Plugins/PlayBulb
From Domoticz Wiki
Revision as of 15:41, 29 December 2020 by Walter vl (talk | contribs)
This Plugin goal is to drive Playbulb / Mipow Bluetooth Bulbs via Domoticz, using BTLE connection (using usb BTLE dongle or RPI3 BTLE Feature) : http://www.playbulb.com/en/index.html
This Plugin Support :
- Garden (fw : BTL400M_1.9) - Candle (fw : BTL300_v5 et 6) - Rainbow (fw: BTL300_V5) - Color (fw : BTL100c_v6) - Comet - Smart - Sphere - Spot (fw:BTL203M_V1.6) - Solar
You can find your FW version using Plybulb X Android or iOS APP, after connecting to the bulb and going to config page
You need to get bulb Bt Mac adresse, For this on a ssh connection run :
sudo hcitool lescan
Then a list of btle device in range of your Dongle will appear, just pic the one you need, playbulb device give there name easily, here for a garden :
71:9A:4B:15:AC:E6 PLAYBULB garden
71:9A:4B:15:AC:E6 (unknown)
A4:C1:38:65:0D:01 uaz6wGda
A4:C1:38:65:0D:01 (unknown)
Don't forget to disconnect your phone from the bulb once all information is getting, bulb doesn't allow 2 connections on the same time.
Then you have to install python environnement for Domoticz :
sudo apt-get install python3-pip libglib2.0-dev
pip3 install bluepy
then as bluepy isn't on working dir for Domoticz, copy it
sudo cp -r /usr/local/lib/python3.4/dist-packages/bluepy/ /usr/lib/python3.4/
or
sudo ln -s /usr/local/lib/python3.4/dist-packages/bluepy /usr/lib/python3.4/bluepy
Create a Mipow dir :
mkdir /home/user/domoticz/plugin/mipow where user is the user name used for domoticz
that mean for a rpi user with raspbian : /home/pi/domoticz/plugins/Mipow
and paste plugin.py for this zip file : https://github.com/zaraki673/MiPow-PlayBulb/
Finally restart domoticz :
sudo service domoticz.sh restart
Goes to Hardware, create a new and search for Mipow/playbulb
- Input your Device MAC Adresse, - Choose your Bulb - Your HCI device (which dongle have to be use to connect domoticz to your bulb)
You have 2 more option :
Activate Status: who keep connection between Domoticz and the bulb: - set on False, you can controle bul with booth Domoticz and Mobile APP, - set on True give exclusivity to Domoticz.
Debug : show debug info on Domoticz Log.
Device will be created on not used device tab, just add it by cliking the the green arrow.
Then Enjoy !
My bulb FW isn't on the list, can't controle it ? yes you can ! (need more works on it)
Let's speak about it on this topic : http://www.domoticz.com/forum/viewtopic.php?f=28&t=16843
