API Enable/Disable a device or sensor. See this API wiki page
12920 e5cb7d3fd 20210207 Clang-Tidy Merge PR 4615 from neheb; Uses C++14 auto lamba parameters for bind
12918 31664ae46 20210207 Webserver Fix for issue 4617 Keep current custom image when device set to used
12917 226d200b1 20210205 Connected cars Merge PR 4614 from MrHobbes74; Added support for manual API key
12914 5ca0a2fe3 20210204 Xiaomi Merge PR 4612 from waaren; Fix for issue 4610; Added missing definition for new model wireless double key switch
12913 c9dabef7f 20210203 OTGW (OpenThermGateWay) Added DHW (Domestic Hot Water) Flow Rate
12912 fc27e7fbe 20210203 OTGW Merge PR 4605 from kiddigital; Fix for firmware 5.0 (OpenThermGateWay)
12904 ae9d858b1 20210203 Build Removed building for docker. this will be done differently for official Domoticz docker
12903 90501be77 20210203 MQTT Disabled verification of remote certificate
12902 6df6a4f7b 20210202 GUI Fix function call to distance sensor edit mode
12901 b6dc22e8b 20210201 dzVents Allow yyyy-mm-ddThh:mm:ssZ format in time strings
12900 9cca890b4 20210201 Build Merge PR 4604 from kiddigital; Updated github action, added artifact upload and excluded some actions for forked repos
12898 f784e2637 20210131 EvoHome Merge PR 4603 from brucemiranda; Add new device class
12896 d5c2e6a46 20210130 SatelIntegra Merge PR 4602 from neheb; Fix for mistakenly removed code
12895 88bdccdc7 20210129 Webserver Add IP number to logmessage when parsing HTTP give an error
12894 e4f2cbbbd 20210129 dzVents Merge PR 4598 from waaren; Update to 3.1.4 (fix for issue 3805 )
12893 7a4475449 20210127 GUI Fix for issue 4593 Crash when accessing settings on Windows; Corrected Gui Language array size
12892 cb924ffe3 20210126 Python plugins Redirecting Python logs to plugin log function
12891 71c3177d0 20210126 dzVents Fix for missing statusText in ShellCommandResponse and wiki update
12890 6c8b48c2a 20210126 Build Merge PR 4594 from neheb; Explicitly set C++ version to 14
12888 d5f6ad751 20210125 Connected cars Merge PR 4592 from kiddigital; Improved mercapi handling
12884 75cc8eddf 20210124 Clang-Tidy Merge PR 4588 from neheb; Manual constexpr conversions
12883 1a7e11b7d 20210124 Webserver Implemented a safer way to clean web server sessions
12882 a302ec7f7 20210123 dzVents Allow setKelvin method for devices with subtype 'White'
12881 b2d1bf16d 20210123 dzVents Merge PR 4590 from waaren; Update to 3.1.3
12880 c3df51e90 20210122 dzVents Merge PR 4588 from Chrominator; Adding clickatell as addressable notification subsystem.
12878 33405d5b7 20210122 Build Changing package folder and disabling default debug to SSH feature
12877 d9a767507 20210122 Build Check/Build Pull Requests
12876 f1ddb5e5e 20210122 Build disabled debug session of github actions
12875 fb1c0603d 20210122 Build Updated SSH session of github actions
12873 4548816ba 20210121 Build Merge PR 4587 from stas-demydiuk; Added docker build step to github actions
12872 dc09476b4 20210121 Hardware Merge PR 4578 from rpeyron; Added option to Panasonic hardware to allow to send command even if off
12870 04c10b9bb 20210121 Various code Merge PR 4585 from akamming; Run some scheduled tasks in their own thread
12869 d85316aa3 20210121 Build Upload new package folder to github actions
12868 f214e1cbc 20210121 Build Checking out complete branch
12867 b7d35043a 20210121 Build Travis, reverting to sftp github Actions, correcting openzwave checkout/build path,
12866 13354bc08 20210121 dzVents Merge PR 4586 from waaren; Update to 3.1.2
12865 58e5f8eb2 20210120 Build Changed FTP protocol in github actions
12863 b6534437d 20210120 Python plugins Fixed reference count error on traceback during logging
12861 7a208b76b 20210119 dzVents Added resilience to openURL() and getColor()
12860 31cf3bb9b 20210119 Build Added and modded Git Actions project file ( build 12851- 12860 )
12850 f1bd4dbde 20210117 History Updated History
12849 6ed3faccf 20210116 Floorplan Merge PR 4579 from kiddigital; Allow custom icons and control Thermostat SetPoints
12847 815e12372 20210116 Python plugins Fix for ill behaving Python plugins
12846 fba44b2cf 20210116 Hardware Fix for issue in PR 4581
12845 53eb433af 20210116 Hardware Merge PR 4581 from gizmocuz; Control log level output per hardware device
12844 b1feeb963 20210115 OpenZwave Updated configuration files
12843 24b1f259f 20210115 OpenZwave Fix for issue 4567 and issue 4580 thermostat/fanmode thanks to Richard (rrozema) for finding!
12842 f7159ed8e 20210115 Python plugins Merge PR 4576 from ultrasuperpingu; Implemented multiline parameters in python plugins.
12841 192869ee8 20210114 MQTT Merge PR 4577 from brjhaverkamp; Expand MQTT command sendnotification to add control
12840 3c140ffe9 20210114 dzVents Fixed wrong function name in call and some typos in documents
12839 743a0d1ab 20210111 GUI Fix missing log button for some types on devices tab
12838 f9b16e91a 20210110 GUI Fix for issue 4567 to make option edit for thermostat devicetypes available again
12837 5fd9c67cd 20210109 GUI Fix for issue 4567 to make option edit in setpoint device available again
12836 ee047941d 20210109 OpenZwave Removed obsolete and duplicate functions
12834 bb0865d7d 20210108 dzVents Make framework more resilient against datafile corruption
12833 680ddf657 20210108 Data push Change push type selection mechanism
12832 7345524d1 20210108 OpenZWave Change default for reload after update of config file
12831 74143cda3 20210108 OpenZWave Removed debug code
12830 ef6f7559c 20210108 OpenZWave Change default for auto update of config file
12829 a730c98b8 20210107 dzVents Documentation: clarified use and effect of methods for counter type devices
12828 7a7c9645c 20210107 Various code Prevent crash when wrong values have been entered in database
12827 30f4c413a 20210107 JSON Fix for issue 4564 JSON API retrieve all Favorite devices returns all devices
12826 745eb5da7 20210107 OpenZwave Protect against extreme negative NeoCoolcam power values
12825 5befa3819 20210106 Data push Small refactoring
12824 83d89fd31 20210105 Data push Improving Pusher speed and logic
12823 f76abeb15 20210105 Data push Refactored code
12822 78bcd6184 20210105 Database Pushlink index change from 0-based to 1-based carried trough in database
12821 434eebeba 20210105 Data push Fixed typo in commit 7a74f7665
12820 192ab515e 20210104 dzVents M Update to 3.1.1; Fix for 4557 Access to domoticz API when started in sslwww only
12819 141a839cf 20210104 Data push Removed requirement for device var; possible fix for 4555
12818 7a74f7665 20210104 Hardware Merge PR 4559 from tofbouf; Fix for PR 4558 Motherboard Sensors on Linux shows wrong disk usage for big partitions
12815 622f8704a 20210103 OpenZwave Merge PR 4545 from gizmocuz; Simplified interface between domoticz and Zwave
12813 90c7e2a3f 20210103 OpenZwave Updated configuration files
12812 3571a43e0 20210103 Icons Fix for 4555 Custom icon upload not working on linux clients/browsers
12811 19c0d8ab0 20210102 Switches Removed unnecessary blanking of colon character when adding a selector level
12810 510641411 20210102 Data push Fix for 4528 Could not determine data push value
12806 fa67c059f 20210102 GraphLog Fix for empty logpage incremental counter.
12805 ca09c4302 20201231 Connected cars Merge PR 4554 from kiddigital; Added Status message for non-standard HTTP results in Mercedes Api
12803 58dcc3054 20201231 GraphLog Merge PR 4553 from michahagg; Various charts fixes and improvements.
12790 96da3e655 20201231 Various code Merge PR 4551 from akamming; Changed compiletime debug-logging to runtime debug-logging.
12787 7ed456b27 20201231 GUI Merge PR 4552 from ultrasuperpingu; Add option to change icons of Utility sensors.
12781 b6d2ef4ed 20201230 Connected cars Merge PR 4550 from kiddigital; Create switches instead of textsensor for boolean custom values
12779 544fc4b9d 20201230 Connected cars Merge PR 4549 from kiddigital; Handle wrong or empty battery readings
12778 0ad350991 20201230 GUI Fix for dashboard only showing starred devices when filtered on room
12777 a26097387 20201230 JSON Merge PR 4548 from waaren; Add active state to gettimerplans call
12776 031de90a0 20201230 Build Travis using GCC-9
12775 ad68a32b8 20201230 Build Update Travis GCC version
12774 62f928726 20201229 Connected cars Merge PR 4544 from kiddigital; Fix for Mercedesme; handle HTTP/2 and other response headers correctly
12773 262da4b23 20201229 dzVents Add attribute trigger to shellCommand and documentation update
12772 e38643616 20201229 OpenZwave Add check for UK wall plug
12771 c4eb9288c 20201229 dzVents Merge PR 4538 from akamming; Update to version 3.1 (async shell commands)
12763 6a5ec4566 20201228 OpenZwave Merge PR 4542 from tih; fix Zwave powermeter check
12760 f241cb615 20201226 OpenZwave Updated configuration files
12759 2b4abd06b 20201226 GUI Some modifications to the dark theme to make the settings look correct
12758 6a15a234d 20201223 GUI Merge PR 4535 from rpeyron; Allow custom URLs in menu
12753 5dd9ae977 20201223 Hardware Merge PR 4536 from rpeyron; Add customizable buttons to the default remote for Panasonic TV
12750 d6010644d 20201223 Icons Merge PR 4498 from ultrasuperpingu; Make CustomImage of Utility devices visible to javascript and use it …
12746 b2effc582 20201223 Build Fix for mosquitto build issue (introduced upstream)
12745 35f6cfeaa 20201223 BeNext Merge PR 4533 from Catfriend1; Fix for 4532 Doorsensor no longer update its values to domoticz
12743 28537b5bb 20201222 Data push Ensure level is 0 when device is 'Off'
12742 4cd052245 20201216 Hardware Merge PR 4523 from waaren; Add WW Switch to dummy hardware device type selection list
12741 fee1840ed 20201214 Data push Include attribute level in push for supported switches
12739 f5112567d 20201214 GUI Fix for 4519 Don't return any device in a room plan as favorite
12738 7a65ccbb5 20201214 Python Plugins Merge PR 4518 from badzz; Fix for plugins blocking the Global Interpreter Lock
12736 1ac46bada 20201210 Xiaomi Removed obsolete header file
12735 246c3d2c1 20201210 Xiaomi Merge PR 4514 from EvgenaNet; Adding new switch Aqara D1
12733 dc49adf91 20201208 dzVents Merge PR 4510 from waaren; Update to 3.0.19
12731 7933f659d 20201206 OpenZwave Extra checks for some zwave power/energy hardware
12730 235f51257 20201205 dzVents Update to 3.0.18
12729 93528ce11 20201204 dzVents Add boolean isdst to time object
12728 a82fe999f 20201204 Clang-Tidy Merge PR 4504 from neheb; Various Clang-Tidy code changes
12723 fa53b4f64 20201203 Build Add mosquitto include folder
12720 bad685fab 20201203 dzVents Simplified and documented attributes for Evohome relay device
12716 ee672d111 20201202 dzVents Made stringSplit function more robust and better to control
12715 e5d28e572 20201201 dzVents Fix for some small bugs and typo
12714 7bc38657e 20201201 Daikin Merge PR 4499 from jgaalen; Add yearly energy usage for kwh meter
12711 4213df05a 20201129 Update Dealing with old Travis curl version
12710 cc6ba3cfb 20201129 Update Travis deploy retry and updated command line
12709 7dfcb3d5c 20201129 Update Checking updater (gz) file integrity after donwload before update
12708 5a59d036c 20201128 Update Force rebuild of tar for windows / linux
12707 596a86acb 20201127 dzVents Add script summary logging when debugging
12706 5f4621fbb 20201126 dzVents Exception for Lux device no longer needed
12705 d05c1201b 20201125 Python plugins Fix for issue 4487; Crash on exit with Python 3.9.0
12704 76d00efd4 20201124 Database Merge PR 4488 from waaren; Workaround for extreme sized sValue field of Preferences table
12702 cb1a8effb 20201124 dzVents Merge PR 4485 from waaren; Update to 3.0.17 add date/time conversion functions
12701 152a10583 20201124 GUI Added some transparency for disabled style
12700 34b2139b9 20201124 GUI Removed missing maps warning
12699 94fc2f994 20201124 GUI Display hardware disabled status
12698 1bd6375d1 20201124 GUI Alert when not all parameters are entered
12697 34c800ea6 20201122 Build Fix for issue 4481; Segmentation fault in build 12693
12696 f0a68a317 20201122 Weather Option to replace Visibility device
12695 68f5a5337 20201122 Watt meter Set default max. Power Usage to 6000 Watt as default
12694 47b5e380a 20201122 Watt meter Checking for max. Power on correct devices
12693 40f91011d 20201122 LightingLog Better Switch User Logging
12692 90fd2a88c 20201122 LightingLog Improved switch log (user)
12691 37320f34a 20201122 EvoHome Renamed internal Evohome switch function
12690 c63fd800e 20201121 LightingLog Correcting incorrect switch user description
12689 13b9181b2 20201119 P1 Meter P1 Meter Decryption, possible fix
12688 14f1d5a9f 20201119 Build Merge PR 4476 from gizmocuz; Revert PR 4417 Clang-Tidy replace bind calls with lambdas
12686 34c807d2b 20201119 Enphase Merge PR 4474 from Tuurtje; prevent overflow of net consumption
12684 82350593d 20201119 Clang-Tidy Merge PR 4417 from neheb; replace bind calls with lambdas
12682 db346f96e 20201118 Clang-Tidy Merge PR 4465 from neheb; Various Clang-Tidy code changes
12672 5d1fc74a6 20201118 GUI Merge PR 4473 from Olifant1990; Fix some log button issues
12670 bee66dffa 20201117 Watt meter Bail out when a higher value is detected
12669 f79cf6624 20201117 Watt meter Maximum Electric Power limiter to prevent faulty sensor reading.
12668 632553592 20201116 Enphase Merge PR 4470 from waaren; Fix for issue 4469 Prevent overflow of production value
12666 bc7445ff9 20201116 dzVents Merge PR 4468 from waaren; Pre-process headers table in Lua before sending to EventSystem
12665 c07870750 20201115 Build Merge PR 4464 from neheb; Fix compilation with newer Python versions
12663 ff4cb0231 20201115 Counter Merge PR 4454 from CreasolTech; Allow negative values when updating (Energy) counter
12660 c9135d56c 20201115 Clang-Tidy Merge PR 4458 from neheb; Applied many Clang-Tidy rules
12644 e3044d2e1 20201115 Clang-Tidy Revert OpenURL changes in dzVents.cpp ; Fix for issue 4462
12641 5947a40c4 20201114 P1 Meter Merge PR 4461 from samm-git; prevent crash on invalid sValue to Gas device
12639 fe397087b 20201113 Clang-Tidy Merge PR 4456 from neheb; Silence various compiler warnings and some other code improvements
12629 fc90b1342 20201111 Clang-Tidy Merge PR 4452 from neheb; Clang-Format: remove keys not present with old versions
12627 b8eeb6ca2 20201111 OpenZwave Updated configuration files
12626 cbb57235c 20201110 Clang-Tidy Increase column limit to 200 characters
12625 d4bfea473 20201110 Various code Removed obsolete declarations for vector iterators
12624 c301f6632 20201110 EventSystem Fix for issue 4449; Crash in EventSystem/Blockly
12623 3114ba8bf 20201109 Build Fixed code error caused by loop conversion
12622 5202ca02a 20201109 Build Fixed compile errors
12621 5990074a0 20201109 Build Fixed compile warning
12620 61d6ec92e 20201109 Clang-Tidy Removing unknown format keys
12619 850235fb9 20201109 Build Fixed compile warning (header)
12618 586b0bade 20201109 AirconWithMe Merge PR 4448 from LarsenDX; Fix for issue 4383; Re-added mistakenly removed line
12616 0f81ca121 20201109 Clang-Tidy Merge PR 4444 from neheb; Use Microsoft style base file
12614 bbef2827b 20201109 Build Fix for issue 4447 Compile error on multiple platforms
12613 34d934c5e 20201109 Build Using temporarily private jsoncpp because of a build error due to upstream repo
12612 91a25887b 20201109 EvoHome Merge PR 4414 from brucemiranda; Decode, display and store hotwater setpoint
12610 2c02ff543 20201109 Clang-Tidy Merge PR 4442 from neheb; for range loop conversions
12607 db233fd1a 20201108 Clang-Tidy Disabled sorting of includes rule
12606 bd32caae1 20201108 Clang-Tidy Merge PR 4440 from neheb; Fix miscelaneous rules
12601 1c2aefe76 20201108 Build Fixing compile warning
12600 c176ab51a 20201108 Clang-Tidy Merge PR 4439 from neheb; Removed void and defaulted destructors
12596 a86a9ad08 20201108 GUI Merge PR 4441 from flopp999; Open page on new browser tab for external domains in hardware setup page
12594 4fc6bf7ea 20201107 Clang-Tidy Merge PR 4438 from neheb; Use standard method to address nullptr
12592 82d570793 20201106 Build Merge PR 4436 from jzapater; Fix for issue 4415 Build failure with python 3.9
12590 6c54b69e2 20201106 Clang-Tidy Merge PR 4435 from neheb; Don't put functions on the same line
12588 f4a316d09 20201106 Clang-Tidy Merge PR 4431 from neheb; Run through
12585 f0466fc70 20201105 Clang-Tidy Merge PR 4430 from neheb; Make clang-format file more similar to the domoticz codebase
12583 1608cc513 20201104 GUI Merge PR 4385 from kiddigital; Improved Weather forecast screen and functionality
12574 77ffeea13 20201103 Clang-Tidy Merge PR 4418 from neheb; Add format file
12554 36715b865 20201103 OpenZwave Updated configuration files
12553 dd8eb9cd0 20201103 dzVents Merge PR 4424 from waaren; update to V3.0.16
12552 c43721a83 20201102 Build Merge PR 4422 from jzapater; Fix for issue 4415 Build failure with python 3.9
12550 4afd2351b 20201102 GUI Merge PR 4382 from michahagg; Complete overhaul of temperature graph (includes autorefresh)
12501 2e2691522 20201027 SQLHelper Merge PR 4419 from kiddigital;Fix for issue 4411 Phantom records in LightingLog
12499 976453d0f 20201025 dzVents Added protection against devices with id 0 and missing attributes
12498 418f2d15f 20201024 dzVents Added resilience against absent subType in thermostat type 3 device-adapter.
12497 c8f1e167e 20201022 dzVents Merge PR 4412 from waaren; update to V3.0.15 (now without updatedBy)
12496 f18fc9720 20201021 Caching Fix for issue 4410 Cache refresh problem on Safari
12495 4b8680319 20201020 dzVents Revert update to V3.0.15 because of severe rise in CPU usage
12494 f6c3b1e94 20201020 dzVents Merge PR 4405 from waaren; update to V3.0.15
12493 197cd8a67 20201019 Hardware monitor Merge PR 4406 from kiddigital; Removed obsolete code
12491 7973d26a0 20201019 OpenWebNet Merge PR 4404 from Spugna85; Fix for issue 4403 Setpoints stopped working
12485 851da37f7 20201015 Hardware monitor Merge PR 4401 from kiddigital; Code cleanup
12483 eb21910b6 20201014 OpenZwave Merge PR 4398 from nonolk; Better handling of Zwave blinds
12481 a11887c34 20201014 Build Merge PR 4397 from xbeaudouin; Fix for compilation under FreeBSD
12480 7820ada8c 20201013 EvoHome Merge PR 4396 from brucemiranda; Added new EvoHome faultlog message
12477 e9a501c26 20201012 Connected cars Merge PR 4394 from kiddigital; Do not stop worker but just keep heartbeating and warn user
12476 854f59ef9 20201012 Hardware monitor Merge PR 4393 from kiddigital; Code cleanup (less compile-time specific code)
12470 f54023052 20201011 Hardware monitor Merge PR 4389 from kiddigital; Code refactoring
12467 2829993f3 20201011 Various code Fixing HTML end tags
12466 9d6e9413e 20201011 GUI Fixed floorplan uploading
12465 631b8ba9b 20201011 GUI Fix for issue 4388 Some floorplan dots mssing
12464 b3cb2fef5 20201011 MQTT Added publish schemes: device index, device name and implemented custom topics for in- and outbound messages
12463 7336ab315 20201008 AirconWithMe Merge PR 4383 from RDols and LarsenDX;Implemented hardware module AirconWithMe
12453 651daa081 20201007 Python plugins Additional call to heartbeat received
12452 1c3859e1d 20201007 Python plugins Fix for issue 4378 Data timeout always restart plugin
12451 6ed85cee0 20201005 GUI Fix for issue 4376 No add or update button on device notification page
12450 3b9300eed 20201004 dzVents Improved code sanity check and small documentation fix
12449 445172aa7 20201003 GUI Making old checkbox small, and enable auto refresh device log where possible
12448 41b79f1d8 20201003 GUI Merge PR 4375 from michahagg; Fix fancy checkboxes in default theme
12445 492c4cb9f 20201003 GUI Removed obsolete code
12444 64233a2d0 20201003 GUI Removed obsolete check for temperature device type
12443 74f4d57bc 20201003 GUI Correcting temperature graphs
12442 9834d993a 20201002 OpenZWave Updated configuration files
12441 a4215d44c 20201002 History Updated History
12440 12113bc63 20201002 GUI Supported more sensor types in autorefresh device logs
12439 70c3809cd 20201002 GUI Fix API call for devicelog charts for day log
12438 0b6803227 20201002 GUI Merge PR 4371 from michahagg; (Instructions for) the included unit tests for PR 4370
12434 be276e60e 20201002 GUI Merge PR 4370 from michahagg; Upgrade of several libraries and temperature Log now supports autorefresh
12433 0f08b8ae4 20201002 Build Fixed compile error
12403 f583c3949 20201002 OpenWeatherMap Merge PR 4366 from Olifant1990; Various fixes and improvements
12400 0bc33209b 20201002 Connected cars Merge PR 4362 from kiddigital; Switch to the new OAuth2 endpoint for Mercedes
12397 3ce58ee2e 20201002 Clickatell SMS Merge PR 4359 from ojozef; Decode the Clickatell api key.
12395 c90b5a10f 20200926 dzVents Merge PR 4365 from waaren; update to version 3.0.14
12394 d837b5c4e 20200923 dzVents Merge PR 4360 from waaren; update to version 3.0.13
12393 46660897d 20200921 Clickatell SMS Merge PR 4350 from osjozef; Add "from" field
12392 29d08c3cb 20200919 Translations Updated translations
12391 3034fcb3e 20200919 GraphLog Merge PR 4342 from michahagg; autorefresh feature for graphical logs
12390 67a9248a3 20200919 openWeatherMap Fix for issue 4351; Openweathermap plugin does not read rain sensor and refactored some code
12389 d728ed196 20200916 Comm5 Merge PR 4332 from correa; Fix for Comm5 MA-4200 hardware
12388 b09940190 20200916 Plugwise Merge PR 4348 from p-hagen; Update to Plugwise scene selector and added a migration process
12383 946e57dc1 20200915 dzVents Prevent confusing log messages when logging a table with embedded functions
12382 3e90d6847 20200914 Various code Small code cleanup
12381 c61747e36 20200914 Tado Merge PR 4344 from kiddigital; Fixed compiler warnings; switched logger to HardwareBase
12379 329675dcc 20200913 dzVents Fix for error when trying to log a table with embedded functions
12377 c8ea3180c 20200913 Denkovi Merge PR 4330 from denkovi;Added two new denkovi devices
12361 879e6b8c3 20200913 Tado Merge PR 4337 from LarsenDX; Add support for per-zone Open Window Detection
12359 8269f669a 20200913 Connected cars Merge PR 4343 from kiddigital; Request data of one resource per cycle to make module more responsive.
12357 0c55028ce 20200912 TTNMQTT Merge PR 4341 from kiddigital; Optimise reading location at startup instead of each cycle
12355 34d18240d 20200911 RTL433 Fix for issue 4340 Prevent crash when receiving a Object or Array
12354 6a06eb8602 20200910 Annatherm Merge PR 4327from p-hagen; Added Helper functions for selector switch
12351 41186ced7a 20200909 Tado Merge PR 4334from larsenDX; Fix Tado Zone/Home limit, Setpoint mix-up
12349 183de9120 20200909 PHP Merge PR 4333from lokonli; Fix PHP Binary
12347 cf48c51b63 20200908 Logging Added friendly warning to Raspberry Pi users when vcgencmd is not installed
12344 572876367 20200907 PHP Merge PR 4326 from lokonli; Fix parsing of full querystring
12338 c8b66860b 20200906 dzVents Merge PR 4322 from waaren; Update to V3.0.12 - Add option to use objects as parm to \object\Exists() methods
12337 9537ad649 20200903 Connected cars Merge PR 4318 from kiddigital; Performance optimization. Query home location only during startup
12335 163768354 20200903 Connected cars Merge PR 4316 from kiddigital; Simplified authentication process
12332 316c9b7c7 20200903 Various code Merge PR 4198 from xbeaudouin; Use standard type of coding in C++ where possible
12313 cca10cd21 20200831 Annatherm Merge PR 4311 from p-hagen; Fixed Annatherm Presets usage in Events
12298 aea8cb5af 20200831 Connected cars Merge PR 4281 from kiddigital; Implemented Mercedes Me as module of connected cars framework
12283 d33514913 20200830 Translations Updated translations
12282 b92d81ab4 20200830 OpenZwave Do not send 0xFF but set level to 99% for ZWave blinds.
12281 a58449cea 20200829 Logging Fix for issue 4308 wrong divider for hardware timeout logmessage
12280 f8711e9c1 20200828 dzVents Give useful message on malformed user scripts in domoticz log
12279 805fee10f 20200826 OpenZwave Merge PR 4304 from RDols; Enabling refreshing values, even when these values didn't change.
12277 54acf5178 20200825 Hardware monitor Merge PR 4302 from akamming; Improve PI hardware detection
12271 866265e2a 20200823 Build Merge PR 4303 from hvbommel; Fix some compiler warnings
12269 81b1d645b 20200823 Weather Merge PR 4300 from hvbommel; Add option to set Wind speed multiplyer
12268 082165a18 20200823 Hardware monitor Merge PR 4299 from akamming; Add internal clock speed to motherboard sensors
12262 5cd59b20b 20200823 History Updated History
12261 0e637522f 20200823 Translations Updated translations
12260 01784e66e 20200823 EventSystem Prevent double triggers when updating a Thermostat Setpoint device via JSON API/M
12259 29ac0412b 20200823 Python plugins Small refraction
12258 7296dd999 20200823 Python plugins Some call refraction
12257 c52d57e94 20200822 Backup Tweaked backup procedure to prevent unnecessary delays
12256 e67541d9d 20200821 GUI Merge PR 4125 from jordanalex04; Fix for issue 3541 allow custom icon for RBGW YeeLight's
12252 ce7f13306 20200820 RFXCom Chime Byron-BY Fix for issue 4276 RFXCOM: Add Byron BY support for transmit
12251 b2278d5f2 20200818 openWeathermap Merge PR 4294 from kiddigital; Fix description of hourly forecast
12248 138de51a1 20200818 Backup Merge PR 4293 from akamming; Tune database backup
12247 0a6028240 20200817 Backup Prevent endless loop in backup code. Fix for issue 4180; domoticz crashes during backup.
12246 d8d60639c 20200817 Conversion Fixed wrong conversion factor (cm to inches) for distance sensor
12245 367253d96 20200816 Translations Updated translations
12242 95ba021e4 20200814 openWeathermap Support for City ID
12241 9c2aa0b40 20200816 OpenZwave Updated configuration files
12240 74d9da850 20200813 openWeathermap Allowing City, Country as location in config
12239 d5eb4800a 20200813 SolarEdge Renamed temperature sensor
12238 cee7b0d9d 20200813 SolarEdge Implemented request in issue 4284; Add support for 3 Phase inverter
12237 96df7b185 20200813 openWeathermap Removed debug log defines
12236 45e055d09 20200812 openWeathermap Fixed new code and made it backward compatible. Fix for issue 4284; Updated openweathermap cause coredump
12235 971c88620 20200812 Daikin Removed Daikin debug write
12234 d5da96f53 20200811 openWeathermap Merge PR 4284 from kiddigital;Change openWeathermap hardware to use new API link
12233 c00c8e0c6 20200811 Various code Merge PR 4286 from RDols;fix bug caused by wrong way of erasing iterator.
12232 092cdd81b 20200811 OpenWebNet Merge PR 4279 from Spugna85; added lights management on area 0, fix for issue 4252
12231 a0890bdb1 20200730 Data push Merge PR 4280 from waaren; Add devicetype Counter incremental to base push, fix for issue 3752
12230 72d6b26e3 20200719 OpenZwave disable AutoUpdateConfigFile
12229 ccc58b997 20200717 GUI Merge PR 4272 from jan-vandenberg; Add total nett usage to smartmeter year report
12228 5bf15b874 20200717 GUI Merge PR 4271 from DewGew; Changed style of notification to Collapsible/ Accordion
12227 36016cd13 20200714 Build Updating CMakeLists.txt to be compatible recent (upstream) jsoncpp changes
12223 a75593293 20200713 GUI Merge PR 4263 from DewGew; Improved lay-out of notifications tab
12221 74c0c9fcc 20200712 OpenZwave Update configuration files
12218 ec4c55d4a 20200712 RTL433 Merge PR 4262 from FredrikFornstad; Added X-10 Security support
12216 f70ef9b88 20200712 OpenZWave Differentiate kWh, kVah, kVar and kVarh
12215 3fe2c57c5 20200711 GUI Corrected Sound sensor on Floorplan
12214 501483af8 20200711 Honeywell Corrected OR statement
12213 be4889e5d 20200708 dzVents Merge PR 42598 from waaren; update to 3.0.11 (solarnoon and sensorValue for custom sensors)
12212 c2fd4451c 20200708 GooglePubSub Fix bug in Update and Delete push rows
12211 943863218 20200708 SolarEdge Add more logging details to API
12210 8bfa60f76 20200708 OpenZwave Merge PR 4257 from akamming; Add "Has Node Failed" and "Replace Failed Node" to ZWave GUI
12202 9cefa7a8e 20200708 Database Merge PR 4258 from waaren; Prevent duplicate keys in preferences table
12201 ebef357ac 20200707 OpenZwave Updated configuration files
12200 102cf93c1 20200705 dzVents Make stringToSeconds available for users and update wiki
12198 7a9dc298c 20200706 OpenZwave Multisensor type 'General' now handled as a custom sensor
12195 44be66e73 20200704 dzVents Merge PR 4254 from waaren; update dzVents to 3.0.10
12194 9d42736b0 20200702 OpenZwave Added 3 new Aeotec Sensors by name
12193 a69b48347 20200702 OpenZwave Updated configuration files
12191 d53ab35b2 20200629 Websockets Add websocket notification for sub/slave devices
12190 574e17d87 20200628 Event Editor Merge PR 4250 from stas-demydiuk; Fix font in events editor on MacOS
12188 757203a10 20200626 OpenZwave Updated configuration files
12184 17f0a1bca 20200622 GUI Added missing equal image
12183 9b32e5719 20200620 dzVents Fixed bug when no nighttime or daytime (in the arctic around June 21, December 21)
12182 abf363b4c 20200619 Blebox Merge PR 4240 from szczukot; Change for the newest SwitchBox API
12179 ebe934350 20200618 dzVents Allow strings enclosed in square brackets in fromJSON
12178 af2cdafee 20200617 Blebox Merge PR 4239 from szczukot; Updated to the latest SwitchBox API
12173 1263a966d 20200615 GUI Merge PR 4237 from mikewoudenberg; Open domoticz window on desktop notification
12171 4dc768123 20200615 Honeywell Merge PR 4231 from deligoz; Add cooling control and Fahrenheit support
12166 885ede465 20200615 Documentation Merge PR 4234 from szczukot; Corrected package name
12164 2aae3498e 20200612 Counter Merge PR 4230 from gizmocuz; Add support for divider in meters of type counter
12161 0352e1e7a 20200611 Buienradar Merge PR 4225 from akamming; Improve resilience to unexpected buienradar responses
12154 eabd79d5a 20200610 GUI Fix for issue 4224 Inverted energy icon colors in report
12153 c8f1d3f0c 20200610 GUI Added inverted color up/down icons
12152 67ae0ce57 20200610 Build Removed images from VStudio project
12151 b4aa9d7bd 20200610 OpenZwave Merge PR 4229 from matjoker; Add sound switch class, methods and devices
12143 db6df3125 20200609 Fan Corrected Fan ID's
12142 7792018f1 20200609 dzVents Fix for some small bugs, -typos and added some remarks in documentation
12140 3b03ec3f0 20200609 Honeywell Merge PR 4223 from deligoz; Fix Honeywell systems with more then 1 thermostat
12138 03c18a5e6 20200609 Fan Add support for fan types Casafan, FT1211R, Falmec, LucciAirDCII, IthoECO and Novy
12136 134f2cf02 20200608 OpenZwave Merge PR 4215 from matjoker; Add sound switch
12134 69107d983 20200608 TTNMQTT Merge PR 4200 from kiddigital; Add possibility to use TTN custom decoder for decoding (incl. batterylevel)
12130 f838ee373 20200608 OpenZwave Merge PR 4216 from matjoker; Add sound switch class
12127 9db9c2902 20200606 dzVents Merge PR 4217 from waaren; Fix compiler casting warnings on Windows
12126 283021bce 20200605 dzVents Merge PR 4208 from waaren; Allow use of HTTP POST with postdata for dzVent customEvents
12125 54ccd7cb6 20200605 OpenZwave Merge PR 4206 from dwmw2; Fix OpenZWave include path handling
12124 47ed63012 20200605 RFLink Merge PR 4209 from bilbolodz; Fix issue 4207 version not detected when using RFLink over TCP
12122 2834bca58 20200605 RTL433 Merge PR 4210 from FredrikFornstad; Fix for issue 4205 user parameters cannot be used
12120 ecd90cd57 20200604 dzVents Merge PR 4204 from waaren; update dzVents to 3.0.9
12119 1f39a6001 20200603 RTL433 Changed indenting in code
12118 3b9d54443 20200602 Sensors Merge PR 4197 from FredrikFornstad; Corrected reported RF Quality to match RSSI range of 0-11
12117 7598e9a84 20200601 Help add app-root to --help text (merged from nuxeh branch)
12114 8546ffa1f 20200601 TTNMQTT Better GPS/Locations handling, distance calculation (Geofencing) and more
12113 98713240b 20200601 Hardware Merge PR 4163 from jeje42; Add meteorologisk (Meteorologisk institutt Norway) to hardware
12112 e1578b40d 20200601 Sensors Added default RSSI parameter
12111 6dd98764 20200601 Sensors Implemented RSSI for Distance sensor, Moisture sensor, Watt Meter, kWh Meter
12110 12017c677 20200601 RTL433 Merge PR 4194 from FredrikFornstad; Map received Signal to Noise Ratio to RSSI
12106 b08d17c2d 20200529 JSON Prevent use of wrong commands in switchcmd parm of switchscene JSON
12105 003356961 20200528 dzVents Merge PR 4186 from waaren; update dzVents to 3.0.8
12103 187eb1326 20200529 Build Cleaned up CMake project
12102 b5745509b 20200528 Build Force update of submodules to latest version
12101 79e825a86 20200528 Logging Allowing duplicate entries for pTypeSecurity1 device types
12100 283e18f34 20200526 Translations Updated translations
12099 1e920c4bf 20200525 RTL433 Merge PR 4178 from annegerben; added wind_avg_m_s and wind_max_m_s for AlectoV1-Wind
12086 ce263e78e 20200525 Pinger Implementing request of issue 4171 Added more log information (Name/IP)
12085 9d19657a9 20200525 Build Merge PR 4181 Fix build if Python is disabled
12083 f6982fce7 20200525 dzVents Fix for utils.round
12081 7f0f8957c 20200524 Blockly Change gcm to fcm
12080 acd0aae1a 20200524 Translations Updated translations
12078 383d1f1c6 20200523 dzVents Merge PR 4177 from waaren; Correct wrong plural of object hardware
12077 686efb0a0 20200522 RTL433 Fix for issue 4172 Added UV type
12076 cecf537d8 20200522 dzVents Merge PR 4173 from waaren; update to 3.0.7 Add domoticz.hardwares() as separate object class
12074 92ba8659d 20200522 OpenZwave Updated configuration files
12073 e13d8e451 20200520 P1 Meter Using OpenSSL for decrypting
12072 a2d4f914f 20200520 P1 Meter Added support for Encryption
12071 64527c22c 20200519 Connected cars Merge PR 4168 from MrHobbes74; Fix for issue 4167 wrong inside temperature
12069 134c1fd51 20200518 dzVents dzVentsify lua code of function domoticz.hardwareInfo
12068 8a885ccea 20200518 dzVents Merge PR 4166 from waaren; update to 3.0.6 - add function domoticz.hardwareInfo
12067 a29cc48a2 20200517 JSON Added optional parameter 'level' to addlogmessage JSON
12065 bbcf7fd06 20200517 Build Removed deprecated bind placeholders in global namespace
12064 51be4bd43 20200517 OpenZwave set node tab as default
12063 a3d98f545 20200516 OpenZwave Implemented legend and tooltips in neighbours overview
12062 86e98e5e3 20200516 GUI Added extra protection against undefined status
12061 b6ac807b9 20200515 RTL433 removed debug breakpoint
12060 e00af595d 20200514 Network Merge PR 4136 from gizmocuz; support IPv6 in LocalNetwork setup
12057 096d786a2 20200514 RTL433 switch1/switch5 messages
12056 0e46dc1ed 20200513 dzVents Stricter check on xml
12055 f225575ea 20200513 RTL433 Fix typo and improved buffer handling
12051 afea37f3d 20200513 OpenZWave Display product name as description (avoids duplicate manufacturer name)
12050 fc46cc773 20200513 RTL433 Fix for non Windows systems
12049 cc6492431 20200513 GUI Merge PR 4159 from waaren; Fix issue with RFXSensor temperature device not showing logpage
12047 a66d7426d 20200513 Build Merge PR 4153 from danielhoperez; Strip version from InnoSetup path
12043 62244845b 20200513 RTL433 RTL433, different buffer approach
12042 ec5b6a2a8 20200512 RTL433 Add pressure (PSI) type
12039 e4372e31d 20200512 RTL433 Fix for broken pipe buffer
12038 ac7b37e15 20200511 RTL433 Switched to Json input
12037 0cbf2196a 20200511 OpenWebNet Merge PR 4151 from Spugna85; added 'gateway interface management', date/time check and sync
12030 01b60a9cd 20200511 Build Merge PR 4145 from danielhoperez; Do not install jsoncpp, mosquitto, sqlite and minizip binaries on make install
12027 865d66e21 20200510 csocket Merge PR 4147 from neheb; remove incorrect #include <sys/errno.h>
12025 40532290c 20200510 SMTP Merge PR 4138 from pieterh; improved error logging for smtp client
12023 c3dd12431 20200510 EcoDevices Merge PR 4142 from laoranz; improved handling of ecoparameter withPAPP
12020 edf6a9788 20200510 RTL433 possible fix for issue 4150 RTL433 increase reception buffer for header-line
12019 9259c27ea 20200508 dzVents Allow JSON's loosely following standard
12018 532168789 20200508 dzVents Merge PR 4149 from waaren; dzVents 3.0.5; fix settings.url and add dumpSelection
12017 d66b49520 20200504 GraphLog Highcharts, using default CSV/XLS exporter
12016 9f752c965 20200504 Connected cars Merge PR 4133 from MrHobbes74; Solve wakeup bug in Tesla module
12012 d08a21c1d 20200503 Update Merge PR 4104 from HoekieN; removed reference to old name of new updateControler
12010 e7f66eca6 20200503 OpenZWave Updated OpenZWave configuration files
12009 5dae4b28b1 20200502 dzVents Merge PR 4126 from waaren; dzVents 3.0.4; less strict contentType check before converting json/xml to table
12006 cef1d029f 20200430 TTNMQTT Merge PR 4103 from kiddigital; Improved calculation and storage of signal-levels
12003 212462a03 20200429 dzVents Merge PR 4118 from joro75; Updated documentation to correct data store location
12002 f035dcd3c 20200429 EventSystem Merge PR 4115 from waaren; Fix for issue 4112 lastLevel and lastUpdate set before eventSystem trigger
12000 0cf752ed7 20200429 Connected cars Merge PR 4117 from MrHobbes74; Add ODO meter, unlock/open alert, max charge level
11998 219ed6439 20200427 dzVents Update dzVents to 3.0.3 make customEvent object consistent with HTTPResponse
11997 bcef96e45 20200426 Network Code refactoring Allow complete IPv6 address in local network setting
11996 e9ba04b51 20200426 Build Bumping version to 2020.2
